GBLC12CI-LF-T7
GBLC12CI-LF-T7
    UMW(友台)
    SC-76
    19V 夹子 1A(8/20µs) Ipp TVS - 二极管 表面贴装型 SOD-323
GBLC12CI-LF-T7 数据手册
UMW R GBLCxxI/CI DESCRIPTION The GBLCxxI and GBLCxxCI Series are ultra low capacitance transient voltage suppressor arrays, designed to protect applications such as portable electronics and SMART phones. This series is available in both unidirectional and bidi-rectional configurations and is rated at 250W for an 8/20µs waveshape. The GBLCxxI and GBLCxxCI Series meets IEC 61000-4-2 (ESD) and IEC 61000-4-4 (EFT) requirements. At higher operat-ing frequencies or faster edge rates, insertion loss and signal integrity are a major concern. This series offers a ultra low capacitance and low leakage current in a miniature SOD-323 package. 1 1 2 UNIDIRECTIONAL 2 BIDIRECTIONAL APPLICATIONS FEATURES ■ Ethernet 10/100/1000 Base T ■ SMART Phones ■ Compatible with IEC 61000-4-2 (ESD): Air - 15kV, Contact - 8kV Exceeds Level 4: Handles 10kV Contact & 25kV Air Discharge ■ Compatible with IEC 61000-4-4 (EFT): 40A - 5/50ns 250W Peak Pulse Power per Line (tp = 8/20µs) ■ Replacement for MLV (0805) ■ Unidirectional & Bidirectional Configurations ■ Handheld - Wireless Systems ■ USB Interface MACHANICAL DATA ■ Molded JEDEC SOD-323 Package ■ Approximate Weight: 5 milligrams ■ Protects One Power or I/O Port ■ ESD Protection > 25kV ■ Lead-Free Pure-Tin Plating (Annealed) ■ Low Clamping Voltage ■ Available in Multiple Voltages Ranging From 3V to 24V ■ Solder Reflow Temperature: Pure-Tin - Sn, 100: 260-270°C ■ Ultra Low Capacitance: 0.6pF (Typical) ■ 8mm Tape and Reel Per EIA Standard 481 ■ Flammability Rating UL 94V-0 ■ RoHS Compliant ■ REACH Compliant ■ Patent Pending TYPICAL DEVICE CHARACTERISTICS MAXIMUM RATINGS @ 25°C Unless Otherwise Specified PARAMETER SYMBOL VALUE UNITS Peak Pulse Power (tp = 8/20µs) - See Figure 1 PPP 250 W Operating Temperature TA -55 to 150 °C Storage Temperature TSTG -55 to 150 °C www.umw-ic.com 1 友台半导体有限公司 UMW R GBLCxxI/CI ELECTRICAL CHARACTERISTICS PER LINE @ 25°C Unless Otherwise Specified RATED STAND-OFF VOLTAGE MINIMUM BREAKDOWN VOLTAGE MAXIMUM LEAKAGE CURRENT TYPICAL CAPACITANCE @ 1mA V(BR) VOLTS MAXIMUM CLAMPING VOLTAGE (Fig. 2) @ IP = 1A VC VOLTS VWM VOLTS @VWM ID µA @0V, 1MHz C pF GBLC03I 3.0 4.0 7.0 5 0.6 GBLC03CI 3.0 4.0 7.0 5 0.6 GBLC05I 5.0 6.0 9.8 5 0.6 GBLC05CI 5.0 6.0 9.8 5 0.6 GBLC08I 8.0 8.5 13.4 2 0.6 GBLC08CI 8.0 8.5 13.4 2 0.6 GBLC12I 12.0 13.3 19.0 1 0.6 GBLC12CI 12.0 13.3 19.0 1 0.6 GBLC15I 15.0 16.7 24.0 1 0.6 GBLC15CI 15.0 16.7 24.0 1 0.6 GBLC18I 18.0 20.0 29.0 1 0.6 GBLC18CI 18.0 20.0 29.0 1 0.6 GBLC24I 24.0 26.7 43.0 1 0.6 GBLC24CI 24.0 26.7 43.0 1 0.6 PART NUMBER (Note 1 -2) NOTES 1. Part numbers with an additional “C” suffix are bidirectional devices, i.e., GBLC05CI. 2. Unidirectional Only: Positive potential is applied from pin 1 to 2. www.umw-ic.com 2 友台半导体有限公司 UMW R GBLCxxI/CI TYPICAL DEVICE CHARACTERISTICS FIGURE 1 PEAK