RA4-1A-DC-2-GL
RA4-1A-DC-2-GL
    SWITCHCOMPONENTS(开关元件)
    3P SPST OFF-ON LED - IP65 DC
RA4-1A-DC-2-GL 数据手册
Rocker Switch RA4-1A-DC-2-GL Mechanical Dimensions (mm) Tolerances ±0.3 Unless Otherwise Specified Circuit Diagram Mounting Hole 3P SPST OFF-ON (LED-D) Thickness: 1.5~2.5 Thickness: 0.7~2.5 Electrical Specifications Material Specifications Rating 20A 14V DC Frame Black, Nylon 66 (94-V2) Contact Resistance 50m ohm Max. Actuator Green clear, PC (94-V2) Insulation Resistance DC 500V 100M ohm Min. Waterproof Rubber Black, Silicone IP65 Dielectric Strength AC 1500V 1 minute Terminals Silver plated, Copper alloy Operation Temperature -25°C~85°C LED Green (Dependent)
RA4-1A-DC-2-GL 价格&库存
很抱歉,暂时无法提供与“RA4-1A-DC-2-GL”相匹配的价格&库存,您可以联系我们找货
RA4-1A-DC-2-GL
  • 1+42.607771+5.51440
  • 25+37.8056625+4.89290
  • 50+35.4482750+4.58780
  • 100+33.09087100+4.28270
