VPFS22256GTCBMTL
VPFS22256GTCBMTL
    VIKINGTECHNOLOGY
    SSD 256GB 2.5" MLC SATAIII 5V
VPFS22256GTCBMTL 数据手册
SATA 6Gb/s 2.5” SSD Manual The SATA SSD is a non-volatile, solid-state storage device. With its Serial ATA interface and industry-standard form factors, it is a drop in replacement for hard disk drives. The SSD delivers extremely high levels of performance, reliability and ruggedness for I/O intensive or environmentally challenging applications. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 1 of 45 www.vikingtechnology.com Revision History Date Revision 9/16/14 X1 12/9/14 X2 1/16/15 X3 1/3015 3/13/15 4/29/15 X4 X5 A 5/08/15 B 7/16/15 C 8/06/15 D 9/20/16 E 10/19/16 F 3/19/17 G 5/29/17 H Description Initial release. Revised S10 performance numbers. Updated PN table. Added Military Purge information. Revise Raw capacity 1024 for 960GB and 2048 for 1920GB SSDs Revise performance numbers per DVT testing Add Heading for Encryption at 2.6.1 and revise per vendor documentation rev 1.1 Remove brand name “Element” Add eMLC PN’s Add photo. Update per psg Revise power consumption table. IOPS per IOMeter and Anvils Storage Utility. Remove PFAIL/DATA Hardening signaling. Changed Absolute max Vin 3.6V. Reliability table changed from 72 bit per 1KB to 120 bit per 2KB page. Checked by IDC PAGE 2 change to MLC) fix typo for the CrystalDiskMark test on page 13 to 400MB Add 15nm PN’s Add VPFS22256GTCBMTL (1/29/16) Revise logo and color scheme. Remove temp sensor and SATA attribute. add enterprise PN’s and Power holdup circuit support. Add write protect. Revise PN’s Revise note 2 on Extended SMART Attribute Actual Data table Remove K die PN’S Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 2 of 45 www.vikingtechnology.com Legal Information Legal Information Copyright© 2017 Sanmina Corporation. All rights reserved. The information in this document is proprietary and confidential to Sanmina Corporation. No part of this document may be reproduced in any form or by any means or used to make any derivative work (such as translation, transformation, or adaptation) without written permission from Sanmina. Sanmina reserves the right to revise this documentation and to make changes in content from time to time without obligation on the part of Sanmina to provide notification of such revision or change. Sanmina provides this documentation without warranty, term or condition of any kind, either expressed or implied, including, but not limited to, expressed and implied warranties of merchantability, fitness for a particular purpose, and noninfringement. While the information contained herein is believed to be accurate, such information is preliminary, and should not be relied upon for accuracy or completeness, and no representations or warranties of accuracy or completeness are made. In no event will Sanmina be liable for damages arising directly or indirectly from any use of or reliance upon the information contained in this document. Sanmina may make improvements or changes in the product(s) and/or the program(s) described in this documentation at any time. Sanmina, Viking Technology, Viking Modular Solutions, andlogo are trademarks of Sanmina Corporation. Other company, product or service names mentioned herein may be trademarks or service marks of their respective owners. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 3 of 45 www.vikingtechnology.com Ordering Information: 2.5” SSD Solid-State Drive SATA Interface Application VPFS22960GTCZMTL VPFS22480GTCAMTL SATA 6GB SATA 6GB Client Client VPFS22256GTCBMTL SATA 6GB Client Useable Capacity 1 (GB) 960 480 256 VPFS22240GTCBMTL VPFS22120GTCBMTL VPFS22240GTCAMTL8 VPFS22480GTCZMTL8 SATA 6GB SATA 6GB SATA 6GB SATA 6GB Client Client Enterprise Enterprise 240 120 240 480 Part Numbers NAND Technology MLC MLC Temperature Range (0 to +70'c) (0 to +70'c) TSB 15nm L-die TSB 15nm L-die MLC (0 to +70'c) TSB 15nm L-die MLC MLC MLC MLC (0 to +70'c) (0 to +70'c) (0 to +70'c) (0 to +70'c) TSB 15nm L-die TSB 15nm L-die TSB 15nm L-die TSB 15nm L-die NAND  Usable capacity based on specification LBA1-03a and level of over-provisioning applied to wear leveling, bad sectors, index tables etc.  Higher capacity points may be available based on customer application. Consult your local Viking Field Application Engineer.  SSD’s ship unformatted from the factory unless otherwise requested.  1 GB = 1,000,000,000 Byte  One Sector = 512 Byte.  “y’ specifies flash capacity code  xx is a wild card to indicate customer specific BOM and/or manufacturing location Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 4 of 45 www.vikingtechnology.com Viking’s solid state drives are available in Enterprise and Client versions: Enterprise SSD – An Enterprise SSD contains PFAIL hardware and firmware that detect and manage power failures. This allows the drive to flush the controller cache and harden data to NAND flash. No data is lost or corrupted. Client SSD – A Client SSD does not include power failure detection or management features. MLC NAND, as opposed to SLC NAND, can become corrupted if power is removed during a write, also known as lower page corruption. Therefore, a Client SSD using MLC NAND is well-suited in a system that already manages power fail events, allowing for graceful SSD shutdown. Accordingly, system support should include issuing a Standby Immediate command to the SSD while maintaining power for at least 50ms. If a Client drive with MLC NAND is used in a system that does not manage power failures and shutdowns, there is a small chance of data corruption. Viking Client SSD’s take sophisticated hardware and firmware measures to prevent or mitigate such issues making the chance of corruption very small. If the SSD controller detects data corruption, the drive will be locked. The only way to recover the drive is to return it to the factory for reprogramming; all data will be lost. