SN74LVC1G00DCKR
SN74LVC1G00DCKR
    UMW(友台)
    TSSOP5,SC70-5,SOT353
    与非门 IC 1 通道 SC-70-5
SN74LVC1G00DCKR 数据手册
UMW ■ R SN74LVC1G00 Product introduction SN74LVC1G00 is a 2-input NAND integrated circuit, which can realize the mathematical logic operation of and . Advanced CMOS process design is adopted, which has the working characteristics of low power consumption and high output driving capability. The chip can work normally when the power supply voltage VCC is between 1.65V and 5.5V V. And 74LVC1G00 has a variety of small package shapes,It can be widely used in high-end precision instruments, miniaturized low-power handheld devices, artificial intelligence and other fields. ■ Product features ● ● ● ■ Low static power consumption: 0.1uA typical ● Wide working voltage range: 1.65V to 5.5V Package form: DBV/DCK/DRL/YZP/ DRY/DSF/ DPW High output drive: VCC=4.5V, more than 32MA product usage ● ● ● ■ ● Low input current: 0.1uA typical Portable audio interface ● Blu-ray player and home theater digital television ● Solid state drive Wireless headphones, smart watches, etc. ● Smart wearable devices Package form and pin function definition SOT23-5 SC70-5 SOT-553 SOT-886 SON-6 DSBGA-5 X2SON-5 Pin Name DBV/ DCK/ DRL DRY/DSF YZP DPW Description NC 1 1,5 A1, B2 1 Empty foot A 2 2 B1 2 Input GND 3 3 C1 3 Y 4 4 C2 4 VCC 5 6 A2 5 Power supply ground Output Power supply positive Note: NC null pin, no connecting wire inside. www.umw-ic.com 1 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW ■ R SN74LVC1G00 Limit parameter parameter symbol limit value 6.5 unit operating voltage VCC input VIN -0.5~6.5 V Output voltage (1) VOUT -0.5~6.5 V Single pin output current Or Vcc current. IOUT 25 mA ICC 50 mA Storage temperature TS -65-150 ℃ Pin welding temperature TW 260,10s ℃ V Note: 1. In the power-off state of VCC=0V, the limit voltage that the output can bear, 2. Limit parameter refers to the limit value that can't be exceeded under any conditions. If it exceeds this limit value, it may cause physical damage such as product deterioration; At the same time, the chip can't work normally when it is close to the limit parameters. ■ Principle logic diagram ■ truth table Inputs A B L L L H H L H H ■ Output Y H H H L working conditions project operating voltage symbol VC test condition minimum value 1.65 typical value - 0.65* VC - - 1.7V - - VC =3V~5.5V 0.7* VC - - VC =1.65V~1.95V - - VC =2.3V~2.7V - - 0.7 VC =3V~5.5V - - 0.3* VC VC =1.65V~1.95V Input high level voltage Input high level voltage input voltage Output voltage High level output current Low level output current www.umw-ic.com VHI VHI VC =2.3V~2.7V maximum 5.5 unit V V 0.35* VC V VI - 0 - 5.5 V VO - 0 - VC V VC =1.65V - - -4 VC =2.3V - - -8 VC =3V - - -16 VC =4.5V - - -32 VC =1.65V - - 4 VC =2.3V - - 8 VC =3V - - 16 VC =4.5V - - 32 IOH IOL 2 mA mA UTD Semiconductor Co.,Limited semiconductor co., ltd UMW ■ R SN74LVC1G00 Electrical characteristics Electrical characteristics of DC: T =25℃ A project symbol High level load voltage VOH Low level load voltage incoming current Turn-off current operational current Working current variation value Ac electrical characteristics: project VOL A II B IOFF V test condition typical value maximum IOH =-100uA 1.65V~5.5V 1.64 - IOH =-4 mA 1.65V 1.47 - IOH =-8 mA 2.3V 2.15 - IOH =-16 mA 3V 2.73 - IOH =-32 mA 4.5V 4.0 IOH =100uA 1.65V~5.5V 0.01 - IOH =4 mA 1.65V 0.11 - IOH =8 mA 2.3V 0.11 - IOH =16 mA 3V 0.2 - IOH =32 mA 4.5V 0.35 - 0~5.5V 0.01 ±5 0.01 ±5 VI =5.5V 或 GND unit V V uA VI VI =5.5V 0 0.01 ±10 VO VO =5.5V 0 0.01 ±10 0.01 10 0.01 10 25 - uA 25 - uA ICC ICC VI =5.5V,IO =0 1.65V~5.5V VI =GND ,IO =0 A=VCC -0.6V B=VCC 或 GND uA uA 3V~5.5V B=VCC -0.6V A= VCC 或 GND Ta=25℃ V(298)=5.0V,tr =≤20ns. See test method. symbol Maximum transmission delay time a, B test condition minimum value typical value maximum unit C =15pF - 10 - ns C =15pF - 10 - ns to Y Note: 1. CL capacitor is external chip capacitor (0603), which is connected close to the output pin, and the capacitor ground is close to the chip GND; 2. Input: port input level, f=500kHz,D=50%; tr=tf≤20ns; 3. Output: Y-terminal output test. www.umw-ic.com 3 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW R SN74LVC1G00 ■ Encapsulated information DBV(SOT23-5) ■ Marking C00K www.umw-ic.com 4 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW R SN74LVC1G00 DCK(SC70-5) ■ Marking www.umw-ic.com 5 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW R SN74LVC1G00 DRL(SOT-553) www.umw-ic.com 6 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW R SN74LVC1G00 DRY(SOT-886) www.umw-ic.com 7 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW R SN74LVC1G00 DSF(SON-6) www.umw-ic.com 8 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW R SN74LVC1G00 YZP(DSBGA-5) www.umw-ic.com 9 UTD Semiconductor Co.,Limited semiconductor co., ltd UMW R SN74LVC1G00 DPW(X2SON-4) www.umw-ic.com 10 UTD Semiconductor Co.,Limited semiconductor co., ltd
SN74LVC1G00DCKR 价格&库存
很抱歉,暂时无法提供与“SN74LVC1G00DCKR”相匹配的价格&库存,您可以联系我们找货
