PMA-DS-05-Q1R
PMA-DS-05-Q1R
    OPTIFUSE
    1-1/4"X1/4" - DRIVER/SCREW,
PMA-DS-05-Q1R 数据手册
Type PMA-DS-05-Q1R Panel Mount Fuse Holder ¼” x 1¼” (6.3 x 32mm) Fuses Driver / Screw www.optifuse.com (619) 593-5050 Electrical Rating: 15A, 250V AC Fuse Style: ¼” x 1¼” (6.3 x 32mm) Material: Frame and Cap: PBT (UL flame: 94V-0) Terminals: Tin-plated brass Cap: Slotted Driver type, Screw type Mounting: by nut Terminal: Solder/Quick-Connect 4.8mm / 0.187” Panel Thickness: 0.5 ~ 4.5mm Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 12/2007 - Page: 1/1 Code S02-02D
PMA-DS-05-Q1R 价格&库存
很抱歉,暂时无法提供与“PMA-DS-05-Q1R”相匹配的价格&库存,您可以联系我们找货
PMA-DS-05-Q1R
  • 1+59.217781+7.66140
  • 20+54.4139820+7.03990
  • 100+49.69752100+6.42970
  • 200+44.98106200+5.81950
库存:85
