ODIN-W262-00B
ODIN-W262-00B
    U-BLOX(优北罗)
    SMD52模块
    MOD IOT GATEWAY BT WLAN
ODIN-W262-00B 数据手册
ODIN-W2 series Stand-alone multiradio modules with Wi-Fi and Bluetooth Data Sheet Abstract This technical data sheet describes the ODIN-W2 series short range multiradio modules with Wi-Fi and Bluetooth dual-mode (Classic Bluetooth v2.1+EDR and Bluetooth Low Energy v4.0). The ODIN-W2 is a compact yet powerful stand-alone multiradio module designed for Internet-of-Things applications in the compact ODIN form factor. The Wi-Fi support conforms to IEEE 802.11a/b/g/n, and has support for dual-band 2.4 GHz and 5 GHz operation and 2×2 MIMO (2.4 GHz). www.u-blox.com UBX-14039949 - R12 ODIN-W2 series - Data Sheet Document Information Title ODIN-W2 series Subtitle Stand-alone multiradio modules with Wi-Fi and Bluetooth Document type Data Sheet Document number UBX-14039949 Revision and date R12 30-Mar-2017 Disclosure restriction Product Status Corresponding content status Functional Sample Draft For functional testing. Revised and supplementary data will be published later. In Development / Prototype Objective Specification Target values. Revised and supplementary data will be published later. Engineering Sample Advance Information Data based on early testing. Revised and supplementary data will be published later. Initial Production Early Prod. Information Data from product verification. Revised and supplementary data may be published later. Mass Production / End of Life Production Information Final product specification. This document applies to the following products: Product name Type number Firmware version PCN reference Product status ODIN-W260 ODIN-W260-00B-00 ODIN-W260-01B-00 1.0.0 2.0.0 N/A Mass Production ODIN-W260-01B-01 ODIN-W260-03B-00 ODIN-W262-00B-00 2.0.1 2.0.2 3.0.0 3.0.1 4.0.0 1.0.0 N/A Mass Production ODIN-W262-01B-00 2.0.0 ODIN-W262-01B-01 2.0.1 2.0.2 3.0.0 3.0.1 4.0.0 ODIN-W260-02B-00 ODIN-W262 ODIN-W262-02B-00 ODIN-W262-03B-00 u-blox reserves all rights to this document and the information contained herein. Products, names, logos and designs described herein may in whole or in part be subject to intellectual property rights. Reproduction, use, modification or disclosure to third parties of this document or any part thereof without the express permission of u-blox is strictly prohibited. The information contained herein is provided “as is” and u-blox assumes no liability for the use of the information. No warranty, either express or implied, is given, including but not limited, with respect to the accuracy, correctness, reliability and fitness for a particular purpose of the information. This document may be revised by u-blox at any time. For most recent documents, visit www.u-blox.com. Copyright © 2017, u-blox AG. u-blox® is a registered trademark of u-blox Holding AG in the EU and other countries. ARM® is the registered trademark of ARM Limited in the EU and other countries. UBX-14039949 - R12 Page 2 of 42 ODIN-W2 series - Data Sheet Contents Contents.............................................................................................................................. 3 1 Functional description.................................................................................................. 6 1.1 Overview .............................................................................................................................................. 6 1.2 1.3 Applications .......................................................................................................................................... 6 Product features ................................................................................................................................... 6 1.4 Block diagram....................................................................................................................................... 7 1.5 1.6 Product description ............................................................................................................................... 7 AT command support ........................................................................................................................... 8 1.7 IEEE 802.11d and additional regulatory domains .................................................................................. 8 1.7.1 ODIN-W2 IEEE 802.11d implementation description ...................................................................... 8 1.8 MAC addresses................................................................................................................................... 10 2 Interfaces .................................................................................................................... 11 2.1 Power management ........................................................................................................................... 11 2.1.1 Module supply input (VCC) ......................................................................................................... 11 2.1.2 Digital I/O interfaces supply output (V_INT) .................................................................................. 11 2.2 Antenna interfaces ............................................................................................................................. 11 2.2.1 Antenna connectors and internal antenna ................................................................................... 11 2.3 Data communication interfaces .......................................................................................................... 12 2.3.1 2.3.2 3 4 System functions ........................................................................................................ 14 3.1 3.2 Module power modes ........................................................................................................................ 14 Module reset ...................................................................................................................................... 14 3.3 System IO ........................................................................................................................................... 14 Pin definition .............................................................................................................. 15 4.1 5 UART interface ............................................................................................................................ 12 Ethernet interface ........................................................................................................................ 12 Pin assignment ................................................................................................................................... 15 Electrical specification ................................................................................................ 18 5.1 Absolute maximum ratings ................................................................................................................. 18 5.1.1 Maximum ESD ............................................................................................................................. 18 5.2 Operating conditions .......................................................................................................................... 18 5.2.1 5.2.2 Temperature range ...................................................................................................................... 18 Power supply ............................................................................................................................... 18 5.2.3 I/O DC characteristics .................................................................................................................. 19 5.2.4 5.2.5 Reset characteristics .................................................................................................................... 19 LPO clock .................................................................................................................................... 19 5.2.6 Universal asynchronous serial interface (UART) ............................................................................ 19 5.3 Power consumption ............................................................................................................................ 20 UBX-14039949 - R12 Contents Page 3 of 42 ODIN-W2 series - Data Sheet 5.3.1 5.3.2 General power consumption ....................................................................................................... 20 Wi-Fi 2.4 GHz power consumption .............................................................................................. 20 5.3.3 Wi-Fi 5 GHz power consumption ................................................................................................. 20 5.3.4 5.3.5 Classic Bluetooth power consumption ......................................................................................... 20 Bluetooth Low Energy (BLE) power consumption ......................................................................... 21 5.4 6 5.4.1 5.4.2 Wi-Fi receiver characteristics 2.4 GHz .......................................................................................... 21 Wi-Fi receiver characteristics 5 GHz ............................................................................................. 21 5.4.3 Wi-Fi transmitter characteristics 2.4 GHz ..................................................................................... 21 5.4.4 5.4.5 Wi-Fi transmitter characteristics 5 GHz ........................................................................................ 22 Classic Bluetooth receiver characteristics ..................................................................................... 22 5.4.6 Bluetooth Low Energy receiver sensitivity ..................................................................................... 22 5.4.7 5.4.8 Classic Bluetooth transmitter characteristics ................................................................................ 22 Bluetooth Low Energy transmitter characteristics ......................................................................... 22 Mechanical specifications .......................................................................................... 23 6.1 6.2 7 RF characteristics ................................................................................................................................ 21 Dimensions ......................................................................................................................................... 