TMR-2A
TMR-2A
    OPTIFUSE
    插件,P=5.08mm
    一次性保险丝(熔断) 2A 250V
TMR-2A 数据手册
Type TMR Time Lag Micro Fuse Radial Leaded – Long Leaded Designed to Meet UL/CSA Specifications www.optifuse.com (619) 593-5050 Agency Standards and Listings: Voltage: 250V Material Body: Thermoplastic UL94V0 Pin: Copper Alloy, Tin plated Element: Silver Alloy Interrupt Ratings: 50A @ 250 VAC Electrical Characteristics: Rated Current 1.0 In 2.0 In Carry 60 sec Max 50mA~10A TMR-xxA TMR-xxA-T for Loose Fuses, Bulk, in a bag for Taped Fuses, in a box Mechanical Dimensions: Inches [mm] Warning: Cartridge Catalog Number TMR-50mA TMR-60mA TMR-63mA TMR-80mA TMR-100mA TMR-125mA TMR-160mA TMR-200mA TMR-250mA TMR-300mA TMR-315mA TMR-400mA TMR-500mA TMR-600mA TMR-630mA TMR-700mA TMR-800mA TMR-1A TMR-1.25A TMR-1.5A TMR-1.6A TMR-2A TMR-2.5A TMR-3A TMR-3.15A TMR-3.5A TMR-4A TMR-5A TMR-6.3A TMR-7A TMR-8A TMR-10A Ampere Rating 50mA 60mA 63mA 80mA 100mA 125mA 160mA 200mA 250mA 300mA 315mA 400mA 500mA 600mA 630mA 700mA 800mA 1A 1.25A 1.5A 1.6A 2A 2.5A 3A 3.15A 3.5A 4A 5A 6.3A 7A 8A 10A Voltage Rating I2T 250VAC 0.0056 0.0075 0.009 0.014 0.025 0.044 0.058 0.1 0.17 0.22 0.26 0.32 0.58 0.67 0.75 0.85 0.98 2.8 3.8 4.8 5.2 7.5 14 19 22 24 27 59 100 122 160 220 -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Micro Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Micro Fuse device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev I 09/2018- Page: 1/1 Code: G02-01H
TMR-2A 价格&库存
很抱歉,暂时无法提供与“TMR-2A”相匹配的价格&库存,您可以联系我们找货
