AUDIO MODULE
FOR AUDIO GLASSES
DANUBE 5.0 UAM-P2050 | PRODUCT BRIEF
The Danube 5.0 audio module is an
easy-to-use kit for rapid prototyping of
smart eyewear. It provides the best-inclass ratio between audio performance
and the required mechanical volume
to enhance glasses with an appealing
sound in a 2-way audio system, by
combining a MEMS tweeter and an ED
woofer.
The module and its fixture are intended as a reference design for audio-enabled glasses, but can also be used as
a demonstrator for other wearable applications.
This module is an extension kit of the
development board Helike UA-E3010.
DANUBE FEATURES
Two-way audio system for high sound
quality
Tweeter: USound MEMS speaker Adap
Woofer: 15 x 8 x 2.5 mm electrodynamic
speaker
HELIKE DEVELOPMENT BOARD
FEATURES
Stand-alone mode (SD card playback)
Extension to Raspberry Pi platform via I2S
interface
Multiple supply options
Wide audio bandwidth: 300 Hz–20 kHz
SD card slot
High SPL at small space consumption
Joystick for playback control
Dipole configuration and optimized acoustic
design for maximum audio privacy over a
wide bandwidth
PACKAGE CONTENT:
Easy-to-use fixing mechanism for
reproducible positioning and measurements
The modules are symmetrical and can be
mounted on both sides of the test glasses.
Danube 5.0 set including left and right modules
Test glasses
Fixation set for repeatable mounting
2x 1 meter cable with pin connectors
NOTE: Helike UA-E3010 development board
is not included in the package.
Danube 5.0 UAM-P2050 Product brief
Released in November 2020
USound GmbH | www.usound.com | sales@usound.com
CONTENT
INTRODUCTION 3
SPECIFICATIONS 4
MEASUREMENT SETUP ON KEMAR
4
MECHANICAL DIMENSIONS
5
ELECTRICAL CONNECTIONS
6
ACOUSTIC PERFORMANCE ON KEMAR
6
REVISION HISTORY
2
INTRODUCTION
The Danube 5.0 audio module is an extension kit
that enables fast prototyping of smart eyewear. The
module consists of one MEMS tweeter and one electrodynamic woofer. It features USound’s patented dipole configuration for maximum directivity to the ear
canal, high SPL, and a compact form factor. It also
includes a magnetic fixture mechanism for an easy
attachment.
The module does not include electronics and it’s
advised to be used together with the development
board Helike. It requires two amplifier signals, one for
the MEMS speakers and one for the woofer, which
are provided by the Helike development board. The
board also includes a dedicated filter set-up which
can be applied to optimise the acoustic performance.
Additionally, these filters can be adjusted to meet a
specific target curve. The Helike UA-E3010 board
supports up to four Danube 5.0 in parallel — two left,
and two right modules can be connected and driven
simultaneously.
For more details on how to use the extension kit Danube 5.0 on the Helike development board, please refer to the Helike UA-E3010 user manual.
3
SPECIFICATIONS
Standard conditions: Module fixed on test glasses on KEMAR head.
Fixture mounted 5.5 cm distance from the glasses front plane (see image below).
Woofer driving: 1 VRMS
Tweeter driving: 15 VP (10.6 VRMS) + 15 VDC
Module on KEMAR - woofer without filters
Module on KEMAR - tweeter without filters
500 Hz
[dB]
82
2 kHz
[dB]
87
1 kHz
[dB]
88
4 kHz
[dB]
101
4 kHz
[dB]
111
8 kHz
[dB]
94
THD @ 400 Hz
11
THD @ 6.5 kHz
1.8
Nominal impedance
[Ω]
7
Capacitance @ 1 kHz / 15Vp
[nF]
38
5,5 cm
Figure 1: The fixture is placed on the temple as shown on the photo. The top
of the module coincides with the top of the temple.
4
General
Size (L x W x H)
[mm]
40 x 13 x 8
Woofer size
[mm]
15 x 8 x 2.5
Tweeter
size
6
[mm]
5
6.7 x 4.7 x 1.6
4
[g]
4.1
6
5
Weight
3
3
4
1
1
2
2
F
F
4
13
13
4
3
4
2
3
1
Tweeter
Tweeter
1
2
E
E
F
4
4
13
8
8
F
40
40
13
eeter
8
8
Figure 2:
Tweeter gasket
Tweeter gasket
Vent mesh
Vent mesh
Mechanical
drawings:
E
top/down/side view
Electrical
Electrical
connections
connections
Wires
Wires
40
weeter gasket
D
D
Back port
Back port
E
40
ent mesh
asket
Electrical
D
connections
Back port
h
Electrical
connections
Front mesh
Front mesh
Wires
C
C
D
Back port
Front port
Front port
(tweeter)
(tweeter)
Magnet
Magnet
Front port
Front port
(woofer)
(woofer)
C
Shell1
Shell1
B
B
C
mesh
Figure
Magnet
and
dimensions
millimeters.
accordance
withinDIN
ISO 2768
6
6
5
5
and dimensions in millimeters.
