EGPA500ELL222MM35S
EGPA500ELL222MM35S
    NCC(贵弥功)
    插件
    2200 µF 50 V 铝电解电容器 径向,Can 22 毫欧 @ 100kHz 125°C 时为 5000 小时
EGPA500ELL222MM35S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Long life, Downsized, 125℃ Upgrude! GPA ●Downsized, Series low impedance and high-ripple current version of GXE series ●Specified ESR after endurance test ●For high ripple current automotive applications. (Direct fuel injection and electric power steering etc.) ●Endurance with ripple current : 3,000 to 5,000 hours at 125℃ ●Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ●RoHS Compliant Downsized Higher ripple current GXE GPA Higher temperature LXZ ◆SPECIFICATIONS Items Characteristics Category Temperature Range -40 to +125℃ Rated Voltage Range 25 to 100Vdc (at 20℃, 120Hz) Capacitance Tolerance ±20% (M) Leakage Current I=0.03CV or 4µA, whichever is greater. (at 20℃, 1 minute) Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 25V 35V 50V 63V 80V 100V Dissipation Factor (tanδ) 0.14 0.12 0.10 0.10 0.08 0.08 tanδ(Max.) (at 20℃, 120Hz) When nominal capacitance exceeds 1,000µF, add 0.02 to the above value for each 1,000µF increase. Rated voltage (Vdc) 25V 35V 50V 63V 80V 100V Low Temperature Characteristics Z(-25℃)/Z(+20℃) 2 2 2 2 2 2 (Max. Impedance Ratio) (at 120Hz) Z(-40℃)/Z(+20℃) 4 4 4 4 4 4 The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple Endurance current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours (3,000 hours for 25L and less) at 125 ℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without Shelf Life voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value ◆DIMENSIONS [mm] Code : E φD' φd Sleeve (PET : Brown) F±0.5 ●Terminal L' Vent 15min. 4min. Gas escape end seal φD φd F φD' L' 12.5   14.5  16   18 0.6  0.8   0.8 0.8 5.0 7.5 7.5 7.5 φD+0.5max. L+1.5max. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E GPA AAA E AA AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 470µF:471, 1,000µF:102) Lead forming·taping code Terminal code Voltage code (ex. 25V:250, 50V:500) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. (1/3) CAT. No. E1001M MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Long Life, Downsized, 125℃ Upgrude! GPA Series ◆STANDARD RATINGS WV (Vdc) 25 35 50 Cap (μF) Case size φD×L(mm) 1,200 1,500 1,800 1,800 2,200 2,200 2,700 2,700 2,700 2,700 3,300 3,300 3,300 3,900 3,900 4,700 4,700 5,600 5,600 6,800 680 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,200 2,700 2,700 2,700 3,300 3,300 4,700 470 560 680 680 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,200 1,500 1,800 1,800 2,200 2,200 2,700 12.5×20 14.5×20 12.5×25 16×20 12.5×30 14.5×25 12.5×35 14.5×30 16×25 18×20 12.5×40 14.5×35 16×30 16×35 18×25 14.5×40 18×30 16×40 18×35 18×40 12.5×20 12.5×25 14.5×20 12.5×30 16×20 14.5×25 12.5×35 14.5×30 18×20 12.5×40 16×25 14.5×35 16×30 18×25 14.5×40 16×35 18×30 16×40 18×35 18×40 12.5×20 14.5×20 12.5×25 16×20 12.5×30 14.5×25 12.5×35 14.5×30 16×25 18×20 12.5×40 14.5×35 16×30 18×25 