23 Module weight ................................................................................................................................... 24 Qualification and approvals ...................................................................................... 25 7.1 Compliance with RoHS directive ......................................................................................................... 25 7.2 European Union regulatory compliance .............................................................................................. 25 7.3 7.4 Safety compliance............................................................................................................................... 25 FCC and IC Compliance ...................................................................................................................... 25 7.4.1 IC compliance.............................................................................................................................. 25 7.4.2 7.4.3 Conformité aux normes d’IC ....................................................................................................... 25 FCC statement ............................................................................................................................ 26 7.4.4 Labeling requirements for end product ........................................................................................ 27 7.5 7.6 Japan radio equipment compliance ..................................................................................................... 28 SRRC China Radio Transmission Equipment Type Approval ................................................................. 28 7.6.1 ODIN-W262 labeling requirements for end product ..................................................................... 28 7.7 NCC Taiwan compliance ..................................................................................................................... 29 7.7.1 Taiwan NCC Warning Statement ................................................................................................. 29 7.7.2 ODIN-W260 labeling requirements for end product ..................................................................... 29 7.7.3 ODIN-W262 labeling requirements for end product ..................................................................... 29 7.8 Korean KCC certification .................................................................................................................... 30 7.9 8 Brazil compliance ................................................................................................................................ 30 7.10 7.11 Australia and New Zealand regulatory compliance .......................................................................... 30 South Africa regulatory compliance................................................................................................. 31 7.12 Bluetooth qualification information ................................................................................................. 31 Antennas..................................................................................................................... 32 8.1 Antenna accessories ........................................................................................................................... 32 8.2 Approved antennas ............................................................................................................................ 33 8.2.1 Single band antennas .................................................................................................................. 33 UBX-14039949 - R12 Contents Page 4 of 42 ODIN-W2 series - Data Sheet 8.2.2 9 Dual-band antennas .................................................................................................................... 35 Product handling and soldering ................................................................................ 36 9.1 Packaging ........................................................................................................................................... 36 9.2 Packaging ........................................................................................................................................... 36 9.2.1 Reels ........................................................................................................................................... 36 9.2.2 Tapes .......................................................................................................................................... 36 9.3 9.4 Moisture sensitivity levels .................................................................................................................... 37 Reflow soldering ................................................................................................................................. 37 9.5 ESD precautions.................................................................................................................................. 37 10 Labeling and ordering information........................................................................... 38 10.1 Explanation of codes ....................................................................................................................... 39 10.2 Ordering information ...................................................................................................................... 39 Appendix .......................................................................................................................... 40 Glossary ............................................................................................................................ 40 Related documents........................................................................................................... 41 Revision history ................................................................................................................ 41 Contact .............................................................................................................................. 42 UBX-14039949 - R12 Contents Page 5 of 42 ODIN-W2 series - Data Sheet 1 Functional description 1.1 Overview The ODIN-W2 series is a highly integrated multiradio module developed by u-blox for integration in demanding, reliable devices such as those needed for industrial and medical applications. The module is built around a multiradio chip, which includes dual-band Wi-Fi and dual-mode Bluetooth (Classic Bluetooth v2.1+EDR and Bluetooth Low Energy v4.0). The Wi-Fi support conforms to IEEE 802.11a/b/g/n, and has support for dual-band 2.4 GHz and 5 GHz operation and 2.4 GHz 2×2 MIMO. The high performance ODIN-W2 series module is available in different versions (see Product features). The module has a small form factor and the interface layout is the same as previous Bluetooth and Wi-Fi modules from u-blox in the 15x22 mm ODIN form factor. The module is complete with embedded driver, stack and application for wireless data transfer and AT-command configuration. 1.2 Applications • • • • • • Internet of Things (IoT) Wi-Fi and Bluetooth networks Medical and industrial networking Access to laptops, mobile phones, and similar consumer devices Home/building automation Ethernet/Wireless Gateway 1.3 Product features Table 1: Key features of ODIN-W2 series UBX-14039949 - R12 Functional description Page 6 of 42 ODIN-W2 series - Data Sheet 1.4 Block diagram The block diagram of the ODIN-W2 series is shown below: Figure 1: Block diagram of ODIN-W2 series 1.5 Product description The ODIN-W2 series module supports Wi-Fi, classic Bluetooth and Bluetooth Low Energy (dual-mode / Bluetooth Smart Ready). The Wi-Fi support conforms to IEEE 802.11a/b/g/n, and has support for dual-band 2.4 GHz and 5 GHz operation and 2×2 MIMO (2.4 GHz). UBX-14039949 - R12 Functional description Page 7 of 42 ODIN-W2 series - Data Sheet Wi-Fi *** IEEE 802.11a/b/g/n IEEE 802.11d/e/i/h**** ODIN-W260: 2X2 MIMO***(2.4 GHz only) Band support Station mode: 2.4 GHz, channel 1-13* 5 GHz, channel 36-165* Access Point mode: 2.4 GHz, channel 1-11 5 GHz, channel 36-48 Maximum conducted output power 15 dBm Classic Bluetooth Bluetooth Low Energy Classic Bluetooth v2.1+EDR Maximum number of slaves: 7 Bluetooth profiles: SPP, DUN, GATT and PAN Band support 2.4 GHz, 79 channels Bluetooth 4.0 BLE dual-mode Maximum conducted output power 11 dBm Maximum conducted output power 7 dBm Maximum radiated output power Maximum radiated output power 18 dBm EIRP** 14 dBm EIRP** Conducted sensitivity Conducted sensitivity -90 dBm 2.4 GHz: -95 dBm 5 GHz: -90 dBm Data rates: Data rates: 1 / 2 / 3 Mbit/s IEEE 802.11b: 1 / 2 / 5.5 / 11 Mbit/s IEEE 802.11a/g: 6 / 9 / 12 / 18 / 24 / 36 / 48 / 54 Mbit/s IEEE 802.11n SISO***: 6.5 / 13 / 19.5 / 26 / 39 / 52 / 58.5 / 65 Mbit/s IEEE 802.11n 2x2 MIMO***: 13 / 26 / 39 / 52 / 78 / 104 / 117 / 130 Mbit/s * Maximum, supports 802.11d and depends on region. ** RF power including maximum antenna gain (3 dBi). *** Planned feature. **** DFS client only. Band support 2.4 GHz, 40 channels Maximum radiated output power 10 dBm EIRP** Conducted sensitivity -95 dBm Data rates: 1 Mbit/s Table 2: ODIN-W2 series Wi-Fi and Bluetooth characteristics 1.6 AT command support The ODIN-W2 series modules support AT commands as described in the u-blox Short Range AT Commands Manual [1]. See also the s-center software, which is an easy-to-use tool from u-blox for evaluating, and configuration of u-blox Short Range modules. The s-center tool is available for download on the www.u-blox.com website. 1.7 IEEE 802.11d and additional regulatory domains The ODIN-W2 series modules support IEEE 802.11d. IEEE 802.11d is an amendment to the IEEE 802.11 specification that adds support for "additional regulatory domains". IEEE 802.11d allows ODIN-W2 based devices to self-configure and operate according to the regulations of the country in which they operate. Its parameters include country name, channel quantity and maximum transmission level. The country information feature simplifies the creation of 802.11 wireless access points and client devices that meet the different regulations enforced in various parts of the world. 