PMA-DB-05-Q1R
PMA-DB-05-Q1R
    OPTIFUSE
    1-1/4"X1/4"-DRIVER/BAYONET,
PMA-DB-05-Q1R 数据手册
Type PMA-DB-05-Q1R (formerly PDA-01) Panel Mount Fuse Holder ¼” x 1¼” (6.3 x 30mm) Fuses Driver / Bayonet www.optifuse.com (619) 593-5050 Electrical Rating: 15A, 250V AC Fuse Style: ¼” x 1¼” (6.3 x 32mm) Material: Frame and Cap: PBT (UL flame: 94V-0) Terminals: Tin-plated brass Cap: Slotted Driver type, Bayonet type Mounting: by nut Terminal: Solder/Quick-Connect – 4.8mm/0.187” Panel Thickness: 0.5 ~ 4.5mm Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 12/2007 - Page: 1/1 Code S02-02D
PMA-DB-05-Q1R 价格&库存
很抱歉,暂时无法提供与“PMA-DB-05-Q1R”相匹配的价格&库存,您可以联系我们找货
