PMA-KB-03-Q2S
PMA-KB-03-Q2S
    OPTIFUSE
    1-1/4"X1/4" - KNOB/BAYONET,
PMA-KB-03-Q2S 数据手册
Type PMA-KB-03-Q2S (formerly PKA-02) Panel Mount Fuse Holder ¼” x 1¼” (6.3 x 32mm) Fuses Knob / Bayonet www.optifuse.com (619) 593-5050 Electrical Rating: 10A, 250V AC Fuse Style: ¼” x 1¼” (6.3 x 32mm) Material: Frame and Cap: Phenolic (UL flame: 94V-1) Terminals: Nickel-plated brass Cap: Knob type, Bayonet type Max. Operating Temperature: 150C Mounting: by plastic nut Terminal: Solder/Quick-Connect 6.4mm / 0.250” Panel Thickness: 0.5 ~ 6.5mm Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev B 03/2016 - Page: 1/1 Code S02-02D
PMA-KB-03-Q2S 价格&库存
很抱歉,暂时无法提供与“PMA-KB-03-Q2S”相匹配的价格&库存,您可以联系我们找货
PMA-KB-03-Q2S
  • 1+26.884261+3.48040
  • 9+24.963969+3.23180
库存:7
