HHSC630ELL101MJC5S
HHSC630ELL101MJC5S
    NCC(贵弥功)
    插件,D10xL14mm
    100 µF 63 V 铝聚合物电容器 径向,Can 20 毫欧 125°C 时为 4000 小时
HHSC630ELL101MJC5S 数据手册
CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Radial Lead HSC Series ・High reliability and high voltage are realized by hybrid electrolyte ・Endurance with ripple current : 4,000 hours at 125℃ ・Rated voltage range : 25 to 63Vdc, Capacitance range : 100 to 330μF ・For high temperature and high reliability applications. (Automotive equipment, Base station equipment, etc.) ・RoHS2 Compliant ・Halogen Free ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. HSC Higher temperature HSD ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +125℃ 25 to 63Vdc ±20% (M) I=0.05CV Where, I : Max. leakage current (μA) , C: Nominal capacitance(μF), V : Rated voltage(V) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.5 Z(-55℃)/Z(+20℃)≦2.0 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 4,000 hours at 125℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage at 85℃, 85% RH for 2,000 hours. Appearance No significant damage Capacitance change ≦ ±30% of the initial value D.F.(tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Bias Humidity Test ◆DIMENSIONS [mm] ◆MARKING EX) 25V330µF Code : E φD' φd F±0.5 Coated Case L' 15min. 4D8 Size Code φD φd F φD' L' 4min. ◆PART NUMBERING SYSTEM 1 2 3 4 H HSC 5 6 7 8 E (at 20℃ after 2 minutes) 0.16 max. Shelf Life ●Terminal (at 20℃, 120Hz) 9 10 11 12 13 14 15 16 17 18 M J C5 S JC5 10 0.6 5.0 φD+0.5max. L+1.5max. 330 E HC ●Rated voltage symbol Rated voltage (Vdc) 25 35 50 63 Symbol E V H J Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101) Lead forming Taping code Terminal code Voltage code (ex. 35V:350, 50V:500) Series code Category Please refer to "Product code guide (conductive polymer hybrid type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Radial Lead HSCSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) ESR (mΩ max./20℃, 100kHz) Rated ripple current (mArms/125℃, 100kHz) Part No. 16 17 19 20 2,300 2,200 2,100 2,000 HHSC250E□□331MJC5S HHSC350E□□271MJC5S HHSC500E□□121MJC5S HHSC630E□□101MJC5S 25 330 10×12.5 35 270 10×12.5 50 120 10×12.5 63 100 10×12.5 □□:Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 100, 120 270, 330 120 0.10 0.13 1k 0.40 0.45 5k 0.60 0.65 10k 0.70 0.75 20k 0.80 0.85 30k 0.80 0.85 100k to 500k 1.00 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T
HHSC630ELL101MJC5S 价格&库存
很抱歉,暂时无法提供与“HHSC630ELL101MJC5S”相匹配的价格&库存,您可以联系我们找货
HHSC630ELL101MJC5S
  • 1+32.366001+4.18144
HHSC630ELL101MJC5S
    • 1+6.64200
    • 200+2.57040
    • 500+2.48400
    • 1000+2.44080
    HHSC630ELL101MJC5S
      库存:2000
