TCA-250MA
TCA-250MA
    OPTIFUSE
    3AB,3AG,1/4" x 1-1/4"
    CERAMIC - 6.3X32MM, SLOW 250MA
TCA-250MA 数据手册
Type TCA/TCA-P 6.3 x 32mm Time-Lag Ceramic Tube Fuse www.optifuse.com (619) 593-5050 Agency Standards and Listings: UL Listed UL Recognized PSE KC TÜV 100mA-15A 20A-30A 1A-30A 500mA-12A, 15A-30A 3A-30A Electrical Characteristics 100% Min 4h 135% Max 1h 200% Max 120s Interrupting Ratings 100mA~15A 10,000A 20A~25A 400A 1A~15A 500A 100mA~1A 35A 1.2A~3.5A 100A 4A~10A 200A 12A~15A 750A 20A~25A 100A 1A~15A 100A 500mA~30A 100A at 125VAC at 125VAC at 125VAC PSE at 250VAC at 250VAC at 250VAC at 250VAC at 250VAC at 250VAC PSE at 250VAC KC Operating Temperature: -55C - +125C Cartridge Part Number Axial Lead Part Number Ampere Rating Voltage Rating TCA-100mA TCA-125mA TCA-200mA TCA-250mA TCA-300mA TCA-375mA TCA-400mA TCA-500mA TCA-600mA TCA-630mA TCA-750mA TCA-800mA TCA-1A TCA-1.2A TCA-1.25A TCA-1.5A TCA-1.6A TCA-2A TCA-2.5A TCA-3A TCA-3.5A TCA-4A TCA-5A TCA-6A TCA-7A TCA-8A TCA-10A TCA-12A TCA-13A TCA-15A TCA-20A TCA-25A TCA-30A TCA-P-100mA TCA-P-125mA TCA-P-200mA TCA-P-250mA TCA-P-300mA TCA-P-375mA TCA-P-400mA TCA-P-500mA TCA-P-600mA TCA-P-630mA TCA-P-750mA TCA-P-800mA TCA-P-1A TCA-P-1.2A TCA-P-1.25A TCA-P-1.5A TCA-P-1.6A TCA-P-2A TCA-P-2.5A TCA-P-3A TCA-P-3.5A TCA-P-4A TCA-P-5A TCA-P-6A TCA-P-7A TCA-P-8A TCA-P-10A TCA-P-12A TCA-P-13A TCA-P-15A TCA-P-20A TCA-P-25A TCA-P-30A 100mA 125mA 200mA 250mA 300mA 375mA 400mA 500mA 600mA 630mA 750mA 800mA 1A 1.2A 1.25A 1.5A 1.6A 2A 2.5A 3A 3.5A 4A 5A 6A 7A 8A 10A 12A 13A 15A 20A 25A 30A 250V Physical Specifications: Materials Ceramic Body/Nickel Plated Brass Contacts Lead Wire: Tin Plated Copper, Dia. 0.8mm < 15A Dia. 1mm ≥ 15 Mechanical Dimensions: Note: All specifications subject to change without notice. Rev E 10/2018 - Page: 1/2 Code H01-01H Type TCA/TCA-P 6.3 x 32mm Time-Lag Ceramic Tube Fuse www.optifuse.com (619) 593-5050 Time Current Curve Graph Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of fuse with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev E 10/2018 - Page: 2/2 Code H01-01H
TCA-250MA 价格&库存
很抱歉,暂时无法提供与“TCA-250MA”相匹配的价格&库存,您可以联系我们找货