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 5 of 45 www.vikingtechnology.com Product Picture(s) Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 6 of 45 www.vikingtechnology.com Table of Contents 1 INTRODUCTION 10 1.1 Features 10 1.2 Block Diagram 11 1.3 SATA Interface 11 2 PRODUCT SPECIFICATIONS 12 2.1 Capacity and LBA count 12 2.2 Performance 13 2.3 Timing 13 2.4 Electrical Characteristics 2.4.1 Absolute Maximum Ratings 2.4.2 Supply Voltage 2.4.3 Power Consumption 14 14 14 15 2.5 Environmental Conditions 2.5.1 Temperature and Altitude 2.5.2 Shock and Vibration 2.5.3 Electromagnetic Immunity 16 16 16 16 2.6 17 Reliability 2.7 Data Security 2.7.1 Encryption 2.7.2 Data Integrity Assurance After Unexpected Power Loss 2.7.3 Quick Erase 2.7.4 Military Secure Erase / Sanitization/ Purge Routines 18 18 18 19 20 3 30 MECHANICAL INFORMATION 3.1 SSD Physical Dimensions 30 3.2 SSD Weight 31 4 PIN AND SIGNAL DESCRIPTIONS Manual PSFS22xxxGTxxx Revision H 31 5/29/17 Viking Technology Page 7 of 45 www.vikingtechnology.com 4.1 SSD Signal and Power Description Tables 31 4.2 Hot Plug Support 32 5 COMMAND SETS 33 5.1 ATA Commands 5.1.1 48-Bit Address Command Set 5.1.2 ATA General Feature Command Set 5.1.3 Device Configuration Overlay Command Set 5.1.4 General Purpose Log Command Set 5.1.5 Host Protected Area Command Set 5.1.6 Power Management Command Set 5.1.7 Security Mode Feature Set 5.1.8 Identify Device Data 5.1.1 S.M.A.R.T. Support 5.1.2 S.M.A.R.T. Command Set 33 34 34 34 35 35 35 35 36 39 39 5.2 SATA Commands 5.2.1 Native Command Queuing (NCQ) 43 43 6 REFERENCES 44 7 GLOSSARY 45 Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 8 of 45 www.vikingtechnology.com Table of Tables Table 2-1: Maximum Sustained Read and Write Bandwidth ____________________________ 13 Table 2-2: Random Read and Write Input/Output Operations per Second (IOPS) ___________ 13 Table 2-3: Timing Specifications _________________________________________________ 13 Table 2-4: Absolute Maximum Ratings ____________________________________________ 14 Table 2-5: Operating Voltage ____________________________________________________ 14 Table 2-6: Typical Power Consumption ____________________________________________ 15 Table 2-7: Temperature and Altitude Related Specifications ____________________________ 16 Table 2-8: Shock and Vibration Specifications _______________________________________ 16 Table 2-9: Reliability Specifications _______________________________________________ 17 Table 2-10: Endurance Specifications _____________________________________________ 17 Table 2-11: Military Secure Erase / Sanitize Routines _________________________________ 20 Table 3-1: Physical Dimensions __________________________________________________ 30 Table 4-1: Serial ATA Connector Pin Signal Definitions _______________________________ 31 Table 4-2: Serial ATA Power Pin Definitions ________________________________________ 31 Table 5-1: Supported ATA Commands ____________________________________________ 33 Table 5-2: List of Device Identification _____________________________________________ 36 Table 5-3: S.M.A.R.T. Command Set ______________________________________________ 40 Table 5-4: Extended SMART Attribute Table ________________________________________ 40 Table 5-5: Extended SMART Attribute Actual Data ___________________________________ 41 Table 5-6: Supported S.M.A.R.T. EXECUTE OFF-LINE IMMEDIATE Subcommands ________ 43 Table of Figures Figure 1-1: High-Level Block Diagram _____________________________________________ 11 Figure 3-1: 2.5” SSD Case Dimensions ____________________________________________ 30 Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 9 of 45 www.vikingtechnology.com 1 Introduction Viking SSD’s offer the highest flash storage reliability and performance as well as support for many functional features. 1.1 Features The SSD delivers the following features:  Seamless SATA Revision 3.2 interface support for SATA up to 6Gb/s  Low overall SSD power consumption  Supports Native Command Queuing (NCQ) to 32 commands  Compatible with all major SLC and MLC flash technologies  S.M.A.R.T.  Power hold-up circuit technology ensures no data loss resulting from an unexpected power loss  Superior static and dynamic wear-leveling algorithm  Efficient error recovery  TRIM Support  48-bit LBA Support Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 10 of 45 www.vikingtechnology.com 1.2 Block Diagram Figure 1-1: High-Level Block Diagram Notes: Support for up to 8-channels and 32 CE in the NAND Flash interface 1.3 SATA Interface    The Serial ATA (SATA) interface is compliant with the SATA IO Serial ATA specification, revision 3.2 that supports SATA up to 6GB/s. The SATA interface connects the host computer to the SSD subsystem. The SATA interface runs at a maximum speed of 6.0 Gbps (Giga-bits per second). If the host computer is unable to negotiate a speed of 6.0 Gbps, the SATA interface automatically renegotiates to a speed of 3GBPs or 1.5Gbps. For a list of supported commands and other specifics, please see Chapter 5. