TCD-250MA
TCD-250MA
    OPTIFUSE
    D5.2xL20mm
    一次性保险丝(熔断) 250mA 250V
TCD-250MA 数据手册
Type TCD Time-Delay High Breaking Capacity 5 x 20 mm Ceramic Fuse www.optifuse.com (619) 593-5050 Agency Standards and Listings: Cartridge Part number CCC CQC SEMKO VDE BSI UR/C-UR PSE KC 1A~6.3A 8A, 10A, 12.5A, 16A 1A~10A, 12.5A, 16A 1A~10A, 12.5A, 16A 1A~6.3A 200mA~15A 1A~15A 1A~10A Interrupt Ratings: 1500Amperes at 250V AC Time Characteristics 275% Rated 210% Current MAX MIN MAX 200mA~ 30 250 80 800mA min ms sec 30 750 80 1A~3.15A min ms sec 30 750 80 4A~10A min ms sec 30 1 80 12A~16A min sec sec 400% MIN MAX 50 5 ms sec 95 5 ms sec 150 5 ms sec 150 8 ms sec 1000% MIN MAX 5 150 ms ms 10 150 ms ms 10 150 ms ms 20 150 ms ms TCD-200mA TCD-250mA TCD-315mA TCD-400mA TCD-500mA TCD-630mA TCD-800mA TCD-1A TCD-1.25A TCD-1.6A TCD-2A TCD-2.5A TCD-3.15A TCD-4A TCD-5A TCD-6.3A TCD-8A TCD-10A TCD-12A TCD-12.5A TCD-15A TCD-16A Axial Lead Part number TCD-P-200mA TCD-P-250mA TCD-P-315mA TCD-P-400mA TCD-P-500mA TCD-P-630mA TCD-P-800mA TCD-P-1A TCD-P-1.25A TCD-P-1.6A TCD-P-2A TCD-P-2.5A TCD-P-3.15A TCD-P-4A TCD-P-5A TCD-P-6.3A TCD-P-8A TCD-P-10A TCD-P-12A TCD-P-12.5A TCD-P-15A TCD-P-16A Ampere Rating Voltage Rating 200mA 250mA 315mA 400mA 500mA 630mA 800mA 1A 1.25A 1.6A 2A 2.5A 3.15A 4A 5A 6.3A 8A 10A 12A 12.5A 15A 16A 250V Mechanical Dimensions: Inches [mm] Operating Temperature: -55ºC to +125ºC Material: Ceramic Body/Nickel Plated Brass Caps Lead Wire Ø0.65mm - < 10A Ø0.8mm - 10A ~ 12A Ø1.0mm - > 12A Packaging: TCD 1000 pcs; TCD-P 500 pcs per box. Note: All specifications subject to change without notice. Rev D 01/2016 - Page: 1/2 Code: H01-01H Type TCD Time-Delay High Breaking Capacity 5 x 20 mm Ceramic Fuse www.optifuse.com (619) 593-5050 Part Number TCD TIME CURRENT CURVES Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Glass Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Glass Fuse device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev D 01/2016 - Page: 2/2 Code: H01-01H
TCD-250MA 价格&库存
很抱歉,暂时无法提供与“TCD-250MA”相匹配的价格&库存,您可以联系我们找货
