X4BD130LTI
Rev A
Impedance Matched Ultra Low Profile 0603 Balun
For TI AFE7950 and ADC12DJ5200RF chipsets
Description:
The X4BD130LTI is an ultra-small low profile balanced to unbalanced
transformer designed specifically for Texas Instruments AFE7950 and
ADC12DJ5200RF chipsets. The X4BD130LTI is available on tape and
reel for pick and place high volume manufacturing.
All of the Xinger components are constructed from ceramic filled PTFE
composites, which possess excellent electrical and mechanical
stability. All parts have been subjected to rigorous qualification testing
and units are 100% RF tested. Produced in an ENIG final finish.
Electrical Specifications**
Features:
• 9200-16150 MHz
• 50 Ohm to 2 x50 Ohm
• 5G Applications
• Very Low Loss
• Tight Amplitude
Balance
• Input to Output DC
Isolation
• Production Friendly
• Tape and Reel
• Non-conductive Surface
• RoHS Compliant
• Halogen Free
Frequency
Port
Impedance
Insertion
Loss
Return
Loss
Amplitude
Balance
MHz
Unbalanced :
Balanced
dB Max
dB Min
dB Max
9200-14000
50:100
0.7
18
± 1.0
14000-16150
50:100
1.0
16
± 1.5
Phase
Balance
CMRR
Power
Degrees
dB Max
±9
Avg. CW
Watts @105oC
Operating
Temp.
± 12
16
ºC
1
-55 to +140
1
-55 to +140
**Specification based on performance of unit properly installed on a TTM test board with small signal applied.
*Specifications subject to change without notice. Refer to parameter definitions for details.
Mechanical Outline:
1
X4BD130LTI
Rev A
Insertion Loss and Power Derating Curves:
Insertion Loss Derating:
The insertion loss, at a given frequency, of a group of
Balun is measured at 25°C and then averaged. The
measurements are performed under small signal
conditions (i.e. using a Vector Network Analyzer). The
process is repeated at -55°C and 140°C. A best-fit line
for the measured data is computed and then plotted
from -55°C to 140°C.
Power Derating:
The power handling and corresponding power
derating plots are a function of the thermal
resistance, mounting surface temperature (base
plate temperature), maximum continuous operating
temperature of the Balun, and the thermal insertion
loss. The thermal insertion loss is defined in the
Power Handling section of the data sheet.
As the mounting interface temperature approaches
the maximum continuous operating temperature,
the power handling decreases to zero.
If mounting temperature is greater than 105°C,
Xinger Balun will perform reliably as long as the
input power is derated to the curve above.
2
X4BD130LTI
Rev A
Typical Performance: 9200 MHz to 16150 MHz
3
X4BD130LTI
Rev A
Definition of Measured Specifications:
Parameter
Definition
Return Loss
The impedance match at
the single ended port.
Differential Port
Return Loss
Insertion Loss
Phase Imbalance
the differential port.
Power loss from common
mode
to
differential
mode.
The difference in phase
angle between the two
differential ports, offset
by 180 deg.
Amplitude
Imbalance
The ratio of the power at
differential ports.
Common Mode
Rejection Ratio
The ratio of powers of the
differential gain to the
common-mode gain.
Mathematical Representation
𝑅𝑅𝑅𝑅 = 20𝐿𝐿𝐿𝐿𝐿𝐿10 (S11 )
𝑅𝑅𝑅𝑅𝑅𝑅 = 20𝐿𝐿𝐿𝐿𝐿𝐿10 |0.5 ∗ (S22 − S23 − S32 + S33 )|
𝐼𝐼𝐼𝐼𝐼𝐼 = 20𝐿𝐿𝐿𝐿𝐿𝐿10 (0.707 ∗ (S21 − S31 ))
𝑃𝑃B = (Phase(S21 ) − Phase(S31 )) − 180°
AB = 20𝐿𝐿𝐿𝐿𝐿𝐿10 |
S21
S31
CMRR = ±20𝐿𝐿𝐿𝐿𝐿𝐿10 (S21 +S31 )/(S21 −S31 )
Peak Power Handling:
High-Pot testing of these components during the qualification procedure resulted in a minimum breakdown
voltage of 1Kv (minimum recorded value). This voltage level corresponds to a breakdown resistance capable
of handling at least 12dB peaks over average power levels, for very short durations. The breakdown location
consistently occurred across the pads and the ground bar (see illustration below). The breakdown levels at
these points will be affected by any contamination in the gap area around these pads. These areas must be
kept clean for optimum performance. It is recommended that the user test for voltage breakdown under the
maximum operating conditions and over worst case modulation induced power peaking. This evaluation should
also include extreme environmental conditions (such as high humidity).
4
X4BD130LTI
Rev A
Packaging and Ordering Information:
Parts are available in reel and are packaged per EIA 481. Parts are oriented in tape and reel as shown
below. Minimum order quantities are 4000 per reel.
Contact us:
rf&s_support@ttm.com
5
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Anaren:
X4BD130LTI
很抱歉,暂时无法提供与“X4BD130LTI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+192.00240
- 30+183.14640
- 国内价格 香港价格
- 1+151.055561+19.62135
- 10+131.4172710+17.07044
- 25+124.6004525+16.18497
- 100+115.25401100+14.97091
- 250+109.66028250+14.24432
- 500+105.71347500+13.73165
- 国内价格 香港价格
- 4000+95.209214000+12.36720