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 11 of 45 www.vikingtechnology.com 2 Product Specifications 2.1 Capacity and LBA count Raw Capacity (GB) User Capacity (GB) LBA Count 16 14 27,370,224 16 16 31,277,232 32 30 58,626,288 32 32 62,533,296 64 60 117,231,408 64 64 125,045,424 128 120 234,441,648 128 128 250,069,680 256 240 468,862,128 256 256 500,118,192 512 480 937,703,088 512 512 1,000,215,216 1024 960 1,875,385,008 1024 1024 2,000,409,264 2048 1920 3,750,748,848 2048 2048 4,000,797,360 Notes: 1. Per LBA1-03 spec, LBA counts = (97,696,368) + (1,953,504 * (Advertised Capacity in GBytes – 50)) Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 12 of 45 www.vikingtechnology.com 2.2 Performance Table 2-1: Maximum Sustained Read and Write Bandwidth Access Type Sequential Read, 256K Sequential Write, 256K MB/s Up to 550 Up to 448 Notes: 1. Performance measured using IOMeter and Anvils Storage Utility with queue depth set to 32. 2. Write Cache enabled with DDR3 cache. 3. Refer to Application Note AN0006 for Viking SSD Benchmarking Methodology. 4. Data is based on SSD’s capacities > 250GB, using Synchronous NAND devices (ONFI or toggle mode) Table 2-2: Random Read and Write Input/Output Operations per Second (IOPS) Access Type Read, 4K Write, 4K IOPS Up to 126,000 Up to 90,000 Notes: 2. Performance measured using IOMeter and Anvils Storage Utility with queue depth set to 32. 3. Write Cache enabled. 4. Random IOPS cover the entire range of legal logical block addresses (LBA’s). Measurements are performed on a full drive (all LBA’s have valid content). 5. Performance may vary by NAND type and host. 6. Refer to Application Note AN0006 for Viking SSD Benchmarking Methodology. 7. Data is based on SSD’s capacities > 250GB, using Synchronous NAND devices (ONFI or toggle mode) 2.3 Timing Table 2-3: Timing Specifications Type Average Latency Read (at 64KB) 0.14mS Write (at 64KB) 2.12mS Power On Ready (POR) 536mS Notes: 1. Device measured using Drivemaster. 2. DRQ (Data Transfer Requested) bit being asserted Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 13 of 45 www.vikingtechnology.com 2.4 Electrical Characteristics 2.4.1 Absolute Maximum Ratings Values shown are stress ratings only. Functional operation outside normal operating values is not implied. Extended exposure to absolute maximum ratings may affect reliability. Table 2-4: Absolute Maximum Ratings Description Maximum Voltage Range for Vin Maximum Temperature Range Min -0.2 -40 Max 6 85 Unit V c Description Min Max Unit Operating Voltage for 5.0 V (+/- 5%) Ripple (0-30MHz) 4.75 5.25 100 V mV 2.4.2 Supply Voltage The operating voltage is 5V. Table 2-5: Operating Voltage Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 14 of 45 www.vikingtechnology.com 2.4.3 Power Consumption All onboard power requirements of the SSD are derived from the SATA 5.0V input rail. Table 2-6: Typical Power Consumption Capacity Flash: TSBA19 Read() Write 128GB 8GBx1Diex16CE 2.224 3.446 256GB 8GBx1Diex32CE 2.21 512GB 8GBx2Diex32CE 1TB 16GBx2Diex32CE Capacity Flash: M L95B 128GB Idle Partial Slumber 0.505 0.0911 0.0911 4.31 0.566 0.0695 0.068 2.335 4.431 0.632 0.0824 0.0798 2.481 4.234 0.651 0.1014 0.1009 Read() Write Idle Partial Slumber 16GBx1Diex8CE 2.193 2.524 0.625 0.1158 0.0716 256GB 16GBx1Diex16CE 2.161 3,624 0,571 0.0675 0,0659 512GB 16GBx2Diex16CE 2.39 3.971 0.567 0.1199 0.0968 Notes: 1. The average value of power consumption is achieved based on 100% conversion efficiency. 2. The measured power voltage is 5V. 3. Samples were built of Toshiba A19nm Toggle MLC NAND flash and measured under ambient temperature. 4. Sequential R/W is measured while testing 400MB sequential R/W 5 times by CrystalDiskMark(CDM). 5. Power Consumption may differ according to flash configuration and platform. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 15 of 45 www.vikingtechnology.com 2.5 Environmental Conditions 2.5.1 Temperature and Altitude Table 2-7: Temperature and Altitude Related Specifications Conditions Commercial Temperature - Ambient Industrial Temperature - Ambient Humidity (noncondensing) Operating 0 to 70°C (32 to 158° F) Shipping -40 to 85°C (-40 to 185° F) Storage -40 to 85°C (-40 to 185° F) -40 to 85°C (-40 to 185° F) -40 to 85°C (-40 to 185° F) -40 to 85°C (-40 to 185° F) 90% under 40C 93% under 40C 93% under 40C Notes: 1. SLC flash based products may be available in the following temperature ranges: a) Commercial temperature range of 0 to 70°C (32 to 158° F) b) Industrial temperature range -40 to 85°C (-40 to 185° F) 2.5.2 Shock and Vibration SSD products are tested in accordance with environmental specification for shock and vibration Table 2-8: Shock and Vibration Specifications Stimulus Shock Vibration Nonoperational 2.5.3 Description 500G (2ms) Condition Frequency/Displacement Frequency/Acceleration 20Hz~80Hz/1.52mm 80Hz~2000Hz/20G Vibration Orientation X, Y, Z axis/30 min for each Electromagnetic Immunity This SSD is an embedded product for host systems and is designed not to impair with system functionality or hinder system EMI/FCC compliance. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 16 of 45 www.vikingtechnology.com 2.6 Reliability Table 2-9: Reliability Specifications Parameter ECC MTBF Read Endurance Write Endurance Value up to 120bit/2KB ECC circuit (BCH) ~ 2,000,000 hours Unlimited (Refer to Endurance table) SLC and MLC is 1 year at NAND expiration eMLC is 90 days at NAND expiration Data retention Table 2-10: Endurance Specifications Capacity 60GB 120GB 240GB 480GB 960GB Flash Structure 8GB x 8 16GB x 8 32GB x 8 64GB x 8 128GB x 8 Terabytes Written (TBW) 32 60 107 240 465 Notes: 1. Samples were built using Toshiba A19nm Toggle MLC NAND flash. 