16×35 14.5×40 18×30 16×40 18×35 18×40 ESR (Initial) (Ωmax/100kHz) 20℃ -40℃ 0.22 0.044 0.19 0.037 0.17 0.033 0.17 0.034 0.13 0.029 0.14 0.028 0.11 0.024 0.10 0.023 0.13 0.026 0.16 0.032 0.095 0.021 0.095 0.021 0.10 0.023 0.090 0.020 0.12 0.024 0.081 0.018 0.099 0.022 0.077 0.017 0.086 0.019 0.072 0.016 0.22 0.044 0.17 0.033 0.19 0.037 0.13 0.029 0.17 0.034 0.14 0.028 0.11 0.024 0.10 0.023 0.16 0.032 0.095 0.021 0.13 0.026 0.095 0.021 0.10 0.023 0.12 0.024 0.081 0.018 0.090 0.020 0.099 0.022 0.077 0.017 0.086 0.019 0.072 0.016 0.33 0.065 0.28 0.055 0.24 0.048 0.22 0.043 0.18 0.041 0.20 0.040 0.15 0.034 0.16 0.036 0.16 0.031 0.20 0.039 0.13 0.028 0.13 0.029 0.13 0.027 0.15 0.029 0.10 0.023 0.11 0.024 0.12 0.026 0.090 0.020 0.10 0.022 0.080 0.018 ESR (End of Life) (Ωmax/100kHz) 20℃ -40℃ 0.18 2.2 0.11 1.3 0.13 1.6 0.10 1.3 0.11 1.3 0.080 0.90 0.090 0.80 0.070 0.70 0.080 1.1 0.090 0.60 0.080 0.50 0.060 0.70 0.070 0.90 0.060 0.70 0.070 0.50 0.050 0.50 0.080 0.60 0.040 0.60 0.070 0.50 0.030 0.40 0.18 2.2 0.13 1.6 0.11 1.3 0.11 1.3 0.10 1.3 0.080 0.90 0.090 0.80 0.070 0.70 0.090 0.60 0.080 0.50 0.080 1.1 0.060 0.70 0.070 0.90 0.070 0.50 0.050 0.50 0.060 0.70 0.080 0.60 0.040 0.60 0.070 0.50 0.030 0.40 0.18 2.2 0.11 1.3 0.13 1.6 0.10 1.3 0.11 1.3 0.080 0.90 0.090 0.80 0.070 0.70 0.080 1.1 0.090 0.60 0.080 0.50 0.060 0.70 0.070 0.90 0.070 0.50 0.060 0.70 0.050 0.50 0.080 0.60 0.040 0.60 0.070 0.50 0.030 0.40 Rated ripple current (mArms/125℃,100kHz) Part No. 1,820 2,100 2,280 2,280 2,560 2,620 2,970 3,060 2,860 2,490 3,340 3,380 3,160 3,590 3,010 3,730 3,390 3,970 3,840 4,230 1,820 2,280 2,100 2,560 2,280 2,620 2,970 3,060 2,490 3,340 2,860 3,380 3,160 3,010 3,730 3,590 3,390 3,970 3,840 4,230 1,500 1,740 1,900 2,040 2,150 2,190 2,510 2,470 2,620 2,240 2,870 2,840 2,940 2,750 3,300 3,230 3,140 3,720 3,510 3,940 EGPA250E□□122MK20S EGPA250E□□152MU20S EGPA250E□□182MK25S EGPA250E□□182ML20S EGPA250E□□222MK30S EGPA250E□□222MU25S EGPA250E□□272MK35S EGPA250E□□272MU30S EGPA250E□□272ML25S EGPA250E□□272MM20S EGPA250E□□332MK40S EGPA250E□□332MU35S EGPA250E□□332ML30S EGPA250E□□392ML35S EGPA250E□□392MM25S EGPA250E□□472MU40S EGPA250E□□472MM30S EGPA250E□□562ML40S EGPA250E□□562MM35S EGPA250E□□682MM40S EGPA350E□□681MK20S EGPA350E□□102MK25S EGPA350E□□102MU20S EGPA350E□□122MK30S EGPA350E□□122ML20S EGPA350E□□122MU25S EGPA350E□□152MK35S EGPA350E□□152MU30S EGPA350E□□152MM20S EGPA350E□□182MK40S EGPA350E□□182ML25S EGPA350E□□222MU35S EGPA350E□□222ML30S EGPA350E□□222MM25S EGPA350E□□272MU40S EGPA350E□□272ML35S EGPA350E□□272MM30S EGPA350E□□332ML40S EGPA350E□□332MM35S EGPA350E□□472MM40S EGPA500E□□471MK20S EGPA500E□□561MU20S EGPA500E□□681MK25S EGPA500E□□681ML20S EGPA500E□□821MK30S EGPA500E□□821MU25S EGPA500E□□102MK35S EGPA500E□□102MU30S EGPA500E□□102ML25S EGPA500E□□102MM20S EGPA500E□□122MK40S EGPA500E□□122MU35S EGPA500E□□122ML30S EGPA500E□□122MM25S EGPA500E□□152ML35S EGPA500E□□182MU40S EGPA500E□□182MM30S EGPA500E□□222ML40S EGPA500E□□222MM35S