Front port
4
B
(woofer)
4
DIN ISO 2768
in millimeters.
CONFIDENTIAL
Property of
USound
CONFIDENTIAL
Property of
USound
ID:
REV DETAILS
DATE
2020.11.10 3 Cable included
INT. REF: Audio module
2020.10.06 2 Ports annotations
PROJECT: DANUVE (5v0)
ID:
2020.09.01
1
REV DETAILS
MATERIAL:
10 3 Cable included
INT.
REF:
Audio module
PURPOSE:
Illustration
USound
GmbH
scale the drawing. Unless
5 in
2 tolerancces
Ports annotations
PROJECT:
Kratkystrasse
2
DANUVE (5v0)
e06
specified,
8020 Graz, AUSTRIA
ance
01 with
1 DIN ISO 2768
MATERIAL:
www.usound.com
PURPOSE: Illustration
USound
GmbH
drawing. Unless
4
2
3
Kratkystrasse
2
d, tolerancces
in
8020 Graz, AUSTRIA
www.usound.com
CONFIDENTIAL
CONFIDENTIAL
Property of
Property
of
USound
USound
Magnet
Front mesh
Front port REV DETAILS
DRW DATE
DETAILS
REV
DRW
DATE
(tweeter)
included
3 Cable
IIR 2020.11.10
Cable
included
IIR 2020.10.06
2020.11.10
23 Ports
annotations
3:IIR
Mechanical
drawings:
perspective
view
2020.10.06 12 Ports annotations
IIR port
Front
2020.09.01
IIR
IIR 2020.09.01 1
(tweeter)
USound GmbH
Do not
scale
the drawing. Unless
Front
port
Kratkystrasse
2
otherwise
specified,
tolerancces
in B
USound GmbH
Do not scale
the drawing.
Unless
(woofer)
8020
Graz, AUSTRIA
accordance
with DINtolerancces
ISO 2768 in
Kratkystrasse
2
otherwise
specified,
www.usound.com
8020
Graz, AUSTRIA
www.usound.com
3
3
ID:
ID: REF: Audio module
INT.
INT. REF: DANUVE
Audio module
PROJECT:
(5v0)
MATERIAL:
MATERIAL:Illustration
PURPOSE:
2
2
Danube A5.0 UAM-P2050 Product brief
SHEET 1/1
1 A
SHEET 1/1
A
A
SHEET 1/1
1SHEET 1/1
1
Figure 4: The electrical connection is done with a 5-pole pin header. The middle pin is unused. With
this configuration, the pin order is directly compatible with Helike UA-E3010.
Danube With EQ
120
SPL [dBSPL]
100
80
60
40
300 400
600
1000
2000
3000 4000
6000
10000
20000
Frequency [Hz]
Note: Acoustic performance at 0dBFS with and without filters applied.
6
RELATED DOCUMENTATION
Helike UA-E3010 User manual
Helike UA-E3010 Datasheet
Adap UTP-2019 Datasheet
COMPATIBLE PRODUCTS OVERVIEW
Product name
Description
Helike UA-E3010
Development board for evaluating, rapid prototyping and designing
audio solutions using our MEMS speaker technology.
IMPORTANT NOTICE AND DISCLAIMER
USound GmbH (“USound”) makes no warranties for the use of USound products, other than those expressly
contained in USound’s applicable General Terms of Sale, located at www.usound.com. USound assumes no
responsibility for any errors which may have crept into this document, reserves the right to change devices or
specifications detailed herein at any time without notice, and does not make any commitment to update the
information contained herein. No license to patents or other intellectual property rights of USound are granted
in connection with the sale of USound products, neither expressly nor implicitly.
In respect of the intended use of USound products by the customer, the customer is solely responsible for observing existing patents and other intellectual property rights of third parties and for obtaining, as the case may be, the necessary licenses. For more information about USound patents visit
https://www.usound.com/patents/.
Important note: The use of USound products as components in medical devices and/or medical applications,
including but not limited to, safety and life supporting systems, where malfunctions of such USound products
might result in damage to and/or injury or death of persons is expressly prohibited, as USound products are
neither destined nor qualified for use as components in such medical devices and/or medical applications. The
prohibited use of USound products in such medical devices and/or medical applications is exclusively at the
risk of the customer.
7
很抱歉,暂时无法提供与“UAM-P2050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1396.284571+180.02650
