ISOBLOCK I-FG-1C (6A 10V) 数据手册
IsoBlock I-FG
Single-Channel FluxGate
Current Measuring Module
OVERVIEW
The IsoBlock Current-FG is a sensor designed for high-quality isolated current measurements in
the range from 6 to 50 Amperes. The IsoBlock Current-FG module provides 1200V primary-to-secondary isolation, which allows users to monitor a miscellaneous of currents at different potentials.
The IsoBlock Current-FG uses Flux-Gate methodology to measure the current flowing through the
input conductor. In essence, this technique works by placing a toroid with a high number of turns
(secondary) around the input current path (primary), while a close-loop circuitry controls the current through the secondary to null out the magnetic field inside the toroid. The input current is
then obtained by multiplying the current from the control circuitry by the number of turns of the
secondary. This is followed by an anti-aliasing filter and a conditioning stage to output a ±10V
signal.
The compact form factor of the IsoBlock Current-FG module allows users to setup high channel
density monitoring systems, making it ideal for deployed and portable systems.
SPECIFICATION
IsoBlock I-FG
6A
15A
Bandwidth (-3dB point)
25A
DC - 300kHz
Integrated sensor noise
(Referenced to input)
Conversion Factor
< 3.2 mA
< 6 mA
< 10 mA
< 18 mA
1.667 V/A
666.667 mV/A
400 mV/A
200 mV/A
12A
30A
50A
100A
Input dynamic range
Eletrical
Max total phase shift at 60Hz
Max Input delay
Isolation voltage from primary
side to secondary side
Withstanding common mode
surge voltage
±0.2%
Outer Dimensions
Weight
Input-Output non-linearity
Output voltage
< 280 ppm/A
±10V, ±5V Custom
< 0.05°
Gain temperature drift
±50 ppm/°C
< 5 μs
Power Supply Voltage
8V to 28V
Output type
Differential signal
> ±1200V
Output Offset Voltage
±2000V
< ±0.01% / °C
Mechanical
Mounting Type
The current input connector is located at the top of the module in
the figure above. A connector that servers to power the unit and
output the sensor signal lays along the bottom.
Performance
Accuracy (percentage of
reading)
Thermal drift gain
HARDWARE
DESCRIPTION
50A
Output impedance
Common mode impedance
Differential Input impedance
< ±500µV
indication of input, output and power of the IsoBlock I-FG
The IsoBlock Current module is designed to mount on standard
NS-35 or NS-32 DIN rails with minimal preparation, providing users ease of use and flexibility.
100Ω
> 2 GΩ || 4pF
> 1 MΩ
Environmental
DIN Rail
3.5” x 2.5” x 1.5”
Operating temperature
– 25 to 65 °C
Storage temperature
– 40 to 70 °C
205 g (7.2 oz)
Installation on DIN rail
650 Washington St, San Francisco, CA 94111
(708) 374-8658
1
MERCHANICAL
DIMENSIONS
HARDWARE
CONFIGURATION
A. Connect external power source
to power the unit. For proper functioning the power supply should provide a
voltage as specified with at
least 0.2A of continuous current and
0.4A surge during module start-up.
A
Standards and Certifications
● CE
● RoHS Compliant
B. Securely connect one end of a
twisted pair to the output terminals,
and the other end to the inputs of your
data acquisition unit
C. Pass conductor through aperture
and observe orientation for proper signal polarity.
C
B
DANGER
THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the
failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage.
2
ISOBLOCK I-FG-1C (6A 10V) 价格&库存
很抱歉,暂时无法提供与“ISOBLOCK I-FG-1C (6A 10V)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3478.898371+450.08837
- 10+2909.8392710+376.46538
- 25+2734.4292625+353.77142
