PMC-KS-01-SOS
PMC-KS-01-SOS
    OPTIFUSE
    5 X 20 MM - KNOB/BAYONET,
PMC-KS-01-SOS 数据手册
Type PMC-KS-01-SOS (formerly PKC-01) Panel Mount Fuse Holder 5 x 20 mm Fuses Knob / Screw www.optifuse.com (619) 593-5050 Electrical Rating: 10A, 250V AC Fuse Style: 5 x 20mm Material: Frame and Cap: Phenolic (UL flame: 94V-2) Terminals: Nickel-plated brass Cap: Knob type, Screw type Mounting: by metal nut with white washer Terminal: Solder 4.0mm / 0.156” Panel Thickness: 4.5mm MAX Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 01/2008 - Page: 1/1 Code S02-02D
PMC-KS-01-SOS 价格&库存
很抱歉,暂时无法提供与“PMC-KS-01-SOS”相匹配的价格&库存,您可以联系我们找货
