7INCH_HDMI_LCD-PK
7INCH_HDMI_LCD-PK
    UDOO
    智能,智慧,发光二极管,图形 红色,绿色,蓝色(RGB) TFT - 彩色 并联,24 位(RGB) 7"(177.80mm) 1024 x 600
7INCH_HDMI_LCD-PK 数据手册
3. PRODUCT INFORMATION 3.1. Description FY07024DI26A67-FT is a color active matrix LCD module incorporating amorphous silicon TFT (Thin Film Transistor). It is composed of a color TFT-LCD panel, driver ICs, FPC and a backlight unit. The 7.0′′ display area contains 1024 (RGB) x 600 pixels 3.2. Applications □UMPC □Portable DVD □GPS □MID 3.3. Features □High Resolution:1024(RGB) x 600 Dots □adopting a high aperture ratio □24 chip LED backlight □Dot-Inversion 4. General Specifications NO. ITEM SPECIFICATION UNIT inch 1 LCD size 7.0 (Diagonal) 2 Driver Method a-si TFT active matrix - 3 Resolution 1024 × 3(RGB) × 600 dots 4 Display mode Normally Black, FFS - 5 Dot pitch 0.1506(H) × 0.1432(V) mm 6 Active area 154.21(H) × 85.92(V) mm 7 Panel size 163.64 (H) × 96.84(V) ×2.6(T) 8 9 Color Pixel RGB vertical stripe Arrangement Surface treatment Anti-Glare 10 View Direction All - 11 Interface RGB - mm - REMARK Mechanical drawing 5. A00 VER 2013.09.27 DATE Component Area Height 1.2mm (Max) DETAIL A Specification: 1). ViewingDirection: 2).Display mode:Normally Black 3). Operating temp.: -20~70° C Storage temp.: -30~80° C 4). Drive IC: 5)Backling:24chip white LED in parallel vf:10.5 v if:160mA 6). Dimensions with mark "*" are important, with mark "()" are referenced 7)Request ROHS DETAIL A SCALE:2:1 ± 0.3 Vf=9~10.5V If=160mA AK 13.09.27 1 ☆PI补强PI+FPC (即补强后总厚度)=0.3mm ±0.03 FY07024DI26A67-FT CAI 30 26 27 28 29 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 2 1 R4 R3 R2 R1 R0 GND DCLK GND SHLR UPDN VGH VGL AVDD RESET NC NC DITH GND NC NC R5 G1 G0 R7 R6 LEDLEDGND NC DVDD MODE DEN VSD HSD B7 B6 B5 B4 B3 B2 B1 B0 G7 G6 G5 G4 G3 G2 LED+ LED+ Pad No. Pad Name 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 6. ABSOLUTE MAXIMUM RATINGS 7.ELECTRICAL CHARACTERISTICS 8. OPTICAL CHARACTERISTICS 9. Backlight Driving Section Item Symbol LED Voltage VF LED Current IF Number of LED -- Note 1: Min. 9 - Typ. Max. 9.8 160 10.5 - 24 Unit V mA -- There are 1 Groups LED Note 2: Ta = 25_ Note 3: Brightness to be decreased to 50% of the initial value BLU CIRCUIT DIAGRAM Remark 10. RGB Interface Pin Function 1-2 LED+ LED Anode 3-4 LED- LED Cathode 5 GND Ground 6 NC Not Connect 7 DVDD Digital Power 8 MODE DE/SYNC mode select. Normally pull high H: DE mode. L: HSD/VSD mode 9 DEN Data Enable signal 10 VSD Vertical sync input. Negative polarity 11 HSD Horizontal sync input. Negative polarity 12-19 B7-B0 Blue Data Input 20-27 G7-G0 Green Data Input 28-35 R7-R0 Red Data Input 36 GND Power ground 37 DCLK Clock input 38 GND Power ground 39 SHLR Left or Right Display Control【Note1】 40 UPDN Up / Down Display Control 41 VGH Positive Power for TFT 42 VGL Negative Power for TFT 43 AVDD Analog Power 44 RESET 45 NC Not connect 46 NC Not connect 47 DITH Global reset pin. Active low to enter reset state. Suggest to connecting with an RC reset circuit for stability.Normally pull high. (R=10KΩ,C=1 μF) Dithering function enable control. Normally pull low DITHER = “1”, Enable internal dithering function DITHER = “0”, Disable internal dithering function 48 GND Power ground 49 NC Not connect 50 NC Not connect 11. Caution 11.1 Handling of LCM . Be sure to ground the body when handling the LCM. . Don’t give external shock . Don’t apply excessive force on the surface. . Liquid in LCD is hazardous substance. Must not lick and swallow. When the liquid is attach to your hand, skin, cloth etc. Wash it out thoroughly and immediately. . Don’t operate it above the absolute maximum rating. . Don’t disassemble the LCM 11.2 Storage .Store in an ambient temperature of 5℃ to 45℃,and in a relative humidity of 40% to 60%. Don’t expose to sunlight or intensive ultraviolet rays . Storage in a clean environment, free from dust, active gas, and solvent. . Store in anti-static electricity container. . Store without any physical load.
7INCH_HDMI_LCD-PK 价格&库存
很抱歉,暂时无法提供与“7INCH_HDMI_LCD-PK”相匹配的价格&库存,您可以联系我们找货