1.7.1 ODIN-W2 IEEE 802.11d implementation description When ODIN-W2 is used as a Wi-Fi station, the scan is used to detect which regulatory domain it is currently in. Passive scan is used for channels that are not available in all regulatory domains. The device supports the following three domains, where WORLD means all channels that are supported both by FCC, ETSI and most other countries in the world: • • WORLD FCC UBX-14039949 - R12 Functional description Page 8 of 42 ODIN-W2 series - Data Sheet • ETSI See Table 3 for detailed information on channels that are supported in the different regulatory domains. The state transition diagram below (Figure 2) describes the algorithm for selecting the current regulatory domain. Entry start scan Do start scan every hour Scan complete Three or more ETSI AP found and no FCC AP found ETSI Scan complete FCC found WORLD Scan complete No or both FCC and ETSI AP found WORLD-FINAL Scan complete FCC AP found and no ETSI AP found FCC Scan complete ETSI found Figure 2: ODIN-W2 series IEEE 802.11d state transition diagram Initial regulatory domain is WORLD. At start up a scan is initiated to detect beacons containing country information IEs. If at least one scan result contains country information indicating FCC and no country information indicates ETSI, then the regulatory domain is set to FCC. If at least three scan results contain country information indicating ETSI and no country information indicates FCC, then the regulatory domain is set to ETSI. If the scan result contains country information indicating both FCC and country information indicating ETSI, then the regulatory domain is set to WORLD. In the state transition diagram this is the state WORLD_FINAL. This state will not be exited until the device is reset. A new scan is performed every hour to update the regulatory domain. If the current regulatory domain is ETSI and at least one scan result contains country information indicating FCC and then the regulatory domain is set to WORLD. In the state transition diagram this is the state WORLD-FINAL. This state is will not be exited until the device is reset. If the current regulatory domain is FCC and at least one scan result contains country information indicating ETSI and then the regulatory domain is set to WORLD. In the state transition diagram this is the state WORLD-FINAL. This state is will not be exited until the device is reset. At restart of the device the algorithm is restarted. It is not possible to override the algorithm described by reconfiguration the device. UBX-14039949 - R12 Functional description Page 9 of 42 ODIN-W2 series - Data Sheet Regulatory Domain Band WORLD 2.4 GHz 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 U-NII-1 36, 40, 44, 48 U-NII-2 52, 56, 60, 64 U-NII-2e 100, 104, 108, 112, 116, 132, 136, 140 U-NII-3 - 2.4 GHz 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 ETSI FCC Tx Channels U-NII-1 36, 40, 44, 48 U-NII-2 52, 56, 60, 64 U-NII-2e 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140 U-NII-3 149, 153, 157, 161, 165 2.4 GHz 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 U-NII-1 36, 40, 44, 48 U-NII-2 52, 56, 60, 64 U-NII-2e 100, 104, 108, 112, 116, 132, 136, 140 U-NII-3 149, 153, 157, 161, 165 Table 3: Channel list for supported regulatory domains The maximum output power is reduced on some channels depending on regulatory requirements. For example, frequency band edge requirements can limit the output power on channels close to band edges. 1.8 MAC addresses The ODIN-W2 module series has four unique consecutive MAC addresses reserved for each module, from which the three first addresses are stored in the configuration memory during production. The first Bluetooth MAC address is available in the Data Matrix on the label (see section 10.1). The last MAC address is not stored in the configuration memory but is reserved for usage with the module. MAC address Assignment Last bits of MAC address Example Module 1, address 1 Bluetooth 00 D4:CA:6E:90:04:90 Module 1, address 2 Wi-Fi 01 D4:CA:6E:90:04:91 Module 1, address 3 RMII/Ethernet 10 D4:CA:6E:90:04:92 Module 1, address 4 Reserved 11 D4:CA:6E:90:04:93 Module 2, address 1 Bluetooth 00 D4:CA:6E:90:04:94 Module 2, address 2 Wi-Fi 01 D4:CA:6E:90:04:95 Module 2, address 3 RMII/Ethernet 10 D4:CA:6E:90:04:96 Module 2, address 4 Reserved 11 D4:CA:6E:90:04:97 Table 4: Example MAC address assignment for two modules UBX-14039949 - R12 Functional description Page 10 of 42 ODIN-W2 series - Data Sheet 2 Interfaces 2.1 Power management 2.1.1 Module supply input (VCC) The ODIN-W2 series modules must be supplied through the VCC pin by a DC power supply. Voltage must be stable, because during operation the current drawn from VCC can vary significantly based on the power consumption profile of the Bluetooth/Wi-Fi technologies. 2.1.2 Digital I/O interfaces supply output (V_INT) The ODIN-W2 series modules provide a 1.8 V supply rail output on the V_INT pin, which is internally generated when the module is powered on. The same voltage domain is used internally to supply the generic digital interfaces of the modules. The V_INT supply output can be used instead of an external discrete regulator. See the Electrical specification section for maximum output current. 2.2 Antenna interfaces The following two different antenna options are available in the ODIN-W2 series: • • ODIN-W260 equipped with dual U.FL. coaxial connectors for external antennas. Different types of external antennas are available and can be used. ODIN-W262 equipped with an integrated dual-band antenna While mounting the unit, ensure that it does not interfere with radio communication. The ODIN-W262 equipped with an internal surface mounted antenna should not be mounted in a metal enclosure. No metal casing or plastics using metal flakes should be used. Avoid metallic based paint or lacquer. See the Antennas section for information on the external antennas that can be used and for other RF and antenna design advices. For more info about antenna integration, see ODIN-W2 series System Integration Manual [2]. 2.2.1 Antenna connectors and internal antenna The ODIN-W260 module has two RF antenna U.FL. coaxial connectors with a characteristic impedance of 50 Ω. The main antenna connector supports both Bluetooth and dual-band Wi-Fi. The second (MIMO) antenna connector adds support for 2x2 MIMO 2.4 GHz single band Wi-Fi. The ODIN-W262 module has an internal dual-band PIFA antenna and supports Bluetooth and dual-band Wi-Fi (SISO). UBX-14039949 - R12 Interfaces Page 11 of 42 ODIN-W2 series - Data Sheet Figure 3: ODIN-W260 with connectors for external antennas and the ODIN-W262 with an internal antenna 2.3 Data communication interfaces The ODIN-W2 series provides several data communication interfaces which are described below. 2.3.1 UART interface The ODIN-W2 series modules include a 6-wire UART for communication with an application host processor (AT commands, Data communication and firmware upgrades). The following UART signals are available: • Data lines (RXD as input, TXD as output) • Hardware flow control lines (CTS as input, RTS as output) • Link status (DTR as output, DSR as input) It is recommended to use CMOS compatible signal levels. See u-blox Short Range AT Commands Manual [1] and ODIN-W2 series System Integration Manual [2] for more information about the UART interface. 2.3.2 Ethernet interface The ODIN-W2 series modules include an integrated Ethernet MAC to communicate with other networked nodes over a shared medium. It supports 10/100 Mbit/s communication and can operate in both full- and half-duplex (CSMA/CD). The Ethernet interface includes: • • RMII either for MAC to PHY or Ethernet MAC to MAC communication. SMI for PHY configuration UBX-14039949 - R12 Interfaces Page 12 of 42 ODIN-W2 series - Data Sheet The IO voltage of the ODIN-W2 is 1.8 V, which means that the RMII interface operates outside the RMII specification v1.2. If the RMII is to be connected to a PHY circuit, then that circuit must support 1.8 V operation. If a direct RMII to RMII connection is used, then a level shifter might be needed depending on the selected host. The selected hardware setup must be verified on the application board to guarantee operation. 2.3.2.1 RMII The RMII uses 7 signals in total. The interface requires an external 50 MHz clock source either from a compatible PHY chip or an external oscillator. The ODIN-W2 module cannot provide this clock signal by itself. 2.3.2.2 SMI (MDC/MDIO management interface) The two-wire SMI is used to configure the PHY chips. It uses a clock line and a data line to clock data to and from the PHY chips registers. UBX-14039949 - R12 Interfaces Page 13 of 42 ODIN-W2 series - Data Sheet 3 System functions 3.1 Module power modes The ODIN-W2 series module does not have an internal low power oscillator (LPO) which is required for low power modes. An external 32.768 kHz LPO signal can be supplied externally via the LPO_CLK pin if low power modes are required. 3.2 Module reset The ODIN-W2 series modules can be reset (rebooted) in one of the following ways: • • Low level on the RESET_N pin, which is normally set high by an internal pull-up. This causes “hardware” reset of the module. The RESET_N line should be driven by an open drain, open collector or contact switch. Using a reset AT command (see the u-blox Short Range AT Commands Manual [1]). This causes “software” reset of the module. 3.3 System IO The module has the following six different configurable IOs that can be used to indicate different system states or to be used as inputs, thus setting the module in different states: • SWITCH_0 • RED • GREEN/SWITCH_1 • BLUE • UART_DTR • UART_DSR See the Pin definition section for more information on the separate IOs. For more information on the use and configuration of the System IOs, see the u-blox Short Range AT Commands Manual [1]. UBX-14039949 - R12 System functions Page 14 of 42 ODIN-W2 series - Data Sheet 4 Pin definition 4.1 Pin assignment Figure 4: ODIN-W2 series pin assignment The signals are available on castellation pads on the edge of the PCB. All non-filled round pads are GND pads. Black circular pads are test and production points that should not be used. RSVD = Reserved, do not connect. UBX-14039949 - R12 Pin definition Page 15 of 42 ODIN-W2 series - Data Sheet No Name A1 RESET_N I External reset input. Internal active pull-up to V_INT. A2 V_INT O Regulated output of the internal I/O voltage. 1.8V, maximum output current 100mA. The maximum output current can be limited by the internal current consumption of the V_INT rail. See the Power consumption section. A3 GND N/A Ground All GND pads must be connected to ground. A4 VCC I Module power supply. 