TCC-5A
TCC-5A
    OPTIFUSE
    5.00 x 20.00mm
    CERAMIC - 5X20MM (UL), SLOW 5A
TCC-5A 数据手册
Type TCC / TCC-P Time Lag Ceramic Fuse 5 x 20 mm Part number: TCC-XXA or TCC-P-XXA Where XX is Amperage P is for Pigtail version Agency Standards and Listings: Approvals: UL Listed 100mA-15A CSA Certified 100mA-15A PSE 5.1A-15A (250V) KTL 1.5A-20A Time Characteristic 1 In Rated Current MIN 100mA~20A 4 Hrs 1.35 In MAX 1 Hr MIN 2 Sec 2 In MAX 120 Sec Interrupt Ratings: 100mA~15A: 10,000 amperes at 125VAC 100mA~1A: 35 amperes at 250VAC 1.25A~3.5A: 100 amperes at 250VAC 3.75A~10A: 200 amperes at 250VAC 10.1A~15A: 750 amperes at 250VAC 15.1A~20A 200 amperes at 250VAC Operating Temperature: -55ºC to +125ºC Physical Specifications: Materials: Ceramic body / Nickel Plated Brass Caps Lead Wire: Diameter Ø0.8 mm 14A and less. Diameter Ø1.0 mm for rating above 15A to 19A. Diameter Ø1.2 mm for rating above 20A. Mechanical Dimensions: www.optifuse.com Cartridge Part Number. TCC-100mA TCC-125mA TCC-150mA TCC-160mA TCC-175mA TCC-200mA TCC-250mA TCC-300mA TCC-350mA TCC-400mA TCC-500mA TCC-600mA TCC-700mA TCC-800mA TCC-1A TCC-1.25A TCC-1.5A TCC-1.6A TCC-2A TCC-2.5A TCC-3A TCC-3.15A TCC-4A TCC-5A TCC-6A TCC-6.3A TCC-7A TCC-8A TCC-10A TCC-12A TCC-15A TCC-20A Axial Lead Part Number TCC-P-100mA TCC-P-125mA TCC-P-150mA TCC-P-160mA TCC-P-175mA TCC-P-200mA TCC-P-250mA TCC-P-300mA TCC-P-350mA TCC-P-400mA TCC-P-500mA TCC-P-600mA TCC-P-700mA TCC-P-800mA TCC-P-1A TCC-P-1.25A TCC-P-1.5A TCC-P-1.6A TCC-P-2A TCC-P-2.5A TCC-P-3A TCC-P-3.15A TCC-P-4A TCC-P-5A TCC-P-6A TCC-P-6.3A TCC-P-7A TCC-P-8A TCC-P-10A TCC-P-12A TCC-P-15A TCC-P-20A Ampere Rating (In) 100mA 125mA 150mA 160mA 175mA 200mA 250mA 300mA 350mA 400mA 500mA 600mA 700mA 800mA 1A 1.25A 1.5A 1.6A 2A 2.5A 3A 3.15A 4A 5A 6A 6.3A 7A 8A 10A 12A 15A 20A (619) 593-5050 Voltage Nominal Rating Resistance (V) Cold Ohms 16.860 7.8250 5.6874 4.5000 3.9200 3.5400 2.0475 1.8920 1.2320 0.9350 0.6430 0.4620 0.3200 0.2267 0.1970 0.1285 250V 0.0890 0.0852 0.0585 0.0872 0.0615 0.0607 0.0410 0.0344 0.0231 0.0221 0.0117 0.0104 0.0074 0.0057 0.0041 0.0028 Nominal Melting I2t A2 Sec 0.0400 0.0703 0.0832 0.0896 0.1148 0.1400 0.2180 0.2700 0.2900 0.3200 0.3800 0.4300 0.5400 0.6400 1.1520 2.3250 4.4384 5.2838 10.656 5.1183 9.8370 12.145 24.023 35.087 48.413 52.411 61.740 75.422 174.02 274.65 534.24 959.40 * Please contact Optifuse Packaging : 1. In Bulk : TCC – 1,000 pcs : TCC-P – 500 pcs per box. 2. On Axial Tape & Reel: 1,000 pcs per reel. 3. Tape & Reel specification: Per EIA-296-E & IEC 286-1 @ 10mm Pitch and 56.5mm inside Tape spacing. Note: All specifications subject to change without notice. Rev D 02/2015 - Page: 1/2 Code C01-01H Type TCC / TCC-P Time Lag Ceramic Fuse 5 x 20 mm www.optifuse.com (619) 593-5050 Part Number TCC/TCC-P Time Current Curve Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of fuse with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev D 02/2015 - Page: 2/2 Code C01-01H
TCC-5A 价格&库存
很抱歉,暂时无法提供与“TCC-5A”相匹配的价格&库存,您可以联系我们找货
