5261316-07
5261316-07
    VECTOR
    PANEL FILLER 6UX16HP ASSEMBLY
5261316-07 数据手册
CATALOG 128_CATALOG 128.qxd 4/24/2014 10:14 AM Page 38 Non EMC DIN-Based VectorPaktmSubracks Front Panels Screw-mounted front panel kits include handle and identification panel. Available in 3U, 6U and 9U heights and in three widths: 4HP (0.788”), 8HP (1.588”) and 12HP (2.388”). All mounting hardware, including board mounting support bracket and hardware also included. Brushed aluminum panel with clear irridite plating matches standard finish for Vector packaging products. Front Panels, Ejector Style, Type II (MHFWRU.QRE )URQW3DQHO ,'3ODWH &DSWLYH6FUHZ 5HWDLQHU6OHHYH 3&%RDUG / %UDFNHW Non EMC Subracks Part # DESCRIPTION FPE04-3U 3U X 4HP FPE08-3U 3U X 8HP FPE12-3U 3U X 12HP FPE04-6U 6U X 4HP FPE08-6U 6U X 8HP FPE12-6U 6U X 12HP FPE04-9U 9U X 4HP FPE08-9U 9U X 8HP FPE12-9U 9U X 12HP A 5.06” 5.06” 5.06” 10.31” 10.31” 10.31” 15.56” 15.56” 15.56” B 0.788” 1.588” 2.388” 0.788” 1.588” 2.388” 0.788” 1.588” 2.388” C N/A N/A N/A 3.50” 3.50” 3.50” 3.50” 3.50” 3.50” D N/A N/A N/A 5.25” 5.25” 5.25” 5.25” 5.25” 5.25” -Add suffix “B” to part # for panels without center brackets mounting, e.g. FPE04-6UB Front Panels, Fixed Handle Style, Type V Type V, 3U Fixed Handle Style 5HWDLQHU6OHHYH 0[&DSWLYH 6FUHZ 0[)ODW +HDG6FUHZ 0[ )LOLVWHU+HDG 6FUHZ ,'3ODWH / %UDFNHWV 0[)LOLVWHU +HDG6FUHZ 3ODVWLF+DQGOH 3&%RDUG 0[ +H[1XW Part # DESCRIPTION A FP04-3U 3U X 4HP 5.06” FP08-3U 3U X 8HP 5.06” FP12-3U 3U X 12HP 5.06” FP04-6U 6U X 4HP 10.31” FP08-6U 6U X 8HP 10.31” FP12-6U 6U X 12HP 10.31” FP04-9U 9U X 4HP 15.56” FP08-9U 9U X 8HP 15.56” FP12-9U 9U X 12HP 15.56” B 0.788” 1.588” 2.388” 0.788” 1.588” 2.388” 0.788” 1.588” 2.388” -Fixed Handle Style front panel kit includes upper and lower handles (lower only on 3U versions) that extend across the full width of the panel 38 Specification subject to change without notice www.vectorelect.com 800-423-5659 CATALOG 128_CATALOG 128.qxd 4/25/2014 9:31 AM Page 39 Non EMC DIN-Based VectorPaktmSubracks Custom Front Panels Whether you need standard panels, modified, or custom front panels, we have manufacturing capabilities to support your needs. Vector Electronics’s custom aluminum front panels offer a wide range of design opportunities. Cost effective punching for volume production. Customization : • Panel cutouts • Silkscreening • Powder coating • Special Finishing Filler Panels/Blank-off Plates Features 94300008 95000002B Captive sleeves/screws are included with all VectorPaktm filler panels and also sold separately in a hardware kit: P/N HD99-1 Includes Black plastic sleeve M2.5 x 11 mm,nickel plated steel screw Qty 48 48 Non EMC Subracks Standard Filler Panels • Covers unused slots • Improves air flow • Mounting hardware included Typical slot width is 0.800” (4HP) Material: 6063T5, extruded brushed Aluminum with clear Irridite finish. Each Filler Panel Kit Includes 4,8 or 12HP panel (0.8”, 1.6” or 2.4”) M2.5 Nickel plated mounting screws with ‘captive’ sleeves U 3 6 9 Part Number Part Number 4HP 8HP 12HP 5231304-07 5261304-07 5291304-07 5231308-07 5261308-07 5291308-07 5231312-07 5261312-07 5291312-07 www.vectorelect.com Part Number 800-423-5659 39 IN349C 2 x.123 2 x.294 .600 60 .7 60 8HP = 1.5 + ) HP P = 4HP .360 4 H = (2 8 P H 12 12HP ID Plate 8HP Handle Top Handle only for 6U & 9U .630 4HP Handle A Optional for 6U & 9U High Panel VECTOR P/N# HD102 Shown 12HP Bottom Handle Configuration M2.5 x 8 Flat Head Screw M2.5 x 10 Filister Head Screw .110 x .150 OBROUND 2 x.294 2 x.123 B Retainer Sleeve 'L' Brackets ID Plate HP 6U-8 M2.5 x 16 Filister Head Screw .277 Washer Plastic Handle PC Board 'L' Bracket Detail .372 .285 .240 .454 M2.5 x 11 Captive Screw 3U-8HP ALL DIMENSIONS ARE IN INCHES TOLERANCE : .XXX .010 .340 M2.5 x 0.45 Hex Nut .645 .170 11115, VANOWEN STREET, NORTH HOLLYWOOD, CA-91605 PHONE : (818)985-8208 FAX : (818)985-7708 www.vectorelect.com 11115 Vanowen Street, North Hollywood,CA 91605 Phone: (818) 985-8208 Fax: (818) 985-7708 IN399 1.090 0.779 0.080 0.427 0.166 0.164 0.176 0.325 0.439 0.200 x 0.200 CUTOUT 0.120 0.075 0.150 RAD. 0.509 0.222 0.235 0.159 0.563 0.465 0.586 0.257 0.170 0.174 0.559 0.945 Ejector Knob THRU 0.237 R 0.170 Front Panel ID Plate Captive Screw Retainer Sleeve 'L' - Bracket PC Board FPE04-6U PANEL WILL HAVE TWO CENTER HOLES FOR OPTIONAL 3U 'L' BRACKETS. ORDER FPE04-6UB FOR PANEL WITHOUT THE CENTER HOLES. 0.311
5261316-07 价格&库存
很抱歉,暂时无法提供与“5261316-07”相匹配的价格&库存,您可以联系我们找货
