MOCBP4-PM-7.5A
MOCBP4-PM-7.5A
    OPTIFUSE
    MINI FUSE FOOTP. CB-TYPE II,7.5A
MOCBP4-PM-7.5A 数据手册
Type MOCBP4-PM Modified Reset Circuit Breaker Automotive Type II Standard Mini Blade Specifications: Mini Blade Modified Reset Type Circuit Breaker Voltage: 14VDC Amperage: 5A, 7.5A, 10A, 15A, 20A, 25A, 30A Materials: Thermoplastic – (UL Rated 94-V-0) Terminals: Tin plated Copper Alloy Testing Standard: SAE J553 Type II Cover is color coded to Amperage Ratings Operating Temperature: -40º C ~ 85º C Ampere Rated 5A-10A version 15A version 20A version 25A-30A version Interrupt Rating 150A @ 14 VDC 225A @ 14 VDC 300A @ 14 VDC 450A @ 14 VDC www.optifuse.com Part Number MOCBP4-PM-5A MOCBP4-PM-7.5A MOCBP4-PM-10A MOCBP4-PM-15A MOCBP4-PM-20A MOCBP4-PM-25A MOCBP4-PM-30A (619) 593-5050 Amperage 5A 7.5A 10A 15A 20A 25A 30A Body Color Tan Brown Red Blue Yellow White Green Mechanical Dimensions: Inches [mm] Part number: MOCBP4-PM Time Current Curves Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. -Not intended for submersible water applications. Note: All specifications subject to change without notice. Rev A 10/2015 - Page: 1/1 Code B01-01H
MOCBP4-PM-7.5A 价格&库存
很抱歉,暂时无法提供与“MOCBP4-PM-7.5A”相匹配的价格&库存,您可以联系我们找货
