ENTUBE DE (1500V 10V)
    VERIVOLT
    电压变送器 ±1500V 输入 ±10V 输出 DIN 轨道
ENTUBE DE (1500V 10V) 数据手册
Entube DE Double Ended - Line to Line Voltage Sensor OVERVIEW The Entube-de series is a family of voltage transducers designed for high quality differential measurements in a very compact form factor, and without need for power supplies. This series covers the ranges of ±50V to ±1500V with up to 50kHz bandwidth and up to 0.2% of signal accuracy. The Entube-de sensor operates as a differential divider RC-network with an anti-aliasing filter on its output. It generates a ±5V or ±10V scaled down version of the difference between the two input voltages, which can then be processed by a computer based measurement system. The Entube-de is part of Verivolt’s sensing platform, which is aimed at allowing users to laid out multiple distributed sensors with a minimum of cabling required and no power supplies. This platform together with the Entube-de ultra-compact form factor, allows for very high channel densities, while delivering high performance for a low cost. SPECIFICATION Entube DE 100V Bandwidth (-3dB point) 200V Gain (Using 10V standard output voltage) Input Impedance 500V 750V 50kHz 1000V < 60μV < 100 μV < 130 μV < 170 μV < 220 μV < 290 μV 10 20 30 40 50 75 100 25kΩ 33kΩ 20kΩ 20kΩ 50kΩ > 2 MΩ Eletrical 1500V 25kHz < 30 μV > 1 MΩ Line Output Impedance 25kΩ HARDWARE DESCRIPTION The Entube-TE is a differential voltage down-converter designed for 3-phase systems. It outputs all line-to-line and line-to-ground signal pairs. Delta or Wye measurements can be made depending on the input configuration of the digitizer being used (NRSE or Differential). < 400 μV 150 > 3 MΩ 15kΩ 10kΩ Integrated sensor noise (Referenced to input) Accuracy (percentage of reading) ±0.2% (±0.05% Typical) Gain (Using 10V standard output voltage) Max total phase shift at 60Hz < 0.05° Common mode rejection ±2000V Withstanding differential mode surge voltage ±1000V Input-Output non-linearity Output voltage Gain temperature drift Mounting Type DIN Rail Connectivity In Clamp cage Connedtivity Out Spring cage < 250 ppm ±5V (±10V optional) ±50 ppm/°C Differential input dynamic range Signal Layout Common mode rejection 52 dB Power Supply Voltage None Output type Output Offset Voltage Mechanical Weight 400V 85kHz Integrated sensor noise (Referenced to input) Outer Dimensions 300V Double-ended signal < ± 10µV (on ±10V signal) Environmental Operating temperature – 25 to 70 °C Storage temperature – 40 to 80 °C The two input phases connect to the sensor via a Spring-cage, while the conditioned signals from the sensor come out on a standard screw terminals. The Entube DE can be mounted anywhere between the signal source and the data acquisition system. A female-screw on the low voltage side of the sensor allows for DIN rail mounting, and serves as a safety ground. A twisted pair should be used to carry the conditioned signals from the sensor. This will keep good resolution beyond the 10th harmonic on a typical 60Hz system. 1.4” x 1.4” x 4.5” 198 g (7.0 oz) 650 Washington St, San Francisco, CA 94111 70VERIVOLT (708) 374-8658 1 MERCHANICAL DIMENSIONS HARDWARE CONFIGURATION A. Safely connect Data Acquistion ground to ground of sensor. A Standards and Certifications ● CE ● RoHS Compliant B. Securely connect one end of a twisted pair to the output terminals, and the other end to the inputs of your breakout board or data acquisition unit C. Securely connect wire between the source of measurement and an available Entube DE’s input clamp cage. C B DANGER THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage. 2
ENTUBE DE (1500V 10V) 价格&库存
很抱歉,暂时无法提供与“ENTUBE DE (1500V 10V)”相匹配的价格&库存,您可以联系我们找货
  • 1+4092.645121+529.29030
