MSC-500MA
MSC-500MA
    OPTIFUSE
    5.00 x 20.00mm
    GLASS-5X20MM (UL), MEDIUM 500MA
MSC-500MA 数据手册
Type MSC / MSC-P Medium Time Delay Glass Tube Fuse 5 x 20 mm Agency Standards and Listings: cULus Listed cURus Recognized CSA Certified PSE KC 100mA-1.6A, 10A 2A-8A 100mA-8A, 10A 1A-15A 100mA-10A Interrupt Ratings: 100mA~1A 35A 1.2 A~3.5A 100A 4A~8A, 10A 200A 1A~15A 100A 100mA~10A 100A @ 250VAC @ 250VAC – CSA @ 250VAC – CSA @ 250VAC – PSE @ 250VAC – KC Operating Temperature: -55C - +125C Time Characteristics 135% Max 1h 200% Max 5s Mechanical Dimensions: Inches [mm] www.optifuse.com Cartridge Part No. Axial Lead Part No. MSC-100mA MSC-125mA MSC-150mA MSC-160mA MSC-200mA MSC-250mA MSC-300mA MSC-315mA MSC-350mA MSC-375mA MSC-400mA MSC-500mA MSC-600mA MSC-630mA MSC-700mA MSC-750mA MSC-800mA MSC-1A MSC-1.2A MSC-1.25A MSC-1.5A MSC-1.6A MSC-2A MSC-2.25A MSC-2.5A MSC-3A MSC-3.15A MSC-3.5A MSC-4A MSC-5A MSC-6A MSC-6.3A MSC-7A MSC-8A MSC-9A MSC-10A MSC-12A MSC-15A MSC-P-100mA MSC-P-125mA MSC-P-150mA MSC-P-160mA MSC-P-200mA MSC-P-250mA MSC-P-300mA MSC-P-315mA MSC-P-350mA MSC-P-375mA MSC-P-400mA MSC-P-500mA MSC-P-600mA MSC-P-630mA MSC-P-700mA MSC-P-750mA MSC-P-800mA MSC-P-1A MSC-P-1.2A MSC-P-1.25A MSC-P-1.5A MSC-P-1.6A MSC-P-2A MSC-P-2.25A MSC-P-2.5A MSC-P-3A MSC-P-3.15A MSC-P-3.5A MSC-P-4A MSC-P-5A MSC-P-6A MSC-P-6.3A MSC-P-7A MSC-P-8A MSC-P-9A MSC-P-10A MSC-P-12A MSC-P-15A Amper e Rating 100mA 125mA 150mA 160mA 200mA 250mA 300mA 315mA 350mA 375mA 400mA 500mA 600mA 630mA 700mA 750mA 800mA 1A 1.2A 1.25A 1.5A 1.6A 2A 2.25A 2.5A 3A 3.15A 3.5A 4A 5A 6A 6.3A 7A 8A 9A 10A 12A 15A (619) 593-5050 Voltage Rating (V) 250V Nominal Melting I2t A2 Sec 0.01227 0.02530 0.02325 0.04315 0.08063 0.1341 0.2167 0.2393 0.3061 0.4017 0.3766 0.7704 0.6552 0.6880 0.7551 0.8669 1.165 2.112 3.608 3.962 6.713 7.795 4.888 6.383 10.49 15.50 17.41 27.88 33.47 51.13 75.02 84.15 112.1 167.0 190.3 257.8 408.1 731.9 Lead Wire: Tin Plated Copper Dia. 0.65±0.02mm 100mA ~ 9A Dia. 0.8±0.02mm 10A ~ 15A Note: All specifications subject to change without notice. Rev C 12/2015 - Page: 1/2 Code: H01-01H Type MSC / MSC-P Medium Time Delay Glass Tube Fuse 5 x 20 mm www.optifuse.com (619) 593-5050 Part Number - MSC/MSC-P Time Current Graph Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuses are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Fuse device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 12/2015 - Page: 2/2 Code: H01-01H
MSC-500MA 价格&库存
很抱歉,暂时无法提供与“MSC-500MA”相匹配的价格&库存,您可以联系我们找货
