RE2-1A-DC-1-UL
RE2-1A-DC-1-UL
    SWITCHCOMPONENTS(开关元件)
    MID-SIZE OFF-ON BULB- IP65 DC
RE2-1A-DC-1-UL 数据手册
Rocker Switch RE2-1A-DC-1-UL Mechanical Dimensions (mm) Tolerances ±0.3 Unless Otherwise Specified Circuit Diagram Mounting Hole 3P SPST OFF-ON (LED-D) Electrical Specifications Thickness X Y 0.75~2.5 27.6-0.1 13.8+0.1 2.5~3.5 27.8-0.1 13.8+0.1 3.5~4.5 28-0.1 13.8+0.1 Material Specifications Rating 25A 14V DC Frame Black, Nylon#66 Contact Resistance 50m ohm Max. Actuator Blue, Nylon#66+30%GF Insulation Resistance DC 500V 100M ohm Min. Terminal 1,2:Copper alloy, Silver plated 3: Brass alloy Dielectric Strength AC 1500V 1 minute LED Blue (Dependent) Operation Temperature -25°C~85°C Waterproof IP65, Black Silicone Rubber
RE2-1A-DC-1-UL 价格&库存
很抱歉,暂时无法提供与“RE2-1A-DC-1-UL”相匹配的价格&库存,您可以联系我们找货
