S-VM1000-C
S-VM1000-C
    VESPER
    VM1000 MEMS 全向性麦克风 音频 评估板
S-VM1000-C 数据手册
VM1000 Coupon PCB User Guide Rev 1.0 By Shin Nagpal General Description This document describes the S-VM1000-C Coupon PCB evaluation board. The coupon PCB provides a quick and simple way of evaluating the single ended analog output VM1000 microphone. The board consists of a VM1000 bottom port MEMS microphone and a 0.1uF power supply bypass capacitor along with an edge connector. The user can simply use a corresponding female connector (CW Industries CWR-170-10-0000) or solder wires to make good electrical contact to the power and output pins of the microphone. Pinout and Pin Descriptions The board is shown in Figure 1 as follows and the corresponding pins in table 1 have been labeled: ‘ Figure 1. VM1000 Coupon PCB (Edge Connector recommendation is provided below) Vesper Technologies Inc. 77 Summer St, 8th floor Boston, MA - 02110 Rev 1.0 FEB2019 VM1000 Coupon PCB User Guide Rev 1.0 By Shin Nagpal Board Pin # Name Description 1 Gnd Ground 2 Gnd Ground 3 Vout Analog Output 4 Gnd Ground 5 Vdd Power Supply 1.6V to 3.6V DC Table 1: Pin Configuration Edge Connector VM1000 Coupon PCB can be used with an Edge connector from CW Industries with part number CWR-170-10-0000. Wiring on the edge connector is redundant and only one electrical connection needed to each of Vdd, Vout+, Vout-, gnd. Supply range for Vdd is 1.6V – 3.6V Figure 2: Connections on VM1000 Coupon PCB and Edge Connector CWR-170-10-0000 Vesper Technologies Inc. 77 Summer St, 8th floor Boston, MA - 02110 Rev 1.0 FEB2019 Vesper VM1000 Coupon PCB User Guide Schematic The schematic of the board is shown in Figure 2. The S-VM1000-C Coupon pcb consists of the VM1000 microphone and the 0.1uF power supply bypass capacitor. Figure 3: S-VM1000-C Coupon PCB Schematic 3 Vesper Technologies Inc. 77 Summer St, 8th floor Boston, MA - 02110 Rev1.0 FEB2019 Vesper VM1000 Coupon PCB User Guide Figure 4: S-VM1000-C Coupon PCB board layout Other Information The detailed specifications and description of the VM1000 microphone can be found in the product datasheet. For convenience the basic parameters and absolute maximum ratings also shown in tables 2 and 3 below: 4 Vesper Technologies Inc. 77 Summer St, 8th floor Boston, MA - 02110 Rev1.0 FEB2019 Vesper VM1000 Coupon PCB User Guide Parameter Typical Value Units Supply Voltage 1.8 V Idd 165 μA -38.0 dBV 12.59 mVrms Output Impedance 400 Ω Output DC Offset 0.8 V Sensitivity @ 94dB SPL Table 2. Typical parameters for microphone operation Parameter Rating Units Supply Voltage -0.3 to +3.6 V Sound Pressure Level 160 dB re 20 μPa Operating Temperature Range -40 to +85 °C Storage Temperature Range -55 to +150 °C Mechanical Shock 10,000g per IEC 60028-2-27:2008 Vibration Per MIL-STD 883E, 2007.2 Table 3. Absolute Maximum Ratings For additional information on Vesper products, contact info@vespermems.com. 5 Vesper Technologies Inc. 77 Summer St, 8th floor Boston, MA - 02110 Rev1.0 FEB2019
S-VM1000-C 价格&库存
很抱歉,暂时无法提供与“S-VM1000-C”相匹配的价格&库存,您可以联系我们找货