2. TBW may differ according to flash configuration and platform. 3. The endurance of SSD could be estimated based on user behavior, NAND endurance cycles, and write amplification factor. It is not guaranteed by flash vendor. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 17 of 45 www.vikingtechnology.com 2.7 Data Security 2.7.1 Encryption The SSD drive is a self-encrypting drive (SED), with a bulk data encryption feature that provides automatic hardware-based data security and enhanced secure erase capability. A self-encrypting drives, scrambles data using a data encryption key as it is written to the drive and then descrambles it with the key as it is retrieved. This gives the user the highest level of data protection available and provides a fast erase simply by deleting the encryption key, eliminating the need for time consuming data-overwrite. Data on the drive is instantly rendered unreadable. The SSD supports AES-256 encryption and ATA Secure Erase features to protect sensitive data. The SSD drives support the following security features:  AES 256 on the fly support.  RSA 512/1024/2048  SHA 160/256/512  TCG OPAL SSC V1.0 2.7.2 Data Integrity Assurance After Unexpected Power Loss 2.7.2.1 Integrated Hold Up Circuit The SSD has an integrated hold-up circuit that powers the module for short period of time after a power failure. In the event of an unexpected loss of power, the hold up circuit is used to supply power to the module to allow the controller time to harden data to the non-volatile NAND flash. Note: This feature is not available for client and industrial versions 2.7.3 Write Protect When a SSD contains too many bad blocks and data are continuously written in, then the SSD might not be usable anymore. Thus, Write Protect is a mechanism to prevent data from being written in and protect the accuracy of data that are already stored in the SSD. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 18 of 45 www.vikingtechnology.com 2.7.4 Quick Erase Quick Erase has been designed to remove data under prompt and urgent situation and is triggered by sending an ATA Command. Input Info of Executing Quick Erase Command Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 19 of 45 www.vikingtechnology.com Normal Output Info of Executing Quick Erase Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. 2.7.5 Military Secure Erase / Sanitization/ Purge Routines Many government and military organizations such as NIST/NSA define their own standard and procedures for performing a Military Secure Erase which overwrite different patterns to sanitize the flash media. Some of the more common military or government purge routines are defined in the following table and the data security features of the drive comply with Department of Defense (DoD) and US military data security standards. Table 2-11: Military Secure Erase / Sanitize Routines Standard Action SSD 1 Code NSA/CSS 9-12 Erase and overwrite all locations with a known unclassified pattern. Verify the overwrite procedure by randomly rereading the overwritten information to confirm that only the known pattern can be recovered. Note 1 NSA/CSS 130-2 Erase the media and overwrite with random data 2 times, then erase and overwrite with a character Note 1 DoD5220.22-M Erase the media and overwrite with single character, then erase again Note 1 NISPOMSUP Erase the media and overwrite with single character, then Note 1 Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 20 of 45 www.vikingtechnology.com Standard Action SSD 1 Code Chap 8, Sect.8-501 erase again and overwrite with single character, then erase again and overwrite with random character then erase again USA Army 380-19 Erase the media and overwrite with random data, erase and overwrite with a character, then erase and overwrite with complement of the character Note 1 Navy NAVSO P-523926 Erase the media and overwrite with random data, then erase again Note 1 Air Force AFSSI 5020 Erase the media and overwrite with pattern, repeat 3 times Note 1 Air Force AFSSI 8580 TBD Note 1 Notes: 1. Enabled using ATA commands Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 21 of 45 www.vikingtechnology.com 2.7.5.1 AFSSI 5020 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. Input Info of Executing AFSSI 5020 Command Normal Output Info of Executing AFSSI 5020 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 22 of 45 www.vikingtechnology.com 2.7.5.2 DOD 5220.22-M Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. 2) To erase the whole disk. Input Info of Executing DoD 5220.22-M Command Normal Output Info of Executing DoD 5220.22-M Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 23 of 45 www.vikingtechnology.com 2.7.5.3 USA NAVY NAVSO P-5239-26 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. 3) To erase the whole disk again. Input Info of Executing USA Navy NAVSO P-5239-26 Command Normal Output Info of Executing USA Navy NAVSO P-5239-26 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 24 of 45 www.vikingtechnology.com 2.7.5.4 NSAMANUAL 130-2 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. 3) To fill the whole disk with random data one more time. 4) To erase the whole disk again. 5) To fill the whole disk with fixed character pattern of 0x55. Input Info of Executing NSA Manual 130-2 Command Normal Output Info of Executing NSA Manual 130-2 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 25 of 45 www.vikingtechnology.com 2.7.5.5 USA-ARMY 380-19 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. 