TSD-250MA
TSD-250MA
    OPTIFUSE
    D5.2xL20mm
    一次性保险丝(熔断) 250mA 250V
TSD-250MA 数据手册
Type TSD Time-Delay Glass Tube Fuse 5 x 20 mm Agency Standards and Listings: CCC CQC SEMKO VDE BSI IMQ UR/C-UR CSA PSE KC CE 100mA~6.3A 8A,10A,12.5A,16A 125mA~10A,12.5A 125mA~10A,12.5A 125mA~6.3A 125mA~6.3A 125mA~15A 125mA~6.3A 1A~15A 125mA~6.3A 100mA~20A IEC: 60127 Interrupt Ratings: 35A or 10 In 250V AC Whichever is Greater Time Characteristics 275% Rated 210% Current MAX MIN MAX 2 200 10 100mA min ms sec 125mA 2 600 10 ~10A min ms sec 5 600 15 > 10A min ms sec 400% MIN MAX 40 3 ms sec 150 3 ms sec 150 5 ms sec 1000% MIN MAX 10 300 ms ms 20 300 ms ms 20 400 ms ms www.optifuse.com Cartridge Part number TSD-100mA TSD-125mA TSD-160mA TSD-200mA TSD-250mA TSD-315mA TSD-400mA TSD-500mA TSD-630mA TSD-800mA TSD-1A TSD-1.25A TSD-1.6A TSD-2A TSD-2.5A TSD-3.15A TSD-4A TSD-5A TSD-6.3A TSD-8A TSD-10A TSD-12A TSD-12.5A TSD-15A TSD-16A TSD-20A (619) 593-5050 Axial Lead Ampere Voltage Part number Rating Rating TSD-P-100mA 100mA TSD-P-125mA 125mA TSD-P-160mA 160mA TSD-P-200mA 200mA TSD-P-250mA 250mA TSD-P-315mA 315mA TSD-P-400mA 400mA TSD-P-500mA 500mA TSD-P-630mA 630mA TSD-P-800mA 800mA TSD-P-1A 1A TSD-P-1.25A 1.25A TSD-P-1.6A 1.6A 250V TSD-P-2A 2A TSD-P-2.5A 2.5A TSD-P-3.15A 3.15A TSD-P-4A 4A TSD-P-5A 5A TSD-P-6.3A 6.3A TSD-P-8A 8A TSD-P-10A 10A TSD-P-12A 12A TSD-P-12.5A 12.5A TSD-P-15A 15A TSD-P-16A 16A TSD-P-20A 20A I2t Sec A2 0.0223 0.0417 0.0767 0.1628 0.3808 0.4833 0.7968 1.362 1.583 3.004 5.309 3.879 6.890 12.33 20.63 36.91 70.56 108.7 187.8 314.9 583.4 958.9 1045 1668 2231 3010 Mechanical Dimensions: Inches [mm] Operating Temperature: -55ºC to +125ºC Material: Glass Body/Nickel Plated Brass Caps Lead Wire Ø0.65mm - < 10A Ø0.8mm - 10A ~ 15A Ø1.0mm - > 15A Packaging: TSD 1000 pcs; TSD-P 500 pcs per box. Note: All specifications subject to change without notice. Rev H 12/2017 - Page: 1/2 Code: H01-01H Type TSD Time-Delay Glass Tube Fuse 5 x 20 mm www.optifuse.com (619) 593-5050 Part Number TSD TIME CURRENT CURVES Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Glass Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Glass Fuse device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev H 12/2017 - Page: 2/2 Code: H01-01H
TSD-250MA 价格&库存
很抱歉,暂时无法提供与“TSD-250MA”相匹配的价格&库存,您可以联系我们找货