EGPA500E□□272MM40S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. (2/3) CAT. No. E1001M MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Long Life, Downsized, 125℃ Upgrude! GPA Series ◆STANDARD RATINGS WV (Vdc) 63 80 100 Cap (μF) Case size φD×L(mm) 470 680 680 820 1,000 1,000 1,200 1,200 1,500 1,800 330 470 470 560 560 680 680 820 820 1,200 200 270 300 360 390 470 510 560 620 750 16×20 16×25 18×20 16×30 16×35 18×25 16×40 18×30 18×35 18×40 16×20 16×25 18×20 16×30 18×25 16×35 18×30 16×40 18×35 18×40 16×20 18×20 16×25 16×30 18×25 16×35 18×30 16×40 18×35 18×40 ESR (Initial) (Ωmax/100kHz) 20℃ -40℃ 0.58 0.085 0.48 0.061 0.49 0.070 0.41 0.053 0.33 0.044 0.34 0.049 0.26 0.036 0.26 0.041 0.21 0.035 0.18 0.030 0.58 0.085 0.48 0.061 0.49 0.070 0.41 0.053 0.34 0.049 0.33 0.044 0.26 0.041 0.26 0.036 0.21 0.035 0.18 0.030 0.88 0.11 0.73 0.091 0.72 0.079 0.62 0.068 0.50 0.064 0.50 0.056 0.39 0.054 0.39 0.046 0.32 0.044 0.27 0.039 ESR (End of Life) (Ωmax/100kHz) 20℃ -40℃ 0.19 3.0 0.14 2.0 0.19 3.0 0.090 1.3 0.070 0.90 0.14 2.0 0.060 0.80 0.090 1.3 0.070 0.90 0.060 0.80 0.19 3.0 0.14 2.0 0.19 3.0 0.090 1.3 0.14 2.0 0.070 0.90 0.090 1.3 0.060 0.80 0.070 0.90 0.060 0.80 0.25 3.9 0.22 3.9 0.18 2.7 0.13 1.9 0.15 2.7 0.090 1.3 0.13 1.9 0.080 1.1 0.090 1.3 0.080 1.1 Rated ripple current (mArms/125℃,100kHz) Part No. 1,790 2,030 1,910 2,330 2,580 2,280 2,900 2,580 2,890 3,210 1,790 2,030 1,910 2,330 2,280 2,580 2,580 2,900 2,890 3,210 1,580 1,690 1,990 2,250 2,110 2,500 2,410 2,700 2,690 2,880 EGPA630E□□471ML20S EGPA630E□□681ML25S EGPA630E□□681MM20S EGPA630E□□821ML30S EGPA630E□□102ML35S EGPA630E□□102MM25S EGPA630E□□122ML40S EGPA630E□□122MM30S EGPA630E□□152MM35S EGPA630E□□182MM40S EGPA800E□□331ML20S EGPA800E□□471ML25S EGPA800E□□471MM20S EGPA800E□□561ML30S EGPA800E□□561MM25S EGPA800E□□681ML35S EGPA800E□□681MM30S EGPA800E□□821ML40S EGPA800E□□821MM35S EGPA800E□□122MM40S EGPA101E□□201ML20S EGPA101E□□271MM20S EGPA101E□□301ML25S EGPA101E□□361ML30S EGPA101E□□391MM25S EGPA101E□□471ML35S EGPA101E□□511MM30S EGPA101E□□561ML40S EGPA101E□□621MM35S EGPA101E□□751MM40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ●Frequency Capacitance(µF) Multipliers Frequency(Hz) 200 270 to 560 620 to 1,800 2,200 to 3,900 4,700 to 6,800 120 0.40 0.50 0.60 0.75 0.85 1k 0.82 0.85 0.87 0.90 0.95 10k 0.93 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. (3/3) CAT. No. E1001M
EGPA500ELL222MM35S
物料型号:GPA系列
器件简介:这是CHEMI-CON公司生产的小型铝电解电容器,具有长寿命、小型化、125℃高温应用的特点,是GXE系列的升级版,具有更低的阻抗和更高的纹波电流承受能力。
引脚分配:文档中没有提供具体的引脚分配信息,但通常这类电容器会有标注正负极的标识。
参数特性: - 工作温度范围:-40至+125°C - 额定电压范围:25至100Vdc - 电容公差:±20%(M类,20°C,120Hz) - 漏电流:最大漏电流为0.03CV或4μA,取较大者,其中I为最大漏电流(μA),C为标称电容值(μF),V为额定电压(V)(20°C,1分钟) - 损耗角正切(tan):随额定电压不同而变化,25V时为0.14,100V时为0.08,如果标称电容超过1,000μF,每增加1,000μF增加0.02(20°C,120Hz) - 低温特性(最大阻抗比):在-25°C和-40°C时,阻抗比分别为2和4(120Hz)
功能详解:适用于高纹波电流的汽车应用,如直接燃油喷射和电动助力转向等,具有耐溶剂特性和符合RoHS标准。
应用信息:适用于需要高纹波电流和高温环境的汽车电子设备。
封装信息:提供了详细的尺寸信息,包括直径(D)、引脚直径(d)、通气孔直径(F)等,以及端子编码方式。
EGPA500ELL222MM35S 价格&库存
很抱歉,暂时无法提供与“EGPA500ELL222MM35S”相匹配的价格&库存,您可以联系我们找货