3) To fill the whole disk with fixed character pattern of 0x55. 4) To fill the whole disk with fixed character pattern of 0xAA. Input Info of Executing USA-Army 380-19 Command Normal Output Info of Executing USA-Army 380-19 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 26 of 45 www.vikingtechnology.com 2.7.5.6 NISPOMSUP CHAP 8, SECT. 8-501 Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. 2) To fill the whole disk with fixed character pattern of 0xAA. 3) To fill the whole disk with random data. Input Info of Executing NISPOMSUP chap 8, Sect. 8-501 Command Normal Output Info of Executing NISPOMSUP chap 8, Sect. 8-501 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 27 of 45 www.vikingtechnology.com 2.7.5.7 NSA/CSS 9-12 Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. Input Info of Executing NSA/CSS 9-12 Command Normal Output Info of Executing NSA/CSS 9-12 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 28 of 45 www.vikingtechnology.com 2.7.5.8 AFSSI 8580 Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. 2) To fill the whole disk with fixed character pattern of 0xAA. 3) To fill the whole disk with random data. Input Info of Executing AFSSI 8580 Command Normal Output Info of Executing AFSSI 8580 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 29 of 45 www.vikingtechnology.com 3 Mechanical Information 3.1 SSD Physical Dimensions Table 3-1: Physical Dimensions Height / Thickness Width Length Dimensions 7.00 69.85 100.5 Max Units mm mm mm Figure 3-1: 2.5” SSD Case Dimensions Notes: All dimensions are in millimeters, +/- 0.2mm, unless otherwise stated. Reference SATA connector specifications Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 30 of 45 www.vikingtechnology.com 3.2 SSD Weight The weight of the 2.5” SSD is approximately 61 grams (1TB drive). 4 Pin and Signal Descriptions 4.1 SSD Signal and Power Description Tables Table 4-1: Serial ATA Connector Pin Signal Definitions Pin S1 S2 S3 S4 S5 S6 S7 Function SGND_1 RX+ on SSD, TX+ on Host RX- on SSD, TX- on Host SGND_2 TX- on SSD, RX- on Host TX+ on SSD, RX+ on Host SGND_3 Definition Signal Ground Differential Signal Differential Signal Signal Ground Differential Signal Differential Signal Signal Ground Mating Order 2nd 1st 1st 2nd 1st 1st 2nd Notes: Key and spacing separate signal and power segments. Pin locations and layout are consistent with SATA specification. Table 4-2: Serial ATA Power Pin Definitions Pin P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13 P14 P15 Function 3.3V_1 3.3V_2 DEVSLP GND_1 GND_2 GND_3 5V_1 5V_2 5V_3 GND_4 Activity GND_5 12V_1 12V_2 12V_3 Definition No connection (open circuit) No connection (open circuit) No connection (open circuit) Ground Ground Ground 5VDC Power precharge 5VDC Power 5VDC Power Ground reserved Ground No connection (open circuit) Optional 10k-ohm PD for legacy support on old versions. Manual PSFS22xxxGTxxx Revision H Mating Order 2nd 2nd 1st 1st 1st 1st 1st 2nd 2nd 1st 2nd 1st 5/29/17 Viking Technology Page 31 of 45 www.vikingtechnology.com 4.2 Hot Plug Support Hot Plug insertion and removal are supported in the presence of a proper connector and appropriate operating system (OS) support as described in the SATA Revision 3.2 specification. This product supports Asynchronous Signal Recovery and will issue an unsolicited COMINIT when first mated with a powered connector to guarantee reliable detection by a host system without hardware device detection. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 32 of 45 www.vikingtechnology.com 5 Command Sets 5.1 ATA Commands Table 5-1: Supported ATA Commands Check power mode Op Code E5h Security Disable Password Op Code F6h Data Set management 06h Security Erase Prepare F3h DCO B1h Security Erase Unit F4h Download Microcode PIO 92h Security Freeze Lock F5h Download Microcode DMA 93h Security Set Password F1h Execute drive diagnostic 90h Security Unlock F2h Flush cache E7h Seek 70h Flush cache Ext EAh Set features EFh Identify device ECh Set Max Address F9h Idle E3h Set Max Address Ext 37h Idle immediate E1h Set multiple mode C6h Initialize drive parameters 91h Sleep E6h Read buffer E4h Smart B0h Read DMA (w/o retry) C9h Standby E2h Read DMA (w/retry) C8h Standby immediate E0h Read DMA Ext 25h Write buffer E8h Read FPDMA QUEUED 60h Write DMA (w/o retry) CBh Read Log Ext 2Fh Write DMA (w/retry) CAh Read multiple C4h Write DMA Ext 35h Read multiple Ext 29h Write DMA FUA Ext 3Dh Read native max address F8h Write FPDMA QUEUED 61h Read native max Ext 27h Write Log Ext 3Fh Read sector(s) (w/o retry) 21h Write multiple C5h Read sector(s) (w/retry) 20h Write multiple Ext 39h Read sector(s) Ext 24h Write multiple FUA Ext CEh Read Verify Ext 42h Write sector(s) (w/o retry) 31h Read verify sector(s) (w/o retry) 41h Write sector(s) (w/retry) 30h Read verify sector(s) (w/retry) 40h Write sector(s) Ext 34h Recalibrate 10h Write uncorrectable 45h Description Description Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 33 of 45 www.vikingtechnology.com 5.1.1 48-Bit Address Command Set SSD supports the 48-Bit Address command set consisting of:  Flush Cache Ext  Read DMA Ext  Read native Max Address Ext  Read Sector(s) Ext  Set Max Address Ext  Write DMA Ext  Write Multiple Ext  Write Sector(s) Ext 5.1.2 ATA General Feature Command Set SSD supports the ATA General Feature command set consisting of:  Download Microcode  Executive Device Diagnostics  Flush Cache  