EMHK350ARA470MF80G
EMHK350ARA470MF80G
    NCC(贵弥功)
    径向,Can-SMD
    47 µF 35 V 铝电解电容器 径向,Can - SMD 300 毫欧 @ 400kHz 125°C 时为 2000 小时
EMHK350ARA470MF80G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MHK - High heat resistance, 125℃ New! Series ・ESR : Less than MHJ ・Endurance : 2,000 hours at 125℃ ・Specified ESR after endurance ・For automobile modules and other high temperature applications ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS Compliant MHK Lower ESR MHJ P116 ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +125℃ 35Vdc (at 20℃, 120Hz) ±20%(M) I=0.01CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minute) Rated voltage(Vdc) 35V tanδ (Max.) 0.14 (at 20℃, 120Hz) Rated voltage(Vdc) 35V Z(-25℃)/Z(+20℃) 2 Z(-40℃)/Z(+20℃) 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 125℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value ESR(Ω max./-40℃, 400kHz) 6.0 The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. impedance Ratio) Endurance Shelf life ◆DIMENSIONS [mm] ● Terminal ● Size Code : A code : F80 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.3 Size code F80 D 6.3 L 7.7 A±0.2 A 6.6 B 6.6 C 7.2 W 0.5 to 0.8 P 1.9 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 E MH K 3 5 0 A D A 11 12 13 14 15 16 17 18 M F80 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470,100µF:101) Taping code Terminal code Voltage code (ex.35V:350) Series code Category ◆MARKING EX) 35V47µF 3A 47 V HK ●Rated voltage symbol Rated voltage (Vdc) Symbol 35 V Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 118 CAT. No. E1001P SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MHKSeries New! - ◆STANDARD RATINGS WV (Vdc) Cap (µF) Size code 35 47 100 F80 F80 ESR (Ω max./100k to 400kHz) 20℃ -40℃ 0.30 0.30 3.0 3.0 Rated ripple current (mArms/125℃, 100k to 400kHz) 240 240 Part No. EMHK350ADA470MF80G EMHK350ADA101MF80G ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 47 to 100 120 0.40 1k 0.75 10k 0.90 100k 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 119 CAT. No. E1001P
EMHK350ARA470MF80G 价格&库存
很抱歉,暂时无法提供与“EMHK350ARA470MF80G”相匹配的价格&库存,您可以联系我们找货
EMHK350ARA470MF80G
  • 1+5.464241+0.68142
  • 10+3.4084910+0.42506
  • 50+2.5421050+0.31701
  • 100+2.26729100+0.28274
库存:786
EMHK350ARA470MF80G
  • 900+1.64166900+0.20473
  • 1800+1.534211800+0.19133
  • 2700+1.469412700+0.18325
  • 4500+1.384994500+0.17272
  • 6300+1.256756300+0.15673
  • 9000+1.252339000+0.15617
  • 10800+1.2137710800+0.15137
  • 21600+1.1975321600+0.14934
  • 22500+1.1971422500+0.14929
库存:786
