ISOBLOCK I-FG-4C (15A 5V) 数据手册
IsoBlock I-FG-4c
4-Channel FluxGate Current
Measuring Module
OVERVIEW
The IsoBlock Current-FG-SC is a 4 (four) channel (SC) module designed for high-quality isolated current measurements in the range from 6 to 50 Amperes. The IsoBlock Current-FG module provides
1200V primary-to-secondary isolation, which allows users to monitor a miscellaneous of currents
at different potentials.
The IsoBlock Current-FG uses Flux-Gate methodology to measure the current flowing through the
input conductor. In essence, this technique works by placing a toroid with a high number of turns
(secondary) around the input current path (primary), while a close-loop circuitry controls the current through the secondary to null out the magnetic field inside the toroid. The input current is
then obtained by multiplying the current from the control circuitry by the number of turns of the
secondary. This is followed by an anti-aliasing filter and a conditioning stage to output a ±5V signal.
The compact form factor of the IsoBlock Current-FG module allows users to setup high channel
density monitoring systems, making it ideal for deployed and portable systems.
SPECIFICATION
IsoBlock I-FG-1c
6A
15A
Bandwidth (-3dB point)
25A
DC - 300kHz
Integrated sensor noise
(Referenced to input)
Conversion Factor
< 3.2 mA
< 6 mA
< 10 mA
< 18 mA
1.667 V/A
666.667 mV/A
400 mV/A
200 mV/A
12A
30A
50A
100A
Differential input
dynamic range
Eletrical
±0.3%
Gain (Using 5V standard output voltage)
Max total phase shift at 60Hz
Max Input delay
< 0.05°
< 5 μs
Isolation voltage from primary
side to secondary side
Input-Output non-linearity
< 280 ppm/A
Output voltage
±5V Custom
Gain temperature drift
±50 ppm/°C
Differential input dynamic range
Common mode rejection
at 50kHz
Power Supply Voltage
> ±1200V
Withstanding common mode
surge voltage
±2000V
Withstanding differential mode
surge voltage
±1000V
Output type
Output Offset Voltage
Differential Input
impedance
Common mode impedance
Mechanical
Output impedance
Mounting Type
DIN Rail
Connectivity (Connector for
power in and signal out to/
from the sensor)
Weight
The current input connectors are located at the top of the module
in the figure above. A connector that servers to power the unit and
output the sensor signal lays along the bottom.
Integrated sensor noise (Referenced to input)
Accuracy (percentage of
reading)
Outer Dimensions
HARDWARE
DESCRIPTION
50A
Spring cage
3.5” x 2.5” x 1.5”
indication of input, output and power of the IsoBlock I-FG-1c
108 dB
8 to 28 V
The IsoBlock Current module is designed to mount on standard
NS-35 or NS-32 DIN rails with minimal preparation, providing users ease of use and flexibility.
Differential signal
< ±500µV
> 1 MΩ
> 2 GΩ || 4pF
200Ω
Environmental
Operating temperature
– 25 to 70 °C
Storage temperature
– 40 to 80 °C
205 g (7.2 oz)
650 Washington St, San Francisco, CA 94111
(708) 374-8658
Installation on DIN rail
1
MERCHANICAL
DIMENSIONS
HARDWARE
CONFIGURATION
A. Connect 5V external power source
to power the unit. For proper functioning the power supply should provide a
voltage between 8V and 28V with at
least 0.2A of continuous current and
0.4A surge during module start-up.
A
Standards and Certifications
● CE
B. Securely connect wire in the 20-6
AWG range between the source of
measurement and an available IsoBlock’s input screw terminal.
C. Securely connect one end of a
twisted pair to the output terminals,
and the other end to the inputs of your
data acquisition unit
C
B
DANGER
THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the
failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage.
2
ISOBLOCK I-FG-4C (15A 5V) 价格&库存
很抱歉,暂时无法提供与“ISOBLOCK I-FG-4C (15A 5V)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11431.884431+1475.76050