Identify Device  NOP (optional)  Read Buffer (optional)  Read DMA  Read Multiple  Read Sector(s)  Read Verify Sector(s)  Seek  Set Features  Set Multiple Mode  Write Buffer (optional)  Write DMA  Write Multiple  Write Sector(s) 5.1.3 Device Configuration Overlay Command Set SSD supports the Device Configuration Overlay command set consisting of:  Device Configuration Freeze Lock  Device Configuration Identity  Device Configuration Restore  Device Configuration Set Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 34 of 45 www.vikingtechnology.com 5.1.4 General Purpose Log Command Set SSD supports the General Purpose Log command set consisting of:  Read Log Ext  Write Log Ext 5.1.5 Host Protected Area Command Set SSD supports the Host Protected Area command set consisting of:  Read Native Max Address  Read Native Max Address Ext  Set Max Address  Set Max Address Ext  Set Max Freeze Lock (optional)  Set Max Lock (optional)  Set Max Set Password (optional)  Set Max Unlock (optional) 5.1.6 Power Management Command Set SSD supports the Power Management command set consisting of:  Check Power Mode  Idle  Idle Immediate  Sleep  Standby  Standby Immediate  Slumber  Partial Mode 5.1.7 Security Mode Feature Set SSD supports the Security Mode command set consisting of:  Security Set Password (OPCODE: F1h)  Security Unlock (OPCODE: F2h)  Security Erase Prepare (OPCODE: F3h)  Security Erase Unit (OPCODE: F4h)  Security Freeze Lock (OPCODE: F5h)  Security Disable Password (OPCODE: F6h)  Standby Immediate Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 35 of 45 www.vikingtechnology.com 5.1.8 Identify Device Data The table below lists the sector data that will be returned by the SSD upon an IDENTIFY DEVICE command. Table 5-2: List of Device Identification F: Fixed V: Variable X: Both Default Value 0 F 0040h 1 X 3FFFh 2 3 4-5 V X X C837h 0010h 00000000h 6 X 003Fh 7-8 V 00000000h 9 10-19 20-21 22 23-26 27-46 X F X X F F 0000h Varies 0000h 0000h Varies Varies 47 F 8010h 48 49 50 51-52 53 F F F X F 0000h 2F00h 4000h 000000000h 0007h 54 X 3FFFh 55 X 0010h 56 X 003Fh 57-58 X 00FBFC10h 59 F 0110h 60-61 62 63 64 F X F F 8GB-128GB 0000h 0407h 0003h 65 F 0078h Word Description General configuration bit-significant information Obsolete – Number of logical cylinders (16383) Specific configuration Obsolete – Number of logical heads (16) Retired Obsolete – Number of logical sectors per logical track (63) Reserved for assignment by the Compact Flash Association Retired Serial number (20 ASCII characters) Retired Obsolete Firmware revision (8 ASCII characters) Model number (xxxxxxxx) 7:0- Maximum number of sectors transferred per interrupt on MULTIPLE commands Reserved Capabilities Capabilities Obsolete Words 88 and 70:64 valid Obsolete – Number of logical cylinders (16383) Obsolete – Number of logical heads (16) Obsolete – Number of logical sectors per track (63) Obsolete – Current capacity in sectors – Number of sectors transferred per interrupt on MULTIPLE commands Total number of user addressable sectors Obsolete Multi-word DMA modes supported/selected PIO modes supported Minimum Multiword DMA transfer cycle time per word Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 36 of 45 www.vikingtechnology.com F: Fixed V: Variable X: Both Default Value 66 F 0078h 67 F 0078h 68 F 0078h 69 F 0100h 70 F 71-74 F 75 76 77 78 79 80 81 82 83 84 85 86 87 88 F F F F V F F F F F V V V V 0000h 000000000000000 0h 001Fh 0706h 0000h 0044h 0040H 01F8h 0000h 346Bh 70D9h 6023h 3469h BC01h 6023h 003Fh 89 F 001Eh 90 F 001Eh 91 92 V V 0000h FFFEh 93 F 0000h 94 V 0000h 95 96 97 98-99 F V V F 0000h 0000h 0000h 0000h 100-103 V 8GB-256GB 104 V 0000h 105 F 0000h 106 F 4000h Word Description Manufacturer’s recommended Multiword DMA transfer cycle time Minimum PIO transfer cycle time without flow control Minimum PIO transfer cycle time with IORDY flow control Additional Supported (support download microcode DMA) Reserved Reserved for the IDENTIFY PACKET DEVICE command Queue depth Serial SATA capabilities Reserved for future Serial ATA definition Serial ATA features supported Serial ATA features enabled Major Version Number Minor Version Number Command set supported Command set supported Command set/feature supported extension Command set/feature enabled Command set/feature enabled Command set/feature default Ultra DMA Modes Time required for security erase unit completion Time required for Enhanced security erase completion Current advanced power management value Master Password Revision Code Hardware reset result. The contents of the bits (12:0) of this word shall change only during the execution of s hardware reset. Vendor’s recommended and actual acoustic management value Stream Minimum Request Size Streaming Transfer Time – DMA Streaming Access Latency – DMA and PIO Streaming Performance Granularity Maximum user LBA for 48 bit Address feature set Streaming Transfer Time – PIO Maximum number of 512-byte blocks per DATA SET MANAGEMENT command Physical sector size / Logical sector size Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 37 of 45 www.vikingtechnology.com F: Fixed V: Variable X: Both Default Value Description 107 F 0000h Inter-seek delay for ISO-7779 acoustic testing in microseconds 108-111 F 112-115 F 116 117-118 119 120 121-126 V F F F F 000000000000000 0h 000000000000000 0h 0000h 00000000h 4015h 4015h 0h 127 F 0h 128 129-159 V X 0021h 0h 160 F 0h 161-167 X 168 F 0h Tbd 3h: 2.5 inch 4h: 1.8 inch 5h: < 1.8 inch 169 F 0001h 170-173 174-175 176-205 206 207-208 F V F F 