UMW
R
UMW 35N06
60V N-Channel Power Mosfet
General Description
These N-channel enhancement mode power mosfets used
advanced trench technology design, provided excellent Rdson
and low gate charge. Which accords with the RoHS standard.
Features
VDS = 60V,ID =35A
RDS(ON),23 mΩ(Typ) @ VGS =10V
RDS(ON),30 mΩ(Typ) @ VGS =4.5V
Fast Switching
Low ON Resistance(Rdson≤29mΩ)
Low Gate Charge
Low Reverse transfer capacitances
100% Single Pulse avalanche energy Test
Application
Power switch circuit of adaptor and charger;
LED backlight driver;
Synchronousrectification
Package Marking and Ordering Information
Device Marking
UMW 35N06
Device
Device Package
Reel Size
Tape width
Quantity
UMW 35N06
TO-252
330mm
12mm
2500
Absolute Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
35
A
24.5
A
IDM
100
A
EAS
56.2
mJ
PD
36.2
W
TSTG
-55 to +150
TJ
-55 to +150
TC=25℃
Continuous Drain Current
TC=100℃
Pulsed Drain Current 1)
Single Puise Avalanche Energy
2)
Maximum Power Dissipation
TC=25℃
Storage Temperature Range
Operating Junction Temperature Range
ID
Thermal Resistance
Parameter
Symbol
Min.
Typ.
Max
Unit
Thermal Resistance,Junction-to-Case
RθJC
3.45
℃/W
Thermal Resistance,Junction to Ambient
RθJA
111.5
℃/W
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW 35N06
Electrical Characteristics(TJ=25℃ unless otherwise noted)
OFF CHARACTERISTICS
Parameter
Symbol
Conditions
VGS=0V,IDS=250uA
Min.
Typ.
Max.
Unit
60
V
Drain-Source Breakdown Voltage
BVDSS
Zero Gate Voltage Drain Current
IDSS
VDS=60V,VGS=0V
1
uA
Gate-Body Leakage
IGSS
VGS=±20V,VDS=0V
±100
nA
ON CHARACTERISTICS
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
Gate Threshold Voltage
VGS(TH)
VDS=VGS,IDS=250uA
1
1.5
2
V
Drain-Source On-State Resistance
RDS(ON)
VGS=10V,IDS=19A
23
29
mΩ
VGS=4.5V,IDS=19A
30
38
mΩ
Conditions
Min.
Typ.
Max.
Unit
939
73.5
52.7
1.9
Ω
Min.
Typ.
Max.
Unit
8.4
8.5
35.4
4.8
21.2
3.6
5.5
DYNAMIC CHARACTERISTICS
Parameter
Symbol
Input Capacitance
CiSS
Output Capacitance
COSS
Reverse Transfer Capacitance
Crss
Gate Resisitance
Rg
VDS =30V, VGS = 0V,
f=1MHz
VDD=0V,VGS=0V,
F=1MHz
pF
SWITCHING CHARACTERISTICS
Parameter
Turn-On Delay Time
Rise Time
Symbol
Td(on)
tr
Turn-Off Delay Time
Fall Time
Conditions
VGS=10V,VDs=30V,
RGEN=3Ω
Td(off)
ID=20A
tf
Total Gate Charge
Qg
Gate to Source Gate Charge
Qgs
Gate to Drain“Miller”Charge
Qgd
VDS=30V,IDS=20A,
VGS=10V
ns
nC
DRAIN-SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
VSD
VGS=0V,IDS=20A
1.2
V
Reverse Recovery Time
trr
TJ=25℃,IF=20A
18.8
nS
Reverse Recovery Charge
Qrr
di/dt=100A/us
13.4
nC
Drain-Source Diode Forward Voltage
Notes:
1) Repetitive rating; pulse width limited by maximum junction temperature .
2) L=0.5mH,VDD=30V,Ias=15A Start TJ=25℃
3) Recommend soldering temperature defined by IPC/JEDEC J-STD 020
www.umw-ic.com
2
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 35N06
3
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 35N06
4
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 35N06
5
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 35N06
6
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 35N06
7
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 35N06
8
友台半导体有限公司
很抱歉,暂时无法提供与“35N06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.70824
- 100+0.47216
- 1250+0.43056
- 2500+0.39520
- 国内价格
- 5+0.87243
- 50+0.69077
- 150+0.59994
- 500+0.53180
- 2500+0.44993
- 5000+0.42261
