92100142
92100142
    VECTOR
    封闭式 AC DC 转换器 4 输出 5V 3.3V 12V -12V 90 ~ 264 VAC 输入
92100142 数据手册
11115 Vanowen Street, North Hollywood, CA 91605 Ph.: 818-985-8208 FAX: 818-985-7708 VECTOR PART NUMBER 92100142 CompactPCI ® 500 Watt – 6U 8HP Power Supplies ® (PICMG COMPLIANT*) Features:  Standard PCI Output Voltages: 5.0V, 3.3V, ±12.0V.  Hot Swap, N+1 Redundant with Internal OR-ing MOSFETs.  Input: >.99 Power Factor Corrected AC 90-264V, or DC 36-72V.  Current Sharing on 5.0V, 3.3V and +12.0V Outputs.  Standard 47 Pin Connector Configuration.  Custom Configurations To Meet User Specified Requirements.  Excellent Performance, Competitively Priced.  2 Year Warranty.  Complies With All Requirements Of PICMG Power Interface Specifications.  Fully Compliant with the EU RoHS Directive.  cCSAus, CE Marked. *CompactPCI® and PICMG® are registered trademarks of the PCI Industrial Computer Manufacturers Group. Cat.# 02127-049 B 11115 Vanowen Street, North Hollywood, CA 91605 Ph.: 818-985-8208 FAX: 818-985-7708 GENERAL PRODUCT SPECIFICATIONS: Over Current/Short Circuit Protection ............Current limit on all outputs, 120-130% max load Voltage/Current .............. AC 90-264V, 7.0A max, 47-63Hz, 1 Phase typical. Recycle input power required to recover. Over Voltage Protection .......................Non-crowbar type. Any output that exceeds Fusing ............................ Internal line fuse provided, non-user serviceable. 25% ±10% of nominal Vout will cause all outputs to latch off. Remote inhibit, enable or input AC Power Factor ............ Meets Harmonic Correction per IEC 1000-3-2. recycle required to reset. 0.99 line PFC typical at AC 115V, full load. -INPUT- Efficiency ........................ AC 77-80% typical at 115V, full load. Inrush Current ................ Soft start, ~25ºC cold start current: AC 30.6A (rms) @ 230V Input Voltage Protection (UVP/OVP) .... Auto DC output shutdown when input rises or falls below safe operating limits. Automatic recovery when input returns to within normal operating range. AC: UVP ≈ 80V. -OUTPUTS- -SIGNALS, INDICATORS and CONTROLSRemote Enable ...............Enabled by closed circuit or TTL logic 0. Disabled by open circuit or TTL logic 1. Remote Inhibit ................Enabled by open circuit or TTL logic 1. Disabled by closed circuit or TTL logic 0. Power Fail Warning ........Loss of input AC causes a TTL compatible signal to go low >4msec prior to V1 or V2 output dropping out of regulation. At AC turn-on, signal stays low until outputs are in regulation. PF signal also triggered in both AC and DC input models by any output under dropping below 10% of nominal. LED Indicator..................Dual LEDs. Green indicates input power ON and Voltage/Current (V/A) ........... V1 V2 V3 V4 outputs within regulation. Off or Amber indicates AC: 92100142 5.0/50, 3.3/30, +12/10(15pk), –12/3.0(5pk). input and/or output power fault. Total continuous loading on all outputs not to exceed 500W. Switch, On/Off Peak loading
92100142 价格&库存
很抱歉,暂时无法提供与“92100142”相匹配的价格&库存,您可以联系我们找货
