KHP500E226M555AT00
KHP500E226M555AT00
    NCC(贵弥功)
    2220(5750 Metric)
    22 µF ±20% 50V 陶瓷电容器 Y5U(E) 2220(5750 公制)
KHP500E226M555AT00 数据手册
METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS THP Series / TMP RoHS Compliant Series -2012 ※ (High Reliability) ◆FEATURES 1. Small size and large capacitance, high ripple current. 2. Excellent temperature cycle durability and most suitable for aluminum substrate. 3. Y5U temperature characteristics. 4. Excellent noise absorption. 5. For reflow soldering use. 6. Suitable for aluminum substrate. ◆APPLICATIONS 1. Smoothing circuit of switching mode AC-DC or DC-DC converter. 2. On-board power supply. 3. Noise suppressor for various kinds of equipments. ◆CUSTOM MADE PRODUCTS We can offer custom made one element metal cap type capacitors for request of customers. Please contact us if you have questions for details. ◆CONSTRUCTION Chip Ceramic Capacitor Metal Cap Soldering Termination ◆RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55∼+125℃ 25, 50, 100, 200Vdc 0.45 to 100µF M(±20%), Z(±80 20%) E(JIS) Y5U(EIA) See No.5 on the following table ◆SPECIFICATIONS No. Items Specification Test Condition 1 Withstand Voltage No abnormality. 250% of rated voltage shall be applied for 5 seconds. 2 Insulation Resistance 1000/CR(MΩ) or 10000(MΩ) whichever is less. Rated voltage shall be applied for 60±5 seconds at temperature 20±2℃. 3 Rated Capacitance Within specified tolerance. Temperature Frequency Voltage : 20±2℃ : 1±0.1kHz (≧100µF, 120Hz) : 1±0.2Vrms 4 Dissipation Factor 5.0% maximum Temperature Frequency Voltage : 20±2℃ : 1±0.1kHz (≧100µF, 120Hz) : 1±0.2Vrms 5 Rated Ripple Current Size Arms 43 1.5 55 3.0 76 4.0 10kHz∼1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. ※ This series is no more RoHS compliant as from January,2013. NTJ series are recommended for the new design and the substitution. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. (1/4) CAT. No. E1002R METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS THP Series / TMP Series ◆SPECIFICATIONS No. Items Specification Test Condition 6 Temperature Cycle Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. 7 Humidity Load Life Appearance : No abnormality. ΔC/C : ±20% D.F. : 7% max. I.R. : 50/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 40±2℃ Humidity : 90 to 95%RH Voltage : Rated voltage Time : 500±24 hours 0 8 Endurance Appearance : No abnormality. ΔC/C : ±20% D.F. : 7% max. I.R. : 100/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 85±2℃ Voltage : 200% of rated voltage. Time : 1000±48 0 hours Temperature (℃) Step Min. Category temperature ±3 1 Room temperature 2 3 Max. Category temperature ±3 4 Room temperature THP series : 100 cycles TMP series : 500 cycles (min.) 30±3 3 max. 30±3 3 max. Temperature : 125±3℃ Voltage : Rated voltage Time : 1000±48 0 hours *CR : Rated Capacitance(µF) ◆Note of mountig for THP series. 1. The face of wider gap between a capacitor and a substrate shall be the mounting face. 2. To prevent degredation of temperature cycling capability, if need to be careful about amount of solder that would not go into the inner side of terminations. Substrate Gap Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. (2/4) CAT. No. E1002R METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS THP Series ◆STANDARD RATINGS Dimensions(mm) 25 50 100 200 W Tmax. a Maximum ripple current (Arms) 4.8±0.4 3.5±0.3 5.5 