0h 0h 0h 0h 0h 209 F 4000h 210-211 V 0000h 212-213 F 0000h Word 214-216 217 218 219 220 221 222 223 224-229 230-233 234 F F F V F F 0000h 0001h 0h 0h 0h 0h 101Fh 0h 0h 0h 0001h Unique ID Reserved Reserved Words per logical Sector Supported settings Command set/Feature Enabled/Supported Reserved Removable Media Status Notification feature set support Security status Vendor specific Compact Flash Association (CFA) power mode 1 Reserved for assignment by the CFA Device Nominal Form Factor DATA SET MANAGEMENT command is supported Additional Product Identifier Reserve Current media serial number SCT Command Transport( Reserved Alignment of logical blocks within a physical block Write-Read-Verify Sector Count Mode 3 (not supported) Write-Read-Verify Sector Count Mode 2 (not supported) NV Cache relate (not supported) Non-rotating media device Reserved NV Cache relate (not supported) Write read verify feature set current mode Reserved Transport major version number Transport minor version number reserved Extend number of user addressable sectors Minimum number of 512-byte data blocks per DOWNLOAD MICROCODE command for Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 38 of 45 www.vikingtechnology.com Word F: Fixed V: Variable X: Both Default Value Description 00FFh mode 03h Maximum number of 512-byte data blocks per DOWNLOAD MICROCODE command for mode 03h Reserved 235 236-254 F 255 X 0h XXA5h XX is variable Integrity word (Checksum and Signature) 5.1.1 S.M.A.R.T. Support Data storage drives capture a variety of information during operation that may be used to analyze drive ―health. SATA drives provide Self-Monitoring, Analysis and Reporting Technology (SMART) features that include monitoring and storing critical performance and calibration parameters to attempt to predict the likelihood of near-term degradation or fault conditions. Drive manufacturers have adopted S.M.A.R.T. to help warn system software, a system administrator, or a user of impending drive failure, while time remains to take preventive action. It provides the host system with the knowledge of a negative reliability condition to allow the host system to warn the user of the impending risk of data loss and advise the user of the appropriate action. The technical documentation for S.M.A.R.T. is captured in the AT Attachment (ATA) standard. The standard defines the protocols for reporting errors and for invoking self-tests to collect and analyze data on demand. The ATA specification is flexible and provides for individual manufacturers to define their own unique vendor specific information. This section describes the baseline supported S.M.A.R.T. command attributes. The information herein should be used in conjunction with the ATA standard and related documents, which may serve as references for topics and details not addressed here. Further, it is recommended to consult the list of public S.M.A.R.T. attributes. The supported S.M.A.R.T. command set is listed in the table below. See the AT Attachment standard for implementation details. 5.1.2 S.M.A.R.T. Command Set The supported S.M.A.R.T. command set is listed in the table below. See the AT Attachment standard for implementation details. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 39 of 45 www.vikingtechnology.com Table 5-3: S.M.A.R.T. Command Set Value (hex) Command 00-CF D0 D1* D2 Reserved S.M.A.R.T. read attributes S.M.A.R.T. read threshold S.M.A.R.T. enable/disable attribute autosave D3* D4 D5 D6 D7* D8 S.M.A.R.T. save attribute values S.M.A.R.T. execute off-line immediate S.M.A.R.T. read log sector S.M.A.R.T. write log sector S.M.A.R.T. write attribute threshold S.M.A.R.T. enable operations D9 S.M.A.R.T. disable operations DA S.M.A.R.T. return status DB S.M.A.R.T. enable/disable automatic off-line DC-FF Reserved (Vendor Specific) * Note that D1, D3, and D7 have been made obsolete in the ATA-8 specification. 5.1.2.1 Extended SMART Attributes Table 5-4: Extended SMART Attribute Table SMART Attribute ID 01h 05h 09h Description Number of accumulated Uncorrectable errors (Range 0255) Read Error Rate Reallocated Sector Count Power-On hours Count (Range 0-4294967295) Drive Power Cycle Count (Number of accumulated power 0Ch on/off cycles) A8h SATA PHY Error Count (only record from power on, when power off this value will clear to zero) this value include all PHY error count, ex data FIS CRC ,code error, disparity error ,command FIS CRC …..) AAh ADh B1h B5h B6h BBh Max Bad Block Count (will show early bad and later bad block count) Erase count (average, max, erase count) Wear Range delta [(most wear block – average wear block)/Max P/E cycles] x 100 Program Fail Count Erase Failure Block Count Reported Uncorrectable Errors (ECC fail count) 4bytes 01h only 1 bytes Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 40 of 45 www.vikingtechnology.com SMART Attribute ID C0h C2h Description Unexpected Power Loss Count N/A Number of accumulated CRC Error (read/write data FIS CRC error) CRC Error Count (R CRC + W CRC) Number of accumulated CRC Error (read/write data FIS CRC error) Number of CRC Errors C7h DAh E7h E8h E9h F1h F2h F3h F4h F5h F6h FAh FBh FCh SSD life remaining Read Failure Block Count Lifetime Writes to Flash ((GB) Lifetime Writes from Host (each G) Lifetime Reads from Host (each G) Total internal copy ECC error count Average erase count (4bytes) Max erase count (4 bytes) Total Erase Count (6 bytes) Read retry count Do wear-leveling count CRC error write count Notes: Dummy is null and not used Table 5-5: Extended