3.0 - 3.6 V power supply. A5 UART_DTR O UART Data Terminal Ready. Active low. Can also be used as a System IO. See the System IO section for more information. See the u-blox Short Range AT Commands Manual [1] for more information about the pin functionality. A6 SWITCH_0 I Connect on external signal. Active low. A secondary function is that the module will restore all factory settings if both the SWITCH_1 and SWITCH_0 signals are low during start up. See the u-blox Short Range AT Commands Manual [1] for more information about the pin functionality. A7 RED O Logic Red LED Signal. Active low. See the System IO section for more information. See the u-blox Short Range AT Commands Manual [1] for more information about the pin functionality. A8 GREEN/ SWITCH_1 O/I This signal is multiplexed: GREEN: Logic Green LED Signal. SWITCH_1: Default Serial Settings. Active low. The GREEN signal is not valid until 500ms after startup. See the System IO section for more information. If the level on this pin is pulled-down during start-up the unit goes back to default serial settings. The SWITCH_1 input is only active during the first 500ms after startup. The module will restore all factory settings if both the SWITCH_1 and SWITCH_0 signals are low during start up. See the u-blox Short Range AT Commands Manual [1] for more information about the pin functionality. A9 BLUE O Logic Blue LED Signal. Active low. See the System IO section for more information. See the u-blox Short Range AT Commands Manual [1] for more information about the pin functionality. A10 UART_CTS I UART Clear To Send, Hardware flow control. Active low. A11 UART_TXD O UART Transmit. A12 UART_RTS O UART Request To Send, Hardware flow control. A13 UART_RXD I UART Receive. A14 RSVD N/A Reserved pin. Leave unconnected. A15 RSVD N/A Reserved pin. Leave unconnected. A16 RSVD N/A Reserved pin. Leave unconnected. A17 RSVD N/A Reserved pin. Leave unconnected. A18 UART_DSR UART Data Set Ready. Active low. Can also be used as a System IO. See the System IO section for more information. See the u-blox Short Range AT Commands Manual [1] for more information about the pin functionality. B1 RSVD N/A Reserved pin. Leave unconnected. B2 RSVD N/A Reserved pin. Leave unconnected. B3 RSVD N/A Reserved pin. Leave unconnected. B4 RSVD N/A Reserved pin. Leave unconnected. UBX-14039949 - R12 I/O I Description Remarks Active low. Pin definition Page 16 of 42 ODIN-W2 series - Data Sheet No Name I/O Description Remarks B5 RSVD N/A Reserved pin. Leave unconnected. B6 RSVD N/A Reserved pin. Leave unconnected. B7 RSVD N/A Reserved pin. Leave unconnected. B8 RSVD N/A Reserved pin. Leave unconnected. C1 GND N/A Ground All GND pads must be connected to ground. C2 RSVD N/A Reserved pin. Leave unconnected. C3 GND N/A Ground All GND pads must be connected to ground. C4 GND N/A Ground All GND pads must be connected to ground. C5 RSVD N/A Reserved pin. Leave unconnected. C6 RSVD N/A Reserved pin. Leave unconnected. C7 GND N/A Ground All GND pads must be connected to ground. C8 RSVD N/A Reserved pin. Leave unconnected. C9 RSVD N/A Reserved pin. Leave unconnected. C10 RSVD N/A Reserved pin. Leave unconnected. C11 RSVD N/A Reserved pin. Leave unconnected. C12 RSVD N/A Reserved pin. Leave unconnected. C13 RSVD N/A Reserved pin. Leave unconnected. C14 RMII_MDC O Management Interface Clock output According to RMII specification v1.2 with the exception that voltage level is 1.8 V. C15 RMII_MDIO I/O Management Interface Data I/O An external pull-up resistor is required on the bidirectional data signal. According to RMII specification v1.2 with the exception that voltage level is 1.8 V. C16 LPO_CLK Low Power Oscillator clock input The module requires an external 32.768 kHz clock for low power modes. Leave this pin unconnected if not used as LPO clock input. C17 RSVD N/A Reserved pin. Leave unconnected. C18 RSVD N/A Reserved pin. Leave unconnected. D1 RMII_TXD0 O Transmit Data output 0 According to RMII specification v1.2 with the exception that voltage level is 1.8 V. D2 RMII_TXD1 O Transmit Data output 1 According to RMII specification v1.2 with the exception that voltage level is 1.8 V. D3 RMII_TXEN O Transmit Enable output Active high. According to RMII specification v1.2 with the exception that voltage level is 1.8 V. D4 RMII_CRSDV I Carrier Sense/Receive Data Valid input Carrier Sense and Receive Data Valid signals are multiplexed together, multiplexing scheme varies with implementation. According to RMII specification v1.2 with the exception that voltage level is 1.8 V. D5 RMII_RXD0 I Receive Data input 0 According to RMII specification v1.2 with the exception that voltage level is 1.8 V. D6 RMII_RXD1 I Receive Data input 1 According to RMII specification v1.2 with the exception that voltage level is 1.8 V. D7 GND Ground All GND pads must be connected to ground. D8 RMII_REFCLK Reference Clock input Continuous 50 MHz reference clock input. According to RMII specification v1.2 with the exception that voltage level is 1.8 V. I N/A I Table 5: ODIN-W2 series pin-out UBX-14039949 - R12 Pin definition Page 17 of 42 ODIN-W2 series - Data Sheet 5 Electrical specification Stressing the device above one or more of the ratings listed in the Absolute maximum ratings section may cause permanent damage. These are stress ratings only. Operating the module at these or at any conditions other than those specified in the Operating conditions section should be avoided. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 5.1 Absolute maximum ratings Symbol Description VCC Module supply voltage GDI Generic digital interfaces ERS External reset signal Condition Min Input DC voltage at VCC pin Input DC voltage at Generic digital interfaces pins Input DC voltage at RESET_N pin Maximum * -0.3 5.5 -0.3 2.2 -0.3 5.2 Unit V V V Tstg Storage temperature -40 +85 ºC * 5.5 V up to 10 s cumulative in 7 years, 5 V cumulative to 250 s, 4.8 V cumulative to 2.33 years - all includes charging dips and peaks. Table 6: Absolute maximum ratings 5.1.1 Maximum ESD Parameter Maximum Unit Remarks ESD immunity for antenna connector shielding 6000 V Contact Discharge according to IEC 61000-4-2 8000 1000 V V Air Discharge according to IEC 61000-4-2 Human Body Model according to ANSI/ESDA/JEDEC JS-001 250 V Charged Device Model according to EIA-JEDEC JESD22-C101E ESD sensitivity for all pins Table 7: Maximum ESD ratings 5.2 Operating conditions Operating condition ranges define those limits within which the functionality of the device is guaranteed. 5.2.1 Temperature range Parameter Min Maximum Unit Storage temperature Operating temperature -40 -40 +85 +85 ºC ºC Table 8: Temperature range 5.2.2 Power supply Symbol Parameter Min Typ Maximum Unit VCC V_INT Supply voltage Output voltage 3.00 1.76 3.30 1.80 3.60 1.84 V V IVCC IV_INT Supply voltage current drain1 Output voltage current drain - - 1.0 100 A mA Table 9: Power supply voltage 1 See Power consumption section for detailed information. UBX-14039949 - R12 Electrical specification Page 18 of 42 ODIN-W2 series - Data Sheet 5.2.3 I/O DC characteristics Symbol Parameter VIL LOW level input voltage VIH VOL HIGH level input voltage LOW level output voltage VOH HIGH level output voltage IIO CIO I/O pin sink and source current I/O pin input capacitance RPU Internal active pull-up resistance RPD Internal active pull-down resistance * Min Typ Maximum Unit 0 0.5 V 1.31 1.8 0 2.0 0.4 V V 1.34 1.8 4.0* mA pF V 5 All IO pins except for UART_RXD 30 40 50 kΩ UART_RXD 8 11 15 kΩ 30 40 50 kΩ Maximum Unit 0.5 V V 8.0 mA is possible but the output voltage level is not guaranteed. Table 10: I/O DC characteristics 5.2.4 Reset characteristics Symbol Parameter VIL(RESET_N) VIH(RESET_N) RESET_N Input low level voltage RESET_N Input high level voltage Vhys(RESET_N) RPU(RESET_N) RESET_N Schmitt trigger voltage hysteresis Internal RESET_N pull-up resistance CRESET_N VF(RESET_N) Internal RESET_N capacitance RESET_N Input filtered pulse Conditions Min Typ 1.3 200 mV 8 kΩ 100 nF ns 100 Table 11: Reset characteristics 5.2.5 LPO clock The ODIN-W2 series module does not have an internal low power oscillator (LPO) required for low power modes. An LPO can be supplied from an external oscillator if low power modes are required. Symbol Parameter LPO32.768kHz Input clock frequency Input slow clock accuracy (Initial + temp + aging) Input transition time Tr/Tf -10% to 90% Tr/Tf VIH VIL Min Typ Maximum 32.768 kHz ±150 Frequency input duty cycle 20 Input voltage limits (Square wave, DC-coupled) 1.31 0 50 Input capacitance Unit ppm 100 ns 80 % 1.8 0.5 V V 10 pF Table 12: External LPO clock characteristics 5.2.6 Universal asynchronous serial interface (UART) Symbol Parameter Min Typ Maximum Unit fbaud Baud rate 2400 115200 5.25M bit/s Table 13: UART characteristics UBX-14039949 - R12 Electrical specification Page 19 of 42 ODIN-W2 series - Data Sheet 5.3 Power consumption 5.3.1 General power consumption VCC = 3.3 V, TA = 25 °C unless otherwise specified. Symbol IDD Parameter Conditions Average Peak Unit Supply current Reset Startup Idle, not connected, default configuration Idle, not connected, no running services** Stop mode*** 5.2 130 30 30 TBD - 6.0 800* 65 60 TBD 1.0 mA mA mA mA mA A IDD_MAXIMUM Absolute maximum current drain * Wi-Fi and Bluetooth calibration during the startup phase causes large short current peaks. ** No server running and Bluetooth Connectable and Discoverable turned off. *** Feature not supported in the current firmware version. See u-blox Short Range AT Commands manual [1] for more information. Table 14: General current consumption 5.3.2 Wi-Fi 2.4 GHz power consumption VCC = 3.3 V, TA = 25 °C unless otherwise specified. Symbol Parameter Conditions Average Peak Unit IDDW24 Supply current not connected IDDW24_TX Supply current transmitting Scan, 11 channels, 300 ms Idle, Connected DTIM = 1, Tbeacon = 100 ms Idle, Connected DTIM = 5, Tbeacon = 100 ms 802.11b 100 36 32 110 450 100 100 460 mA mA mA mA 802.11g 802.11b 110 110 450 460 mA mA 802.11g 110 460 mA IDDW24_RX Supply current receiving Table 15: Current consumption for Wi-Fi 2.4 GHz 5.3.3 Wi-Fi 5 GHz power consumption VCC = 3.3 V, Tamb = 25 °C Symbol Parameter Conditions Average Peak Unit IDDW5 Supply current not connected Scan, 4 channels, 100 ms Idle, Connected DTIM = 1, Tbeacon = 100 ms Idle, Connected DTIM = 5****, Tbeacon = 100 ms 100 36 32 510 100 100 IDDW5_TX IDDW5_RX Supply current transmitting Supply current receiving 802.11a 802.11a 250 102 650 610 mA mA mA mA mA Table 16: Current consumption for Wi-Fi 5 GHz 5.3.4 Classic Bluetooth power consumption VCC = 3.3 V, Tamb = 25 °C Symbol Parameter Conditions Average Peak Unit IDDBT_NDNC IDDBT_NDC Supply current not connected Not discoverable, Not connectable Not discoverable, Connectable, scan interval = TBD, scan window = TBD Discoverable, Connectable, scan interval = TBD, scan window = TBD 30 30 65 65 mA mA 30 65 mA IDDBT_DC IDDBT_INQ Supply current inquiry IDDBT_IDLE Supply current connected IDDBT_TX1Mb IDDBT_RX1Mb 47 120 mA Idle 32 120 mA Transmitting Receiving 56 46 120 120 mA mA