1.3±0.3 1.5 6.0±0.4 5.0±0.4 4.5 1.3±0.3 3.0 6.6±0.5 5.6 6.5 1.5±0.3 4.0 4.8±0.4 3.5±0.3 5.5 1.3±0.3 1.5 6.0±0.4 5.0±0.4 1.3±0.3 3.0 7.8±0.5 4.5 5.6 7.8±0.5 6.6±0.5 6.5 1.5±0.3 4.0 4.8±0.4 3.5±0.3 5.5 1.3±0.3 1.5 6.0±0.4 5.0±0.4 4.5 1.3±0.3 3.0 1.5±0.3 4.0 7.8±0.5 6.6±0.5 5.6 6.5 4.8±0.4 3.5±0.3 5.5 1.3±0.3 1.5 6.0±0.4 5.0±0.4 4.5 5.6 1.3±0.3 3.0 7.8±0.5 6.6±0.5 6.5 1.5±0.3 4.0 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Previous Part Number KHP250E156M435AT00 KHP250E206M435AT00 KHP250E336M555AT00 KHP250E476M555AT00 KHP250E686M555AT00 KHP250E107M765BT00 KHP500E455M435AT00 KHP500E685M435AT00 KHP500E106M555AT00 KHP500E156M555AT00 KHP500E226M555AT00 KHP500E336M765BT00 KHP500E476M765BT00 KHP101E155M435AT00 KHP101E205M435AT00 KHP101E305M435AT00 KHP101E475M555AT00 KHP101E685M555AT00 KHP101E106M555AT00 KHP101E156M765BT00 KHP201E454M435AT00 KHP201E684M435AT00 KHP201E105M435AT00 KHP201E155M555AT00 KHP201E225M555AT00 KHP201E335M765BT00 KHP201E475M765BT00 THP50E1E156MT502 THP50E1E206MT502 THP60E1E336MT502 THP60E1E476MT502 THP60E1E686MT502 THP70E1E107MT502 THP50E1H455MT502 THP50E1H685MT502 THP60E1H106MT502 THP60E1H156MT502 THP60E1H226MT502 THP70E1H336MT502 THP70E1H476MT502 THP50E2A155MT502 THP50E2A205MT502 THP50E2A305MT502 THP60E2A475MT502 THP60E2A685MT502 THP60E2A106MT502 THP70E2A156MT502 THP50E2D454MT502 THP50E2D684MT502 THP50E2D105MT502 THP60E2D155MT502 THP60E2D225MT502 THP70E2D335MT502 THP70E2D475MT502 (Just for your reference) ◆DIMENSIONS ◆PART NUMBERING SYSTEM 1 Part Number 16 17 18 K HP 2 5 0 E 4 7 6 M 5 5 5A T 0 0 76 size 43, 55 size T L W Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category T 15 20 33 47 68 100 4.5 6.8 10 15 22 33 47 1.5 2.0 3.0 4.7 6.8 10 15 0.45 0.68 1.0 1.5 2.2 3.3 4.7 L L a W Rated voltage Rated Capacitance (Vdc) (µF) a Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. (3/4) CAT. No. E1002R METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS TMP Series ◆STANDARD RATINGS Dimensions(mm) Rated voltage Rated Capacitance (Vdc) (µF) 33 47 68 100 10 15 22 33 47 4.7 6.8 10 15 1.5 2.2 3.3 4.7 25 50 100 200 L W Tmax. a Maximum ripple current (Arms) 6.4±0.4 5.0±0.4 5.0 1.3±0.3 3.0 8.2±0.5 6.6±0.5 6.5 1.5v0.3 4.0 6.4±0.4 5.0±0.4 5.0 1.3±0.3 3.0 8.2±0.5 6.6±0.5 6.5 1.5±0.3 4.0 6.4±0.4 5.0±0.4 5.0 1.3±0.3 3.0 8.2±0.5 6.6±0.5 6.5 1.5±0.3 4.0 6.4±0.4 5.0±0.4 5.0 1.3±0.3 3.0 8.2±0.5 6.6±0.5 6.5 1.5±0.3 4.0 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Previous Part Number KMP250E336M555ET00 KMP250E476M555ET00 KMP250E686M765ET00 KMP250E107M765ET00 KMP500E106M555ET00 KMP500E156M555ET00 KMP500E226M555ET00 KMP500E336M765ET00 KMP500E476M765ET00 KMP101E475M555ET00 KMP101E685M555ET00 KMP101E106M765ET00 KMP101E156M765ET00 KMP201E155M555ET00 KMP201E225M555ET00 KMP201E335M765ET00 KMP201E475M765ET00 TMP60E1E336MT502 TMP60E1E476MT502 TMP70E1E686MT502 TMP70E1E107MT502 TMP60E1H106MT502 TMP60E1H156MT502 TMP60E1H226MT502 TMP70E1H336MT502 TMP70E1H476MT502 TMP60E2A475MT502 TMP60E2A685MT502 TMP70E2A106MT502 TMP70E2A156MT502 TMP60E2D155MT502 TMP60E2D225MT502 TMP70E2D335MT502 TMP70E2D475MT502 (Just for your reference) ◆DIMENSIONS ◆PART NUMBERING SYSTEM 1 Part Number 16 17 18 K MP 2 5 0 E 4 7 6 M 5 5 5 E T 0 0 T Spring mechanism L W Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category a Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. (4/4) CAT. No. E1002R
KHP500E226M555AT00 价格&库存
很抱歉,暂时无法提供与“KHP500E226M555AT00”相匹配的价格&库存,您可以联系我们找货
