PMA-LS-DC1-Q2S
PMA-LS-DC1-Q2S
    OPTIFUSE
    1-1/4"X1/4"-LED WARNING/SCREW,
PMA-LS-DC1-Q2S 数据手册
Type PMA-LS-DC1-Q2S Panel Mount Fuse Holder ¼” x 1¼” (6.3 x 32mm) Fuses LED Warning Light / Screw www.optifuse.com (619) 593-5050 Electrical Rating: 20A, 32V DC Fuse Style: ¼” x 1¼” (6.3 x 32mm) IP Rating: IP66 Material: Frame: Phenolic (UL flame: 94V-1) Cap: Polycarbonate (UL flame: 94V-2) Terminals: Silver-plated copper Cap: LED Warning Light type, Screw type LED indicates when fuse is burned. Mounting: by nut Terminal: Solder/Quick-Connect 6.4mm / 0.250” Panel Thickness: 0.5 ~ 10.0mm Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 06/2011 - Page: 1/1 Code S02-01H
PMA-LS-DC1-Q2S 价格&库存
很抱歉,暂时无法提供与“PMA-LS-DC1-Q2S”相匹配的价格&库存,您可以联系我们找货