Table 17: Current consumption for classic Bluetooth UBX-14039949 - R12 Electrical specification Page 20 of 42 ODIN-W2 series - Data Sheet 5.3.5 Bluetooth Low Energy (BLE) power consumption VCC = 3.3 V, Tamb = 25 °C Symbol Parameter Conditions IDDBLE_CD_NC Supply current not connected Central device IDDBLE_CD_INQ IDDBLE_PD_NC IDDBLE_PD_ADV IDDBLE_CD_IDLE IDDBLE_CD_TX Peripheral device Supply current connected IDDBLE_CD_RX IDDBLE_PD_IDLE Central device Peripheral device IDDBLE_PD_TX IDDBLE_PD_RX Average Peak Unit Idle 29 65 mA Low Energy Inquiry Idle 48 29 80 65 mA Advertising Idle 29 44 65 100 mA mA Transmitting 45 100 mA Receiving Idle 45 29 100 100 mA mA Transmitting Receiving 30 30 100 100 mA mA mA Table 18: Current consumption for Bluetooth Low Energy (BLE) 5.4 RF characteristics 5.4.1 Wi-Fi receiver characteristics 2.4 GHz VCC = 3.3 V, Tamb = 25 °C Parameter Conditions Antenna port 802.11b, Rate = 1 Mbit/s, PER ≤ 8% MAIN port 802.11b, Rate = 11 Mbit/s, PER ≤ 8% MAIN port 802.11g, Rate = 6 Mbit/s, PER ≤ 10% MAIN port 802.11g, Rate = 54 Mbit/s, PER ≤ 10% MAIN port * Measured conducted on ODIN-W260, measurement tolerance ±1.0 dB. Receive sensitivity Channel / Freq [MHz] 6 / 2437 6 / 2437 6 / 2437 6 / 2437 IEEE limit -76 -76 -82 -65 Channel / Freq [MHz] 36 / 5180 100 / 5500 140 / 5825 36 / 5180 100 / 5500 140 / 5825 IEEE limit -82 -82 -82 -66 -66 -66 Typ* Unit -95 -86 -90 -72 dBm dBm dBm dBm Typ* Unit -90 -90 -90 -72 -72 -72 dBm dBm dBm dBm dBm dBm Table 19: Receiver characteristics for 2.4 GHz Wi-Fi 5.4.2 Wi-Fi receiver characteristics 5 GHz VCC = 3.3 V, Tamb = 25 °C Parameter Conditions Receive sensitivity 802.11a, Rate = 6 Mbit/s, PER ≤ 10% 802.11a, Rate = 48 Mbit/s, PER ≤ 10% * Measured conducted on ODIN-W260, measurement tolerance ±1.0 dB. Table 20: Receiver characteristics for 5 GHz Wi-Fi 5.4.3 Wi-Fi transmitter characteristics 2.4 GHz VCC = 3.3 V, Tamb = 25 °C IEEE EVM EVM* limit Transmitting output 802.11b, Rate = 1 Mbit/s MAIN port -14 -28 power 802.11b, Rate = 11 Mbit/s MAIN port -14 -26 802.11g, Rate = 6 Mbit/s MAIN port -5 -21 802.11g, Rate = 54 Mbit/s MAIN port -25 -29 * Measured conducted on ODIN-W260 with maximum output power, measurement tolerance ±1.0 dB. Regional power limitation can reduce the maximum output power (especially on channels close to band edges). Parameter Conditions Antenna port Typ* Unit 11.2 11.3 14.2 12.1 dBm dBm dBm dBm Table 21: Wi-Fi transmitter characteristics 2.4 GHz UBX-14039949 - R12 Electrical specification Page 21 of 42 ODIN-W2 series - Data Sheet 5.4.4 Wi-Fi transmitter characteristics 5 GHz VCC = 3.3 V, Tamb = 25 °C Channel / IEEE EVM Freq [MHz] limit Transmitting output 802.11a, Rate = 6 Mbit/s 40 / 5180 -5 power 100 / 5500 -5 140 / 5700 -5 802.11a, Rate = 54 Mbit/s 40 / 5180 -25 100 / 5500 -25 140 / 5700 -25 * Measured conducted on ODIN-W260 with maximum output power, measurement tolerance ±1.0 dB. Regional power limitation can reduce the maximum output power (especially on channels close to band edges). Parameter Conditions EVM* Typ* Unit -26 -25 -18 -26 -25 -25 12.8 11.8 13.7 12.7 12.1 13.2 dBm dBm dBm dBm dBm dBm Table 22: Wi-Fi transmitter characteristics 5 GHz 5.4.5 Classic Bluetooth receiver characteristics VCC = 3.3 V, Tamb = 25 °C Parameter Conditions Limit Typ* Rx sensitivity BR 1Mbit, GFSK, BER ≤ 0.1% EDR 2Mbit, π/4-DQPSK, BER ≤ 0.007% -70 -70 -90 -90 EDR 3Mbit, 8DPSK , BER ≤ 0.007% -70 -83 BR 1Mbit, GFSK, BER ≤ 0.1% EDR 2Mbit, π/4-DQPSK, BER ≤ 0.1% -20 -20 -6 -10 dBm dBm -20 -10 dBm Maximum input level * EDR 3Mbit, 8DPSK , BER ≤ 0.1% Measured conducted on ODIN-W260, measurement tolerance ±1.0 dB. Min* Unit dBm dBm dBm Table 23: Classic Bluetooth receiver sensitivity 5.4.6 Bluetooth Low Energy receiver sensitivity VCC = 3.3 V, Tamb = 25 °C Parameter Conditions Rx sensitivity PER ≤ 30.8% PER ≤ 30.8% Maximum input level * Measured conducted on ODIN-W260, measurement tolerance ±1.0 dB. Limit Typ* -70 -10 -95 Min* Unit -6 dBm dBm Table 24: Bluetooth Low Energy receiver sensitivity 5.4.7 Classic Bluetooth transmitter characteristics VCC = 3.3 V, Tamb = 25 °C Parameter Conditions Typ* Max* Unit Transmitting output power BR 1Mbit, GFSK 11.0 11.4 dBm EDR 2Mbit, π/4-DQPSK 6.5 7.0 dBm EDR 3Mbit, 8DPSK 6.5 7.0 dBm Typ* Max* Unit 6.0 7.0 dBm * Measured conducted on ODIN-W260, measurement tolerance ±1.0 dB. Table 25: Bluetooth transmitter output power 5.4.8 Bluetooth Low Energy transmitter characteristics (VCC = 3.3 V, Tamb = 25 °C Parameter Test conditions Transmitting output power * Measured conducted on ODIN-W260, measurement tolerance ±1.0 dB. Table 26: Bluetooth Low Energy transmitter characteristics UBX-14039949 - R12 Electrical specification Page 22 of 42 ODIN-W2 series - Data Sheet 6 Mechanical specifications 6.1 Dimensions Figure 5: Physical dimensions of ODIN-W260 UBX-14039949 - R12 Mechanical specifications Page 23 of 42 ODIN-W2 series - Data Sheet Figure 6: Physical dimensions of ODIN-W262 6.2 Module weight Module Typ Unit ODIN-W260 2 g ODIN-W262 2 g Table 27: Module weight UBX-14039949 - R12 Mechanical specifications Page 24 of 42 ODIN-W2 series - Data Sheet 7 Qualification and approvals 7.1 Compliance with RoHS directive The ODIN-W2 series modules comply with the "Directive 2011/65/EU of the European Parliament and the Council on the Restriction of Use of certain Hazardous Substances in Electrical and Electronic Equipment" (RoHS). No natural rubbers, hygroscopic materials, or materials containing asbestos are employed. 7.2 European Union regulatory compliance Information about regulatory compliance of the European Union for ODIN-W2 series modules is available in the ODIN-W2 Declaration of Conformity [4]. 7.3 Safety compliance In order to fulfill the safety standard EN 60950-1, the unit must be supplied by a limited power source. 7.4 FCC and IC Compliance 7.4.1 IC compliance This device complies with Industry Canada license-exempt RSS standard(s). Operation is subject to the following two conditions: 1. this device may not cause interference, and 2. this device must accept any interference, including interference that may cause undesired operation of the device. Under Industry Canada regulations, this radio transmitter may only operate using an antenna of a type and maximum (or lesser) gain approved for the transmitter by Industry Canada. To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (e.i.r.p.) is not more than that necessary for successful communication. The device for operation in the band 5150-5250 MHz is only for indoor use to reduce the potential for harmful interference to co-channel mobile satellite systems; The maximum antenna gain permitted for devices in the bands 5250-5350 MHz and 5470-5725 MHz shall comply with the e.i.r.p. limit; and The maximum antenna gain permitted for devices in the band 5725-5825 MHz shall comply with the e.i.r.p. limits specified for point-to-point and non point-to-point operation as appropriate. Operation in the 5600-5650 MHz band is not allowed in Canada. High-power radars are allocated as primary users (i.e. priority users) of the bands 5250-5350 MHz and 5650-5850 MHz and that these radars could cause interference and/or damage to LE-LAN devices. This equipment complies with IC RSS-102 radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance 20 cm between the radiator & your body. 7.4.2 Conformité aux normes d’IC Cet appareil est conforme à la(aux) norme(s) RSS sans licence d’Industry Canada. Son utilisation est soumise aux deux conditions suivantes : 1. Cet appareil ne doit pas causer d’interférences et UBX-14039949 - R12 Qualification and approvals Page 25 of 42 ODIN-W2 series - Data Sheet 2. il doit accepter toutes interférences reçues, y compris celles susceptibles d’avoir des effets indésirables sur son fonctionnement. Conformément aux réglementations d’Industry Canada, cet émetteur radio ne peut fonctionner qu’à l’aide d’une antenne dont le type et le gain maximal (ou minimal) ont été approuvés pour cet émetteur par Industry Canada. Pour réduire le risque d’interférences avec d’autres utilisateurs, il faut choisir le type d’antenne et son gain de telle sorte que la puissance isotrope rayonnée équivalente (p.i.r.e) ne soit pas supérieure à celle requise pour obtenir une communication satisfaisante. Le dispositif de fonctionnement dans la bande 5150-5250 MHz est réservé à une utilisation en intérieur pour réduire le risqué d'interférences nuisibles à la co-canal systèmes mobiles par satellite. Le gain d'antenne maximal autorisé pour les appareils dans les bandes 5250-5350 MHz et 54705725 MHz doit se conformer à la pire limite, et le gain d'antenne maximal autorisé pour les appareils dans la bande 5725-5825 MHz doivent être conformes avec le pire limites spécifiées à point-à-ponctuelles et non point-à-point de fonctionnement selon qu'il convient. Opération dans la bande 5600-5650 MHz n'est pas autorisée au Canada. Haute puissance radars sont désignés comme utilisateurs principaux (c.-àutilisateurs prioritaires) des bandes 5250-5350 MHz et 5650-5850 MHz et que ces radars pourraient causer des interférences et / ou des dommages à dispositifs LAN-EL. Cet équipement respecte les limites d’exposition aux rayonnements IC RSS-102 définies pour un environnement non contrôlé. Il doit être installé et utilisé en maintenant une distance minimum de 20 cm entre le radiateur et votre corps. 7.4.3 FCC statement This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: 1. this device may not cause harmful interference, and 2. this device must accept any interference received, including interference that may cause undesired operation. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: • Reorient or relocate the receiving antenna. • Increase the separation between the equipment and receiver. • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. Consult the dealer or an experienced radio/TV technician for help. The ODIN-W2 module is for OEM integrations only. The end-user product will be professionally installed in such a manner that only the authorized antennas are used. Any changes or modifications NOT explicitly APPROVED by u-blox could cause the module to cease to comply with FCC rules part 15, and thus void the user's authority to operate the equipment. UBX-14039949 - R12 Qualification and approvals Page 26 of 42 ODIN-W2 series - Data Sheet 7.4.3.1 Cautions Any changes or modifications could cause the module to cease to comply with FCC rules part 15 thus void the user's authority to operate the equipment. §15.407 statement; in case of absence of information to transmit or operational failure the module types ODIN-W2 will automatically discontinue transmission. 