Type PMC-DS-05-SOR (formerly PDC-02)
Panel Mount Fuse Holder
5 x 20 mm Fuses
Driver / Screw
www.optifuse.com
(619) 593-5050
Electrical Rating: 10A, 250V AC
Fuse Style: 5 x 20mm
Material:
Frame and Cap: Phenolic (UL flame: 94V-2)
Terminals: Tin-plated brass
Cap: Slotted Driver type, Screw type
Mounting: by nut
Terminal: Solder 4.00mm / 0.156”
Panel Thickness: 4.5mm MAX
Agency Standards and Listings:
Product Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse.
-Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 01/2008 - Page: 1/1
Code S02-02D
很抱歉,暂时无法提供与“PMC-DS-05-SOR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+39.303841+5.08500
- 20+36.1595320+4.67820
- 100+33.01522100+4.27140
- 200+29.87092200+3.86460
