ENTUBE SE (300V 10V) 数据手册
Entube SE
Single Ended - Voltage Sensor
OVERVIEW
The Entube SE series is a family of voltage transducers designed for high quality single ended measurements in a very compact form factor, and without need for power supplies. This series covers
the ranges of ±50V to ±2000V with up to 50kHz bandwidth and up to 0.2% of signal accuracy.
The Entube-de sensor operates as a differential divider RC-network with an anti-aliasing filter on
its output. It generates a ±5V or ±10V scaled down version of the difference between the two input
voltages, which can then be processed by a computer based measurement system.
The Entube SE is part of Verivolt’s sensing platform, which is aimed at allowing users to laid out
multiple distributed sensors with a minimum of cabling required and no power supplies. This platform together with the Entube-de ultra-compact form factor, allows for very high channel densities, while delivering high performance for a low cost.
SPECIFICATION
Entube DE
100V
Bandwidth (-3dB point)
200V
300V
85kHz
Integrated sensor noise
(Referenced to input)
Gain
(Using 10V standard
output voltage)
1000V
1500V
2000V
25kHz
< 60μV
< 100 μV
< 130 μV
< 170 μV
< 220 μV
< 290 μV
< 400 μV
< 500 μV
10
40
50
75
100
150
200
25kΩ
33kΩ
20kΩ
20kΩ
15kΩ
> 1 MΩ
50kΩ
> 2 MΩ
25kΩ
HARDWARE
DESCRIPTION
The Entube SE is a voltage divider designed to measure single
phases with reference to ground.
> 3 MΩ
10kΩ
7.5kΩ
Integrated sensor noise (Referenced to input)
Accuracy (percentage of
reading)
±0.2%
(±0.05% Typical)
Gain (Using 10V standard output voltage)
Max total phase shift at 60Hz
< 0.05°
Common mode rejection
±2000V
Withstanding differential mode
surge voltage
±1000V
Input-Output non-linearity
Output voltage
Gain temperature drift
Mounting Type
DIN Rail
Connectivity In
Clamp cage
Connedtivity Out
Spring cage
< 250 ppm
±5V (±10V optional)
±50 ppm/°C
Differential input dynamic range
Signal Layout
52 dB
Power Supply Voltage
None
Output type
Output Offset Voltage
Mechanical
Weight
750V
50kHz
Eletrical
Outer Dimensions
500V
< 30 μV
Input Impedance
Line Output Impedance
400V
Double-ended signal
< ± 10µV
(on ±10V signal)
Environmental
Operating temperature
– 25 to 70 °C
Storage temperature
– 40 to 80 °C
The input connect to the sensor via a Spring-cage, while the conditioned signals from the sensor come out on a standard screw
terminals. The Entube SE can be mounted anywhere between
the signal source and the data acquisition system. A femalescrew on the low voltage side of the sensor allows for DIN rail
mounting, and serves as a safety ground.
A twisted pair should be used to carry the conditioned signals
from the sensor. This will keep good resolution beyond the 10th
harmonic on a typical 60Hz system.
1.4” x 1.4” x 4.5”
198 g (7.0 oz)
650 Washington St, San Francisco, CA 94111
70VERIVOLT (708) 374-8658
1
MERCHANICAL
DIMENSIONS
HARDWARE
CONFIGURATION
A. Safely connect Data Acquistion
ground to ground of sensor.
A
Standards and Certifications
● CE
B. Securely connect one end of a
twisted pair to the output terminals,
and the other end to the inputs of your
breakout board or data acquisition unit
C. Securely connect wire between the
source of measurement and an available Entube SE’s input clamp cage.
C
B
DANGER
THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the
failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage.
2
ENTUBE SE (300V 10V) 价格&库存
很抱歉,暂时无法提供与“ENTUBE SE (300V 10V)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2719.092081+351.65254