7.4.4 Labeling requirements for end product For an end product using the ODIN-W2 modules there must be a label containing, at least, the following information: This device contains FCC ID: PVH0965 IC: 5325A-0965 The label must be affixed on an exterior surface of the end product such that it will be visible upon inspection in compliance with the modular approval guidelines developed by the FCC. In accordance with 47 CFR § 15.19 the end product shall bear the following statement in a conspicuous location on the device: "This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions; (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation." When the device is so small or for such use that it is not practicable to place the statement above on it, the information shall be placed in a prominent location in the instruction manual or pamphlet supplied to the user or, alternatively, shall be placed on the container in which the device is marketed. In case, where the final product will be installed in locations where the end-user is not able to see the FCC ID and/or this statement, the FCC ID and the statement shall also be included in the end-product manual. 7.4.4.1 IC requirement If the end product using the ODIN-W2 module is able to operate in the band 5150-5250 MHz within Canada (IC) it is only allowed to be used indoor to reduce the potential for harmful interference to co-channel mobile satellite systems. The label of the end product MUST in this case be marked with the text “For indoor use only”: This device contains FCC ID: PVH0965 IC: 5325A-0965 For indoor use only When the device is so small or for such use that it is not practicable to place the statement above on it, the information shall be placed in a prominent location in the instruction manual or pamphlet supplied to the user or, alternatively, shall be placed on the container in which the device is marketed. However, the FCC ID label including the “For indoor use only” text must be displayed on the device. UBX-14039949 - R12 Qualification and approvals Page 27 of 42 ODIN-W2 series - Data Sheet 7.5 Japan radio equipment compliance The ODIN-W2 module complies with the Japanese Technical Regulation Conformity Certification of Specified Radio Equipment (ordinance of MPT N°. 37, 1981), Article 2, Paragraph 1: • • • Item 19 "2.4 GHz band wide band low power data communication system" Item 19-3 “Low power data communications system in the 5.2/5.3 GHz band” Item 19-3-2 “Low power data communications system in the 5.6 GHz band” The ODIN-W2 module is restricted on the Japanese market to be used indoors only if the product is operating in the 5.2/5.3 GHz band. The information: “Indoor use only” translated into Japanese (この製品は屋内においての み使用可能です) must be visible: • • • on the certified end product. on the product package in which the end product is marketed. in the users / installation manual of the end product. The indoor usage information is recommended to be printed close to the Giteki mark but it is also permitted to place that information on another prominent position. The ODIN-W2 MIC certification number is 204-510009. The very small size of the module makes it not reasonable to fit the GITEKI mark and certification number onto the module label. Instead the Giteki mark and certification number is available in this document (Figure 7). When a product integrated with an ODIN-W2 module is placed on the Japanese market, it must have either of the following: • • The ODIN-W2 module is affixed with a label with the Giteki marking below. In this case, it is recommended that the product is marked with “Contains MIC ID: R 204-510009”. The product be affixed with a label with the Giteki marking below. The marking must be visible for inspection. 204-510009 この製品は屋内においてのみ使用可能です Figure 7: Giteki mark, R and the ODIN-W2 MIC certification number. The “Indoor use only” information translated into Japanese below is mandatory if the product is operating in the 5.2/5.3 GHz band. The recommended size of the Giteki mark is Ø5.0 mm but the minimum size is Ø3.0 mm. The end product holder shall also include a copy of the Japan Radio Certificate to the end product technical documentation. See the Contact information in the end of this document for a copy of the Radio Certificate. 7.6 SRRC China Radio Transmission Equipment Type Approval Only the ODIN-W262 is modular approved for integration in an end product on the Chinese market. In accordance with the provisions on the Radio Regulations of the People's Republic of China, the ODIN-W262 module with the product name ODIN-W262 conforms to the provisions with its CMIIT ID: 2016AJ1533. 7.6.1 ODIN-W262 labeling requirements for end product The following requirements apply for end products that are sold in China: • Label with CMIIT ID number of the module is required to be placed on the end product. UBX-14039949 - R12 Qualification and approvals Page 28 of 42 ODIN-W2 series - Data Sheet • The following statement must be included in Chinese in the Chinese user manual: CMIIT ID: 2016AJ1533 (This device contains certified RF module which certificate number is CMIIT ID: 2016AJ1533) 7.7 NCC Taiwan compliance 7.7.1 Taiwan NCC Warning Statement • • 經型式認證合格之低功率射頻電機,非經許可,公司、商號或使用者均不得擅自變更頻率、 加大功率 或變更原設計之特性及功能。 低功率射頻電機之使用不得影響飛航安全及干擾合法通信;經發現有干擾現象時,應立即停用,並改 善至無干擾時方得繼續使用。前項合法通信,指依電信法規定作業之無線電通信。低功率射頻電機須 忍受合法通信或工業、科學及醫療用電波輻射性電機設備之干擾。 Statement translation: • • Without permission granted by the NCC, any company, enterprise, or user is not allowed to change frequency, enhance transmitting power or alter original characteristic as well as performance to an approved low power radio-frequency devices. The low power radio-frequency devices shall not influence aircraft security and interfere legal communications; If found, the user shall cease operating immediately until no interference is achieved. The said legal communications means radio communications is operated in compliance with the Telecommunications Act. The low power radio-frequency devices must be susceptible with the interference from legal communications or ISM radio wave radiated devices. 7.7.2 ODIN-W260 labeling requirements for end product When a product integrated with an ODIN-W260 module is placed on the Taiwan market, the product must be affixed with a label marking as shown below. The label can use wording such as the following: Contains Transmitter Module 內含發射器模組:: CCAJ16LP1230T0 or any similar wording that expresses the same meaning may be used. The marking must be visible for inspection. 7.7.3 ODIN-W262 labeling requirements for end product When a product integrated with an ODIN-W262 module is placed on the Taiwan market, the product must be affixed with a label marking as shown below. The label can use wording such as the following: Contains Transmitter Module 內含發射器模組:: CCAJ16LP1240T0 or any similar wording that expresses the same meaning may be used. The marking must be visible for inspection. UBX-14039949 - R12 Qualification and approvals Page 29 of 42 ODIN-W2 series - Data Sheet 7.8 Korean KCC certification The ODIN-W2 series modules are certified by the Korea Communications Commission (KCC). The KCC IDs for ODIN-W260 and ODIN-W262 are provided below: • • ODIN-W260 module: MSIP-CRM-ULX-ODIN-W260 ODIN-W262 module: MSIP-CRM-ULX-ODIN-W262 7.9 Brazil compliance When a product containing ODIN-W2 module is placed on the Brazilian market, the product must be affixed with a label or marking containing the Anatel logo, ODIN-W2 Homologation number: 03883-16-05903 and a statement claiming that the device may not cause harmful interference but must accept it (Resolution No 506). 03883-16-05903 “Este equipamento opera em caráter secundário, isto é, não tem direito a proteção contra interferência prejudicial, mesmo de estações do mesmo tipo, e não pode causar interferência a sistemas operando em caráter primário.” Statement translation: “This equipment operates on a secondary basis and, consequently, must accept harmful interference, including from stations of the same kind, and may not cause harmful interference to systems operating on a primary basis.” When the device is so small or for such use that it is not practicable to place the statement above on it, the information shall be placed in a prominent location in the instruction manual or pamphlet supplied to the user or, alternatively, shall be placed on the container in which the device is marketed. In case, where the final product will be installed in locations where the end user is unable to see the Anatel logo, ODIN-W2 Homologation number and/or this statement, the Anatel logo, ODIN-W2 Homologation number, and the statement shall also be included in the end product manual. 7.10 Australia and New Zealand regulatory compliance The ODIN-W260 and ODIN-W262 modules are compliant with the standards made by the Australian Communications and Media Authority (ACMA). The modules are compliant with AS/NZS 4268:2012 standard – Radio equipment and systems – Short range devices – Limits and methods of standard measurement. The ODIN-W2 module test reports can be used as part of the product certification and compliance folder. For more information on the test reports, send an email to the respective support team mail address as mentioned in the Contact section based on your location. To meet overall Australian and/or New Zealand end product compliance, the integrator must create a compliance folder containing all the relevant compliance test reports such as RF, EMC, electrical safety and DoC (Declaration of Conformity) and so on. It is the responsibility of the integrator to know what is required in the compliance folder for ACMA compliance. UBX-14039949 - R12 Qualification and approvals Page 30 of 42 ODIN-W2 series - Data Sheet For more information on Australia compliance, refer to the Australian Communications and Media Authority web site http://www.acma.gov.au/. For more information on New Zealand compliance, refer to the New Zealand Radio Spectrum Management Group web site www.rsm.govt.nz. 7.11 South Africa regulatory compliance The ODIN-W2 modules are compliant and certified by the Independent Communications Authority of South Africa (ICASA). End products that are made available for sale or lease or is supplied in any other manner in South Africa shall have a legible label permanently affixed to its exterior surface. The label shall have the ICASA logo and the ICASA issued license number as shown in the figure below. The minimum width and height of the ICASA logo shall be 3 mm. The approval labels must be purchased by the customer’s local representative directly from the approval authority ICASA. A sample of an ODIN-W2 ICASA label is included below: TA-2016/2795 