PMA-KS-02-Q1S
PMA-KS-02-Q1S
    OPTIFUSE
    1-1/4"X1/4" - KNOB/SCREW,
PMA-KS-02-Q1S 数据手册
Type PMA-KS-02-Q1S (formerly PKA-03) Panel Mount Fuse Holder ¼” x 1¼” (6.3 x 32mm) Fuses Knob / Screw www.optifuse.com (619) 593-5050 Electrical Rating: 10A, 250V AC Fuse Style: ¼” x 1¼” (6.3 x 32mm) Material: Frame and Cap: Phenolic (UL flame: 94V-1) Terminals: Nickel-plated brass Cap: Knob type, Screw type Mounting: by nut Terminal: Solder 4.2mm / 0.163”, Solder/Quick-Connect 4.8mm / 0.187” Panel Thickness: 0.5 ~ 4.5mm Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 01/2008 - Page: 1/1 Code S02-02D
PMA-KS-02-Q1S 价格&库存
很抱歉,暂时无法提供与“PMA-KS-02-Q1S”相匹配的价格&库存,您可以联系我们找货
