Envoy SC
Single-Channel Hall Effect
Current Sensor
OVERVIEW
The Envoy SC is a single channel (SC) module designed for high-quality current measurements in
the range from 50 to 300 Amperes.
The IsoBlock Current-FG uses Hall Effect with closed loop methodology to measure the current
flowing in the conductor passing through the aperture. This is followed by an anti-aliasing filter and
a conditioning stage to output a ±10V signal.
The compact form factor of the Envoy SC module allows users to setup high channel density monitoring systems, making it ideal for deployed and portable systems.
SPECIFICATION
Envoy SC
50A
100A
Bandwidth (-3dB point)
200A
< 3.2 mA
< 6 mA
< 10 mA
< 15 mA
< 18 mA
200 V/A
100 mV/A
66.667 mV/A
50 mV/A
33.333 mV/A
50A
100A
150A
200A
300A
Conversion Factor
Input dynamic range
Eletrical
±0.7%
Input-Output non-linearity
< 0.01°
< 1 μs
AC 3000V, for 1 minute
>500MOhm (@500V)
< ±0.01% / °C
Mechanical
Outer Dimensions
Weight
±50 ppm/°C
Differential input dynamic range
Power Supply Voltage
Output type
Mounting Type
±10V, ±5V Custom
Gain temperature drift
Max total phase shift at 60Hz
Thermal drift gain
< 280 ppm/A
Output voltage
Gain
Insulation Resistance
The current sensing component of the unit is the aperture located
at the top of the module in the figure above. Two connectors that
serve to power the unit and output the sensor signal lays along
the bottom.
Integrated sensor noise
Accuracy (percentage of
reading)
Isolation voltage
HARDWARE
DESCRIPTION
300A
DC - 300kHz
(Referenced to input)
Max Input delay
150A
Output Offset Voltage
Output impedance
indication of input, output and power of the IsoBlock I-FG-1c
5V,9V,12V and 24V options
Differential signal
The IsoBlock Current module is designed to mount on standard
NS-35 or NS-32 DIN rails with minimal preparation, providing users ease of use and flexibility.
< ±500µV
100Ω
Environmental
Operating temperature
– 25 to 65 °C
Storage temperature
– 40 to 70 °C
DIN Rail
3.5” x 2.5” x 1.5”
205 g (7.2 oz)
Installation on DIN rail
650 Washington St, San Francisco, CA 94111
(708) 374-8658
1
MERCHANICAL
DIMENSIONS
HARDWARE
CONFIGURATION
A. Connect external power source
to power the unit. For proper functioning the power supply should provide a
voltage as specified with at
least 0.25A of continuous current and
0.5A surge during module start-up.
A
Standards and Certifications
● CE
● RoHS Compliant
B. Securely connect one end of a
twisted pair to the output terminals,
and the other end to the inputs of your
data acquisition unit
C. Pass conductor through aperture
and observe orientation for proper signal polarity.
C
B
DANGER
THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the
failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage.
2
很抱歉,暂时无法提供与“ENVOY SC (50A)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1908.982281+246.85789
