PVC-02
PVC-02
    OPTIFUSE
    PCB MOUNT FUSEHOLDER-5X20MM,
PVC-02 数据手册
Type PVC-02 PCB Mounted Vertical Fuse Holder 5mm x 20mm www.optifuse.com (619) 593-5050 Electrical Rating: 10A, 250VAC Fuse Style: 5mm x 20mm Material: Frame and Cap: Thermoplastic (UL Flame: 94V-1) Terminal: Nickel Plated Brass Mounting: PCB mounting Cap: Finger Grip / Screwdriver Slot Combo Bayonet Knob Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 02/2011 - Page: 1/1 Code S02-01H
PVC-02 价格&库存
很抱歉,暂时无法提供与“PVC-02”相匹配的价格&库存,您可以联系我们找货
