PMC-KB-07-SOR-RD
PMC-KB-07-SOR-RD
    OPTIFUSE
    5 X 20 MM - KNOB/BAYONET,
PMC-KB-07-SOR-RD 数据手册
Type PMC-KB-07-SOR Panel Mount Fuse Holder 5 x 20mm Fuses Knob / Bayonet – Color Cap Electrical Rating: 10A, 250V AC Fuse Style: 5 x 20mm Material: Frame: Bakelite (94V-0) Cap: PBT (94V-0) Terminals: Tin-plated brass Color Cap: ABS (94HB) Cap: Knob type, Bayonet type Cap Colors: Green, Blue, Red, Gold, or Black Mounting: by nut Terminal: Solder tabs - 4mm / 0.157” Panel Thickness: 0.5 ~ 3.0mm Agency Standards and Listings: www.optifuse.com Part Number PMC-KB-07-SOR-GN PMC-KB-07-SOR -BL PMC-KB-07-SOR -RD PMC-KB-07-SOR -GO PMC-KB-07-SOR -BK (619) 593-5050 Cap Color Green Blue Red Gold Black Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev B 03/2011 - Page: 1/1 Code S02-01H
PMC-KB-07-SOR-RD 价格&库存
很抱歉,暂时无法提供与“PMC-KB-07-SOR-RD”相匹配的价格&库存,您可以联系我们找货