PULSE POWER VS PULSE TIME PPP - Peak Pulse Power - Watts 10,000 1,000 250W, 8/20µs Waveform 100 10 0.1 1 10 100 1,000 10,000 t d - Pulse Duration - µs FIGURE 2 PULSE WAVE FORM IPP - Peak Pulse Current - % of IPP 120 TEST WAVEFORM PARAMETERS t f = 8µs t d = 20µs Peak Value IPP 80 e-t 60 40 td = t/(IPP/2) 20 0 www.umw-ic.com tf 100 0 5 10 15 t - Time - µs 3 20 25 30 友台半导体有限公司 UMW R GBLCxxI/CI SPICE MODEL FIGURE 1 SPICE MODEL I/O I/O ABD ABD LCRD LCRD ABD LCRD LCRD Lg 0.6nH Lg 0.6nH UNIDIRECTIONAL BIDIRECTIONAL ABD - Avalanche Breakdown Diode (TVS) LCRD: Low Capacitance Rectifier Diode Lg - Lead Inductance TABLE 1 - SPICE PARAMETERS PARAMETER UNIT ABD(TVS) LCRD BV V See Table 2 100 IBV µA Cjo pF See Table 2 0.3 See Table 2 1E-11 0.5 IS A Vj V 0.6 0.6 M - 0.33 0.33 N - RS Ohms See Table 2 0.75 TT s 1E-8 1E-9 EG eV 1.11 1.11 PART NUMBER www.umw-ic.com 1 1 1 TABLE 2 - ABD SPECIFIC SPICE PARAMETERS IS (AMPS) B V(VOLTS) Cjo(pF) Rs(OHMS) GBLC03I 4.0 200 1E-11 0.22 GBLC05I 6.0 140 1E-11 0.18 GBLC08I 8.5 67 1E-11 0.12 GBLC12I 13.3 55 1E-13 1.10 GBLC15I 16.7 47 1E-13 1.43 GBLC18I 20.0 40 1E-13 2.30 GBLC24I 26.7 28 1E-13 4.24 GBLC03CI 4.0 200 1E-11 0.22 GBLC05CI 6.0 140 1E-11 0.18 GBLC08CI 8.5 67 1E-11 0.12 GBLC12CI 13.3 55 1E-13 1.10 GBLC15CI 16.7 47 1E-13 1.43 GBLC18CI 20.0 40 1E-13 2.3 GBLC24CI 26.7 28 1E-13 4.24 4 友台半导体有限公司 UMW R GBLCxxI/CI SOD-323 PACKAGE OUTLINE DIMENSIONS OUTLINE DIMENSIONS C A DIM E B F D H MILLIMETERS INCHES MIN MAX MIN MAX A 1.60 1.90 0.063 0.075 B 1.15 1.45 0.045 0.057 C 2.39 2.70 0.094 0.106 D 0.80 1.10 0.031 0.043 E 0.25 0.40 0.010 0.016 F 0.10 0.20 0.004 0.008 H - 0.10 - 0.004 L 0.20 - 0.008 - NOTES 1. Controlling dimension: millimeters. 2. Dimensioning and tolerances per ANSI Y14.5M, 1985. 3. Dimensions are exclusive of mold flash and metal burrs. L Marking 1 CC 2 Ordering information Order code Marking code Package Baseqty Deliverymode UMW GBLC03I-LF-T7 C SOD-323 3000 Tape and reel UMW GBLC03CI-LF-T7 CC SOD-323 3000 Tape and reel UMW GBLC05I-LF-T7 A SOD-323 3000 Tape and reel UMW GBLC05CI-LF-T7 AC SOD-323 3000 Tape and reel UMW GBLC08I-LF-T7 B SOD-323 3000 Tape and reel UMW GBLC08CI-LF-T7 BC SOD-323 3000 Tape and reel UMW GBLC012I-LF-T7 D SOD-323 3000 Tape and reel UMW GBLC012CI-LF-T7 DC SOD-323 3000 Tape and reel UMW GBLC015I-LF-T7 E SOD-323 3000 Tape and reel UMW GBLC015CI-LF-T7 EC SOD-323 3000 Tape and reel UMW GBLC018I-LF-T7 F SOD-323 3000 Tape and reel Tape and reel UMW GBLC018CI-LF-T7 FC SOD-323 3000 UMW GBLC024I-LF-T7 H SOD-323 3000 Tape and reel UMW GBLC024CI-LF-T7 HC SOD-323 3000 Tape and reel www.umw-ic.com 5 友台半导体有限公司
GBLC12CI-LF-T7
PDF文档中包含以下信息:
1. 物料型号:型号为LM3S6965。
2. 器件简介:LM3S6965是一款基于ARM Cortex-M3内核的32位微控制器,适用于工业控制、消费电子等领域。
3. 引脚分配:该微控制器有100个引脚,包括电源、地、I/O、通信接口等。
4. 参数特性:工作电压范围为2.0V至3.6V,最大工作频率为50MHz。
5. 功能详解:包括中断管理、定时器、串行通信接口等。
6. 应用信息:适用于需要高性能处理和低功耗的应用场景。
7. 封装信息:采用LQFP100封装。
GBLC12CI-LF-T7 价格&库存
很抱歉,暂时无法提供与“GBLC12CI-LF-T7”相匹配的价格&库存,您可以联系我们找货
