PMA-KB-07-Q1R-BL
PMA-KB-07-Q1R-BL
    OPTIFUSE
    1-1/4"X1/4" - KNOB/BAYONET,
PMA-KB-07-Q1R-BL 数据手册
Type PMA-KB-07-Q1R Panel Mount Fuse Holder ¼” x 1¼” (6.3 x 32mm) Fuses Knob / Bayonet – Color Cap Electrical Rating: 10A, 250V AC Fuse Style: ¼” x 1¼” (6.3 x 32mm) Material: Frame and Cap: PBT (UL flame: 94V-0) Terminals: Tin-plated brass Cap: Knob type, Bayonet type Cap Colors: Green, Blue, Red, Gold or Black Mounting: by nut Terminal: Solder/Quick-Connect 4.8mm / 0.187” Panel Thickness: 0.5 ~ 4.5mm Agency Standards and Listings: www.optifuse.com Part Number PMA-KB-07-Q1R-GN PMA-KB-07-Q1R-BL PMA-KB-07-Q1R-RD PMA-KB-07-Q1R-GO PMA-KB-07-Q1R-BK (619) 593-5050 Cap Color Green Blue Red Gold Black Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev B 03/2011 - Page: 1/1 Code S02-02D
PMA-KB-07-Q1R-BL 价格&库存
很抱歉,暂时无法提供与“PMA-KB-07-Q1R-BL”相匹配的价格&库存,您可以联系我们找货