APPROVED More information on registration as a Responsible Integrator and labeling requirements can be found at the following website: Independent Communications Authority of South Africa (ICASA) web site - https://www.icasa.org.za 7.12 Bluetooth qualification information The ODIN-W2 series modules have been qualified according to the Bluetooth 4.0 specification. The ODIN-W2 series module is Bluetooth listed with Declaration ID D028207. For an end product with ODIN-W2 integrated is no further qualification required. If the end product is Bluetooth listed shall the QD IDs listed in Table 28 be included in the product listing. Product type QD ID Listing Date Controller Subsystem 71681 28-Aug-2015 Host Subsystem 40911 29-Jan-2013 Table 28: ODIN-W2 Bluetooth QD ID For information how to list and declare your product see the ODIN-W2 series System Integration Manual [2]. UBX-14039949 - R12 Qualification and approvals Page 31 of 42 ODIN-W2 series - Data Sheet 8 Antennas This chapter gives an overview of the different external antennas that can be fitted to the module. This radio transmitter IC: 5325A-0965 has been approved by Industry Canada to operate with the antenna types listed below with the maximum permissible gain and required antenna impedance for each antenna type indicated. Antenna types not included in this list, having a gain greater than the maximum gain indicated for that type, are strictly prohibited for use with this device. Cet émetteur radio IC: 5325A-0965 été approuvé par Industry Canada pour fonctionner avec les types d’antenne énumérés ci-dessous avec le gain maximum autorisé et l’impédance nécessaire pour chaque type d’antenne indiqué. Les types d’antenne ne figurant pas dans cette liste et ayant un gain supérieur au gain maximum indiqué pour ce type-là sont strictement interdits d’utilisation avec cet appareil. For each antenna, the "Approvals" field defines in which test reports the antenna is included. Definitions of the «Approvals» field are: • • • • • • • • FCC - The antenna is included in the FCC test reports and thus approved for use in countries that accept the FCC radio approvals, primarily US. IC - The antenna is included in the IC (Industrie Canada) test reports and thus approved for use in countries that accept the IC radio approvals, primarily Canada. R&TTE - The antenna is included in the R&TTE test reports and thus approved for use in countries that accept the R&TTE radio approvals, primarily the European countries. MIC - The antenna is included in the Japanese government affiliated MIC test reports and thus approved for use in the Japanese market. NCC - The antenna is included in the Taiwan NCC test reports and thus approved for use in Taiwan. KCC - The antenna is included in the Korea KCC test reports and thus approved for use in Korea. ANATEL – The antenna is included in the Brazil Anatel test reports and thus approved for use in Brazil. ICASA – The antenna is included in the South Africa ICASA test reports and thus approved for use in South Africa. In general, antennas with SMD connection, Reverse Polarity SMA connector or U.FL connector are included in FCC, IC, R&TTE, NCC, MIC, ANATEL and ICASA radio tests. The antennas with SMA connector are included in R&TTE, NCC, MIC, ANATEL and ICASA radio tests but not in the FCC or IC due to FCC/IC regulations. Only dual band antennas are allowed to be used on the main antenna port (see section 2.2.1) in Korea. Only the ODIN-W262 with internal antenna is modular approved for the China market. The ODINW260 with antenna connectors to be used with the external antennas is not approved to be used on the China market. The external antennas are connected to the board through U.FL connectors. Some antennas are connected directly to the U.FL connector of the board while some are connected using an SMA or reversed polarity SMA connector through a short U.FL to SMA or reversed polarity SMA adapter cable. 8.1 Antenna accessories Name U.FL to SMA adapter cable Connector U.FL and SMA jack (outer thread and pin receptacle) Impedance Minimum cable length 50 Ω 120 mm Minimum cable loss Comment 0.5 dB, The cable loss must be above the minimum cable loss to meet the regulatory requirements The SMA connector can be mounted in a panel Approval R&TTE, MIC, NCC, KCC, ANATEL, and ICASA UBX-14039949 - R12 Antennas Page 32 of 42 ODIN-W2 series - Data Sheet Name U.FL to Reverse Polarity SMA adapter cable Connector U.FL and Reverse Polarity SMA jack (outer thread and pin) Impedance Minimum cable length 50 Ω 120 mm Minimum cable loss 0.5 dB, The cable loss must be above the minimum cable loss to meet the regulatory requirements The Reverse Polarity SMA connector can be mounted in a panel Comment Approval FCC, IC, R&TTE, MIC, NCC, KCC, ANATEL, and ICASA 8.2 Approved antennas 8.2.1 Single band antennas Ex-IT 2400 RP-SMA 28-001 Manufacturer Polarization ProAnt Vertical Gain +3.0 dBi Impedance Size 50 Ω Ø 12.0 x 28.0 mm Type Monopole Reverse Polarity SMA plug (inner thread and pin receptacle). To be mounted on the U.FL to Reverse Polarity SMA adapter cable. Connector Comment Approval An SMA version antenna is also available but not recommended for use (Ex-IT 2400 SMA 28001). FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA Ex-IT 2400 MHF 28 Manufacturer Polarization ProAnt Vertical Gain +2.0 dBi Impedance Size 50 Ω Ø 12.0 x 28.0 mm Type Cable length Monopole 100 mm Connector Comment U.FL. connector To be mounted on the U.FL connector on the PCB. Approval FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA Ex-IT 2400 RP-SMA 70-002 Manufacturer Polarization ProAnt Vertical Gain +3.0 dBi Impedance Size 50 Ω Ø 10 x 83 mm Type Connector Monopole Reverse Polarity SMA plug (inner thread and pin receptacle) Comment Approval To be mounted on the U.FL to Reverse Polarity SMA adapter cable (cB-ACC38). An SMA version antenna is also available but not recommended for use (Ex-IT 2400 SMA 70-002). FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA UBX-14039949 - R12 Antennas Page 33 of 42 ODIN-W2 series - Data Sheet Ex-IT 2400 MHF 70-001 Manufacturer ProAnt Polarization Gain Vertical +3.0 dBi Impedance 50 Ω Size Type Ø 9.4 x 70.5 mm Monopole Cable length Connector 100 mm U.FL. connector Comment Approval To be mounted on the U.FL connector on the PCB. FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA InSide-2400 Manufacturer ProAnt Gain Impedance +3.0 dBi 50 Ω Size 27 x 12 mm (triangular) Type Cable length Patch 100 mm Connector Comment U.FL. connector To be mounted on the U.FL connector on the PCB. Approval FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA FlatWhip-2400 Manufacturer Gain ProAnt +3.0 dBi Impedance Size 50 Ω Ø 50.0 x 30.0 mm Type Monopole Connector Comment SMA plug (inner thread and pin) To be mounted on the U.FL to SMA adapter cable. Approval R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA Outside-2400 Manufacturer Gain ProAnt +3.0 dBi Impedance Size 50 Ω 36.0 x 18.0 x 16.0 mm Type Cable length Patch 70 mm Connector U.FL. connector Comment Approval To be mounted on the U.FL connector on the PCB. FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA * In Korea is only dual band antennas allowed on the main antenna port and 2.4 GHz single band antennas are only allowed on the MIMO antenna port. UBX-14039949 - R12 Antennas Page 34 of 42 ODIN-W2 series - Data Sheet 8.2.2 Dual-band antennas InSide-WLAN Manufacturer Gain ProAnt +3.0 dBi Impedance 50 Ω Size Type 27 x 12 mm (triangular) Patch Cable length Connector 100 mm U.FL. connector Comment Dual-band (2.4 GHz/ 5 GHz) antenna to be mounted on the U.FL connector on the PCB. FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA Approval InSide-WLAN Square Manufacturer ProAnt Gain Impedance +3.0 dBi 50 Ω Size Type 24x22x1 mm with mounting hole Patch Cable length Connector 100 mm U.FL. connector Comment Dual-band (2.4 GHz / 5 GHz) antenna to be mounted on the U.FL connector on the PCB. FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA Approval Ex-IT WLAN RPSMA / Ex-IT WLAN SMA Manufacturer ProAnt Type Polarization ½ wave dipole dual-band antenna Vertical Gain Impedance +3 dBi 50 Ω Size 107 mm (Straight) Type Connector Monopole Comment Approval • Reverse Polarity SMA plug (inner thread and pin receptacle) • SMA plug (inner thread and pin) To be mounted on the U.FL to SMA or reverse polarity SMA adapter cable. FCC, IC, R&TTE, MIC, NCC, KCC*, ANATEL, and ICASA UBX-14039949 - R12 Antennas Page 35 of 42 ODIN-W2 series - Data Sheet 9 Product handling and soldering 9.1 Packaging 9.2 Packaging The ODIN-W2 series modules are delivered as hermetically sealed, reeled tapes to enable efficient production, production lot set-up and tear-down. For more information about packaging, see the u-blox Package Information Guide [3]. 9.2.1 Reels The ODIN-W2 series modules are delivered on the reel as described in Table 29: Parameter Specification Reel type Delivery quantity B2 200 Table 29: Reel information for ODIN-W2 series modules 9.2.2 Tapes Figure 8 shows the position and the orientation of ODIN-W2 modules as they are delivered on the tape, while Figure 9 specifies the tape dimensions. Figure 8: Orientation for ODIN-W2 modules on tape UBX-14039949 - R12 Product handling and soldering Page 36 of 42 ODIN-W2 series - Data Sheet Figure 9: ODIN-W2 series tape dimensions 9.3 Moisture sensitivity levels The ODIN-W2 series modules are Moisture Sensitive Devices (MSD) in accordance with the IPC/JEDEC specification. The Moisture Sensitivity Level (MSL) relates to the required packaging and handling precautions. The ODIN-W2 series modules are rated at MSL level 4. For more information regarding moisture sensitivity levels, labeling, and storage, see the u-blox Package Information Guide [3]. For MSL standards, see IPC/JEDEC J-STD-020, which can be downloaded from www.jedec.org. 9.4 Reflow soldering Reflow profiles are to be selected according to u-blox recommendations (see ODIN-W2 series System Integration Manual [2]). Failure to observe these recommendations can result in severe damage to the device. 9.5 ESD precautions The ODIN-W2 series modules contain highly sensitive electronic circuitry and are Electrostatic Sensitive Devices (ESD). Handling the ODIN-W2 series modules without proper ESD protection may destroy or damage them permanently. The ODIN-W2 series modules are electrostatic sensitive devices (ESD) and require special ESD precautions typically applied to ESD sensitive components. The Maximum ESD section reports the maximum ESD ratings of the ODIN-W2 series modules. