ISOBLOCK I-FG-4C (25A 10V)
    VERIVOLT
    电流变送器 0 ~ 25A 输入 ±10V 输出 9 ~ 28VDC DIN 轨道
ISOBLOCK I-FG-4C (25A 10V) 数据手册
IsoBlock I-FG-4c 4-Channel FluxGate Current Measuring Module OVERVIEW The IsoBlock Current-FG-SC is a 4 (four) channel (SC) module designed for high-quality isolated current measurements in the range from 6 to 50 Amperes. The IsoBlock Current-FG module provides 1200V primary-to-secondary isolation, which allows users to monitor a miscellaneous of currents at different potentials. The IsoBlock Current-FG uses Flux-Gate methodology to measure the current flowing through the input conductor. In essence, this technique works by placing a toroid with a high number of turns (secondary) around the input current path (primary), while a close-loop circuitry controls the current through the secondary to null out the magnetic field inside the toroid. The input current is then obtained by multiplying the current from the control circuitry by the number of turns of the secondary. This is followed by an anti-aliasing filter and a conditioning stage to output a ±5V signal. The compact form factor of the IsoBlock Current-FG module allows users to setup high channel density monitoring systems, making it ideal for deployed and portable systems. SPECIFICATION IsoBlock I-FG-1c 6A 15A Bandwidth (-3dB point) 25A DC - 300kHz Integrated sensor noise (Referenced to input) Conversion Factor < 3.2 mA < 6 mA < 10 mA < 18 mA 1.667 V/A 666.667 mV/A 400 mV/A 200 mV/A 12A 30A 50A 100A Differential input dynamic range Eletrical ±0.3% Gain (Using 5V standard output voltage) Max total phase shift at 60Hz Max Input delay < 0.05° < 5 μs Isolation voltage from primary side to secondary side Input-Output non-linearity < 280 ppm/A Output voltage ±5V Custom Gain temperature drift ±50 ppm/°C Differential input dynamic range Common mode rejection at 50kHz Power Supply Voltage > ±1200V Withstanding common mode surge voltage ±2000V Withstanding differential mode surge voltage ±1000V Output type Output Offset Voltage Differential Input impedance Common mode impedance Mechanical Output impedance Mounting Type DIN Rail Connectivity (Connector for power in and signal out to/ from the sensor) Weight The current input connectors are located at the top of the module in the figure above. A connector that servers to power the unit and output the sensor signal lays along the bottom. Integrated sensor noise (Referenced to input) Accuracy (percentage of reading) Outer Dimensions HARDWARE DESCRIPTION 50A Spring cage 3.5” x 2.5” x 1.5” indication of input, output and power of the IsoBlock I-FG-1c 108 dB 8 to 28 V The IsoBlock Current module is designed to mount on standard NS-35 or NS-32 DIN rails with minimal preparation, providing users ease of use and flexibility. Differential signal < ±500µV > 1 MΩ > 2 GΩ || 4pF 200Ω Environmental Operating temperature – 25 to 70 °C Storage temperature – 40 to 80 °C 205 g (7.2 oz) 650 Washington St, San Francisco, CA 94111 (708) 374-8658 Installation on DIN rail 1 MERCHANICAL DIMENSIONS HARDWARE CONFIGURATION A. Connect 5V external power source to power the unit. For proper functioning the power supply should provide a voltage between 8V and 28V with at least 0.2A of continuous current and 0.4A surge during module start-up. A Standards and Certifications ● CE B. Securely connect wire in the 20-6 AWG range between the source of measurement and an available IsoBlock’s input screw terminal. C. Securely connect one end of a twisted pair to the output terminals, and the other end to the inputs of your data acquisition unit C B DANGER THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage. 2
ISOBLOCK I-FG-4C (25A 10V) 价格&库存
很抱歉,暂时无法提供与“ISOBLOCK I-FG-4C (25A 10V)”相匹配的价格&库存,您可以联系我们找货
  • 1+11085.614551+1434.09348
  • 10+9413.7733510+1217.81530
库存:7
