UMW
R
AO4486
N-Channel MOSFET
General Description
D
The AO4486 combines advanced trench MOSFET
technology with a low resistance package to provide
extremely low RDS(ON).This device is ideal for boost
converters and synchronous rectifiers for consumer,
telecom, industrial power supplies and LED backlighting.
G
Product Summary
S
VDS (V) = 100V
ID = 4.2A
RDS(ON) < 79mΩ (VGS = 10V)
RDS(ON) < 94mΩ (VGS = 4.5V)
Absolute Maximum Ratings TA=25°C unless otherwise noted
Symbol
Parameter
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
TA=25°C
Continuous Drain
Current
Units
V
±20
V
4.2
ID
TA=70°C
Maximum
100
3.4
A
Pulsed Drain Current C
IDM
31
Avalanche Current C
IAS, IAR
14
A
Avalanche energy L=0.1mH C
TA=25°C
EAS, EAR
10
mJ
Power Dissipation
B
TA=70°C
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
Maximum Junction-to-Ambient A D
Maximum Junction-to-Lead
www.umw-ic.com
3.1
PD
-55 to 150
TJ, TSTG
Symbol
t ≤ 10s
Steady-State
Steady-State
W
2
Typ
31
59
16
RθJA
RθJL
1
°C
Max
40
75
24
Units
°C/W
°C/W
°C/W
UTD Semiconductor Co.,Limited
UMW
R
AO4486
N-Channel MOSFET
Electrical Characteristics (TJ=25°C unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
ID=250µA, VGS=0V
IDSS
Zero Gate Voltage Drain Current
IGSS
Gate-Body leakage current
VDS=0V, VGS= ±20V
VGS(th)
Gate Threshold Voltage
VDS=VGS ID=250µA
1.6
ID(ON)
On state drain current
VGS=10V, VDS=5V
31
RDS(ON)
Static Drain-Source On-Resistance
Min
100
Typ
VDS=100V, VGS=0V
TJ=55°C
Max
Units
V
1
µA
5
2.2
±100
nA
2.7
V
A
VGS=10V, ID=5A
69
79
mΩ
VGS=4.5V, ID=3A
82
94
mΩ
V
gFS
Forward Transconductance
VDS=5V, ID=3A
VSD
Diode Forward Voltage
IS=1A,VGS=0V
0.74
1
3.5
A
620
778
942
pF
VGS=0V, VDS=50V, f=1MHz
38
55
81
pF
13
24
35
pF
VGS=0V, VDS=0V, f=1MHz
0.7
1.45
2.2
Ω
S
IS
Maximum Body-Diode Continuous Current
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
Qg(10V)
Total Gate Charge
13
16.3
nC
Qg(4.5V) Total Gate Charge
6.4
8.1
10
nC
2.2
2.8
3.4
nC
2.4
4.1
5.8
nC
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
tD(on)
Turn-On DelayTime
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
trr
Qrr
VGS=10V, VDS=50V, ID=3.0A
6
=16.7Ω,
VGS=10V, VDS=50V, RL=16.7Ω
RGEN=3Ω
ns
2.5
ns
ns
21
2.4
IF=3A, dI/dt=500A/µs
Body Diode Reverse Recovery Time
Body Diode Reverse Recovery Charge IF=3A, dI/dt=500A/µs
ns
ns
14
21
28
65
94
123
ns
nC
A. The value of RθJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The
value in any given application depends on the user's specific board design.
B. The power dissipation PD is based on TJ(MAX)=150°C, using ≤ 10s junction-to-ambient thermal resistance.
C. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150°C. Ratings are based on low frequency and duty cycles to keep
initialTJ=25°C.
D. The RθJA is the sum of the thermal impedence from junction to lead RθJL and lead to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AO4486”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.31696
- 50+1.03011
- 150+0.90720
- 500+0.75384
- 3000+0.66431
- 6000+0.62327