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates the ODIN-W2 series module. The ESD precautions should be implemented on the application board where the module is mounted as described in the ODIN-W2 series System Integration Manual [2]. Failure to observe these recommendations can result in severe damage to the device. UBX-14039949 - R12 Product handling and soldering Page 37 of 42 ODIN-W2 series - Data Sheet 10 Labeling and ordering information The labels of the ODIN-W2 series modules include important product information as described in this section. Figure 8 illustrates the label of all the ODIN-W2 series modules, which includes product type number and revision, production date, Data Matrix with unique serial number (MAC address), u-blox logo and regulatory certification numbers (if applicable). Because of space constraints, all certification numbers are not printed on the label (see Qualification and approvals section for all certification IDs). 1a 1b 3 1 3a 3b 2 5 4 6 Figure 10: Location of product type number on the ODIN-W2 series module label Reference Description 1 2 Text area containing product model name Text area containing regulatory certification IDs 3 Text area containing Product Revision and date of production 3a Major and minor product version info 3b Date of unit production encoded YY/WW (year, week) 4 Data Matrix with unique serial number of 19 alphanumeric symbols. The 3 first symbols represent the unique module type no. 587: ODIN-W260 and 588: ODINW262, the next 12 symbols represent the unique hexadecimal Ethernet MAC address of the module AABBCCDDEEFF, and the last 4 symbols represent the hardware and firmware version encoded HHFF. See section 1.8 for more information about MAC addresses. 5 Certifications logos area 6 u-blox logo. Preprinted on label. The red dot is also indicating pin 1. Table 30: ODIN-W2 series label description UBX-14039949 - R12 Labeling and ordering information Page 38 of 42 ODIN-W2 series - Data Sheet 10.1 Explanation of codes Three different product code formats are used. The Product Name is used in documentation such as this data sheet and identifies all u-blox products, independent of packaging and quality grade. The Ordering Code includes options and quality, while the Type Number includes the hardware and firmware versions. Table 31 below details these three different formats: Format Structure Product Name PPPP-TGRV Ordering Code PPPP -TGRV-TTQ Type Number PPPP -TGRV-TTQ-XX Table 31: Product code formats Table 32 explains the parts of the product code. Code Meaning Example PPPP Form factor ODIN TG Platform (Technology and Generation) T – Dominant technology, For example, W: Wi-Fi, B: Bluetooth G - Generation W2: Wi-Fi Generation 2 R Wireless technology; range [0...9] 6: Multi-radio dual-band 2.4+5GHz V Variant based on the same platform; range [00…99] 0: default mounting, with connector for external antenna TT Major Product Version 00: first revision Q Quality grade • A: Automotive • B: Professional B: professional grade XX Minor product version (not relevant for certification) • C: Standard Default value is 00 Table 32: Part identification code 10.2 Ordering information Ordering Code Product ODIN-W260-00B Wi-Fi IEEE802.11a/b/g/n (dual-band) 2.4 GHz 2x2 MIMO and Bluetooth dual-mode module with dual U.FL. coaxial antenna connectors. Firmware 1.0.0 ODIN-W262-00B Wi-Fi IEEE802.11a/b/g/n (dual-band) and Bluetooth dual-mode module with internal dual-band antenna. Firmware 1.0.0 ODIN-W260-01B Wi-Fi IEEE802.11a/b/g/n (dual-band) 2.4 GHz 2x2 MIMO and Bluetooth dual-mode module with dual U.FL. coaxial antenna connectors. Firmware 2.0.2 ODIN-W262-01B Wi-Fi IEEE802.11a/b/g/n (dual-band) and Bluetooth dual-mode module with internal dual-band antenna. Firmware 2.0.2 ODIN-W260-02B Wi-Fi IEEE802.11a/b/g/n (dual-band) 2.4 GHz 2x2 MIMO and Bluetooth dual-mode module with dual U.FL. coaxial antenna connectors. u-blox connectivity software version 3.0.1 ODIN-W262-02B Wi-Fi IEEE802.11a/b/g/n (dual-band) and Bluetooth dual-mode module with internal dual-band antenna. u-blox connectivity software version 3.0.1 ODIN-W260-03B Wi-Fi IEEE802.11a/b/g/n (dual-band) 2.4 GHz 2x2 MIMO and Bluetooth dual-mode module with dual U.FL. coaxial antenna connectors. Firmware 4.0.0 ODIN-W262-03B Wi-Fi IEEE802.11a/b/g/n (dual-band) and Bluetooth dual-mode module with internal dual-band antenna. Firmware 4.0.0 Table 33: Product ordering codes UBX-14039949 - R12 Labeling and ordering information Page 39 of 42 ODIN-W2 series - Data Sheet Appendix Glossary Name Definition ADC Analog to Digital Converter BT Bluetooth CAN Controller Area Network CTS Clear To Send DC Direct Current DoC Declaration of Conformity DSR Data Set Ready DTR Data Terminal Ready EIRP Equivalent Isotropically Radiated Power FW Firmware GND Ground GPIO General Purpose Input Output H High HW Hardware I Input (means that this is an input port of the module) IEEE Institute of Electrical and Electronics Engineers L Low LPO Low Power Oscillator MIMO Multi-Input Multi-Output N/A Not Applicable O Output (means that this is an output port of the module) PCN / IN Product Change Notification / Information Note PD Pull-Down PU Pull-Up RMII Reduced Media Independent Interface RTS Request To Send RXD Receive Data SMI Station Management Interface SPI Serial Peripheral Interface TBD To Be Defined TXD Transmit Data UART Universal Asynchronous Receiver-Transmitter serial interface Table 34: Explanation of abbreviations used UBX-14039949 - R12 Appendix Page 40 of 42 ODIN-W2 series - Data Sheet Related documents [1] u-blox Short Range Modules AT Commands Manual, document number UBX-14044127 [2] [3] ODIN-W2 series System Integration Manual, document number UBX-14040040 u-blox Package Information Guide, document number UBX-14001652 [4] ODIN-W2 Declaration of Conformity, document number, UBX-15024695 For regular updates to u-blox documentation and to receive product change notifications please register on our homepage. Revision history Revision Date Name Comments R01 05-Sep-2014 mwej Initial release. R02 16-Feb-2015 fbro Minor updates R03 23-Apr-2015 ajoh Updated features list, added input from early measurements and label specification. R04 08-July-2015 fbro, kgom Applied u-blox word template. R05 22-Sept-2015 mwej, kgom Major updates. Updated some IO voltage levels and some tolerances. Clarified mechanical outline. Updated performance measurements with ODIN-W26x SPA FW v0.11.05. Updated after type approval with approval information. Updated Table 1 similar to the ODIN-W2 series Product Summary. R06 29-Jan-2016 mwej, pber Added ETSI, FCC, IC, Japan approval certification information. Added Bluetooth Qualification information. Added list of approved antennas. Removed two unavailable test points from Mechanical dimensions (correction). Provided reference to ODIN-W2 Declaration of Conformity (UBX-15024695). Changed Document status to Early Production Information. Removed n rate characteristics (will be added when supported). Modified Table 1 and Table 2. Updated section 1.1 and section 5.4 (values in Table 19 to Table 26). R07 16-Jun-2016 mwej, kgom Updated product features (Table 1). Modified Updated to product version ODINW260-01B and ODIN-W262-01B due to firmware update. Updated label (section 10.1). Added MAC address information (section 1.8). Power saving mode implemented and current consumption reduced in idle mode (modified Table 14 Table 18). Added Taiwan, China and Korea approval certification information (section 7.8 and section 8). Updated order information (Table 33). R08 18-Jul-2016 mwej, kgom R09 06-Oct-2016 mwej, kgom R10 02-Dec-2016 mwej R11 10-Jan-2017 ajoh, ecar, kgom R12 30-Mar-2017 mwej Updated product features (Table 1). Added compliance information for Australia and New Zealand (section 7.9). Updated the Product features (Table 1) and applicable products Table (page 2) with Firmware 3.0. Added antenna type information in section 8.2. Updated Australia and New Zealand compliance information (section 7.9) and tape orientation (section 9.2.2). Removed the information in European Union regulatory compliance (section 7.2) and provided reference to the ODIN-W2 Declaration of Conformity (UBX15024695). Updated the document status to “Production Information”. Updated number of Test points (TP) to 51 in Figure 5. Removed reference to System Integration Manual [2] in section 7.5. Added channel information in Access Point mode (Table 2). Added information about support for IEEE 802.11d/e/i/h (h:DFS client only) in Table 2. Updated Product ordering codes (Table 33). Included support for ODIN-W2 firmware versions – 2.0.2 and 3.0.1. On page 2, replaced Document status with Disclosure restriction. Updated Product ordering codes (Table 33). Included support for ODIN-W2 firmware version – 4.0.0. Added type approval information for Brazil and South Africa (chapters 7 and 8). UBX-14039949 - R12 Related documents Page 41 of 42 ODIN-W2 series - Data Sheet Contact For complete contact information visit us at www.u-blox.com u-blox Offices North, Central and South America u-blox America, Inc. Phone: +1 703 483 3180 E-mail: info_us@u-blox.com Regional Office West Coast: Phone: +1 408 573 3640 E-mail: info_us@u-blox.com Technical Support: Phone: E-mail: +1 703 483 3185 support @u-blox.com Headquarters Europe, Middle East, Africa u-blox AG Phone: E-mail: Support: +41 44 722 74 44 info@u-blox.com support@u-blox.com Asia, Australia, Pacific u-blox Singapore Pte. Ltd. Phone: +65 6734 3811 E-mail: info_ap@u-blox.com Support: support_ap@u-blox.com Regional Office Australia: Phone: +61 2 8448 2016 E-mail: info_anz@u-blox.com Support: support_ap@u-blox.com Regional Office China (Beijing): Phone: +86 10 68 133 545 E-mail: info_cn@u-blox.com Support: support_cn@u-blox.com Regional Office China (Chongqing): Phone: +86 23 6815 1588 E-mail: info_cn@u-blox.com Support: support_cn@u-blox.com Regional Office China (Shanghai): Phone: +86 21 6090 4832 E-mail: info_cn@u-blox.com Support: support_cn@u-blox.com Regional Office China (Shenzhen): Phone: +86 755 8627 1083 E-mail: info_cn@u-blox.com Support: support_cn@u-blox.com Regional Office India: Phone: +91 80 4050 9200 E-mail: info_in@u-blox.com Support: support_in@u-blox.com Regional Office Japan (Osaka): Phone: +81 6 6941 3660 E-mail: info_jp@u-blox.com Support: support_jp@u-blox.com Regional Office Japan (Tokyo): Phone: +81 3 5775 3850 E-mail: info_jp@u-blox.com Support: support_jp@u-blox.com Regional Office Korea: Phone: +82 2 542 0861 E-mail: info_kr@u-blox.com Support: support_kr@u-blox.com Regional Office Taiwan: Phone: +886 2 2657 1090 E-mail: info_tw@u-blox.com Support: support_tw@u-blox.com UBX-14039949 - R12 Contact Page 42 of 42
ODIN-W262-00B 价格&库存
很抱歉,暂时无法提供与“ODIN-W262-00B”相匹配的价格&库存,您可以联系我们找货