SMART Attribute Actual Data 0 1 2 3 4 ID Flag Flag Value Worse 01h 05h 09h 0Bh 13h 12h 00h 00h 00h 64h 64h 64h 64h 64h 64h 12h 00h 64h 64h 12h 00h 64h 64h 03h 00h Note 1 Note 1 Early bad block NO 12h 00h 64h 64h Max erase count (MAX 65535) 00h 00h 00h 00h The value 0 12h 00h 00h 00h Total program bad blocks count 0 0Ch A8h AAh ADh B1h B5h 5 6 7 8 9 10 11 DATA 0 0 0 0 Power on hour ECC error 0 0 Threshold 0 0 0 0 0 0 0 0 0 32h 32h 00h Power on/off cycles 0 0 0 00h SATA PHY error count 0 0 0 00h Later bad block NO 0 0Ah 00 0 00h 0 0 00h 0 0 00h 0 0 0 0 0 Average erase count (MAX 65535) Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 41 of 45 www.vikingtechnology.com 0 1 2 3 4 ID Flag Flag Value Worse 32h 00h 00h 00h Total erase bad blocks count 0 0 0 00h 03h 00h 00h 00h Total ECC error count 0 0 0 00h 12h 00h 64h 64h number of accidental power loss count 0 0 0 00h N/A N/A N/A N/A N/A N/A 12h 00h 64h 64h CRC Error Count (R CRC + W CRC) 0 0 0 00h 0Bh 00h 64h 64h Number of CRC Error 0 0 0 32h 13h 00h 64h 64h 0 0 0 00h 0Bh 00h 64h 64h 0 0 0 00h 0Bh 00h 64h 64h 0 0 0 00h 32h 00h 00h 00h 0 0 0 00h 32h 00h 00h 00h 0 0 0 00h 02h 00h 64h 64h 0 0 0 00h 02h 00h 64h 64h 0 0 0 00h 02h 00h 64h 64h 0 0 0 00h 02h 00h 64h 64h Total Erase Count 0 00h 02h 00h 64h 64h Read retry Count 0 00h 02h 00h 64h 64h Cool down Count 0 00h 02h 00h 64h 64h CRC write Count 0 00h B6h BBh C0h C2h C7h DAh E7h E8h E9h F1h F2h F3h F4h F5h F6h FAh FBh FCh 5 6 7 8 9 10 11 DATA N/A Threshold N/A % SSD life remaining (Note 2) Total Read bad Block Count Flash write 64GB each count Host write 64GB count Host read 64GB count) Total internal copy ecc error count Total Average erase count Max erase count N/A Note 1 Formula: MABN: Maximum acceptable bad block number CBBN: Current bad block number Value = ((MABN – CBBN)/ (MABN )) x 100 This formula calculates percentage of spare blocks. Value will be from 100 to 1 Note 2 Formula: Average erase count / MAX erase count (SLC PE, MLC PE) * 100 (percentage) Micron L95B or Toshiba 15nm MLC PE is 3000 SLC PE is 100000 Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 42 of 45 www.vikingtechnology.com 5.1.2.2 Off-line Mode SSD’s support the optional 28-bit S.M.A.R.T. EXECUTION OFF-LINE IMMEDIATE (B0h/D4h) command per the ATA-8 specification. This command causes the SSD to initiate the collection of S.M.A.R.T. data in an off-line mode and then preserves this data across power and reset events. Supported subcommands include those shown in the table below. Reference the ATA-8 specification for subcommand detail. Table 5-6: Supported S.M.A.R.T. EXECUTE OFF-LINE IMMEDIATE Subcommands Value Description 00h 01h 02h 04h Execute S.M.A.R.T. off-line routine immediately in off-line mode Execute S.M.A.R.T. Short self-test routine immediately in off-line mode Execute S.M.A.R.T. Extended self-test routine immediately in off-line mode Execute S.M.A.R.T. Selective self-test routine immediately in off-line mode 7Fh 81h 82h 84h Abort off-line mode self-test routine Execute S.M.A.R.T. Short self-test routine immediately in captive mode Execute S.M.A.R.T. Extended self-test routine immediately in captive mode Execute S.M.A.R.T. Selective self-test routine immediately in captive mode 5.2 SATA Commands The SATA Revision 3 specification is a super set of the ATA/ATAPI-7 specification with regard to supported commands. SSD’s support the following features that are unique to the SATA specification. 5.2.1 Native Command Queuing (NCQ) SSD’s support the Native Command Queuing (NCQ) command set, which consists of  READ FPDMA QUEUED  WRITE FPDMA QUEUED Notes: With a maximum queue depth less than or equal to 32. Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 43 of 45 www.vikingtechnology.com 6 References  Serial ATA Specification, Revision 3.2 Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 44 of 45 www.vikingtechnology.com 7 Glossary This document incorporates many industry- and device-specific words. Use the following list to define a variety of terms and acronyms. Term Definition ATA ATAPI Advanced Technology Attachment Advanced Technology Attachment Packet Interface Bit error rate, or percentage of bits that have errors relative to the total number of bits received Device Initiated Link Power Management. The ability of the device to request SATA link power state changes. Direct Memory Access Enterprise Multi-Level Cell Extended First Party 9 Giga-byte defined as 1x10 bytes Hard Disk Drive A term used to describe the removal or insertion of a SATA storage drive when the system is powered on. Input output operations per second Logical Block Address 6 Mega-bytes defined as 1x10 bytes Multi-Level Cell Mean Time Between Failures Native Command Queuing. The ability of the SATA hard drive to queue and re-order commands to maximize execution efficiency. No Operation Operating System The point at which a SATA drive physically connects to the SATA controller. Root Mean Squared Revolutions Per Minute Serial Attached SCSI Serial ATA Small Form Factor Single Level Cell Self-Monitoring, Analysis and Reporting Technology: an open standard for developing hard drives and software systems that automatically monitors a hard drive’s health and reports potential problems. Solid-State Drive BER DIPM DMA eMLC EXT FP GB HDD Hot Plug IOPS LBA MB MLC MTBF NCQ NOP OS Port RMS RPM SAS SATA SFF SLC S.M.A.R.T. SSD Manual PSFS22xxxGTxxx Revision H 5/29/17 Viking Technology Page 45 of 45 www.vikingtechnology.com
VPFS22256GTCBMTL 价格&库存
很抱歉,暂时无法提供与“VPFS22256GTCBMTL”相匹配的价格&库存,您可以联系我们找货
