VAFUSD064GCEAVH2
VAFUSD064GCEAVH2
    VIKINGTECHNOLOGY
    64GB USB3.0 USB STICK
VAFUSD064GCEAVH2 数据手册
US Headquarters 2950 Red Hill Ave, Costa Mesa California, USA 92626 Office: 714.913.2200 Fax: 714.913.2202 www.vikingtechnology.com Datasheet for: MicroSD Card 3.0 PSFUSDxxxxCxxxx Legal Information Copyright© 2018 Sanmina Corporation. All rights reserved. The information in this document is proprietary and confidential to Sanmina Corporation. No part of this document may be reproduced in any form or by any means or used to make any derivative work (such as translation, transformation, or adaptation) without written permission from Sanmina. Sanmina reserves the right to revise this documentation and to make changes in content from time to time without obligation on the part of Sanmina to provide notification of such revision or change. Sanmina provides this documentation without warranty, term or condition of any kind, either expressed or implied, including, but not limited to, expressed and implied warranties of merchantability, fitness for a particular purpose, and non-infringement. While the information contained herein is believed to be accurate, such information is preliminary, and should not be relied upon for accuracy or completeness, and no representations or warranties of accuracy or completeness are made. In no event will Sanmina be liable for damages arising directly or indirectly from any use of or reliance upon the information contained in this document. Sanmina may make improvements or changes in the product(s) and/or the program(s) described in this documentation at any time. Sanmina, Viking Technology, Viking Modular Solutions, and the Viking logo are trademarks of Sanmina Corporation. Other company, product or service names mentioned herein may be trademarks or service marks of their respective owners. Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 2 Revision History Date 11/13/18 Revision Description A Initial release based on PSFUSDxxxxQxxxx_C (9/04/18) Add VAFUSD128GCEZVH2 Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 Checked by MicroSD Card 3.0 Page 3 Ordering Information Spec Viking P/N Grade NAND Process Density GB Temperature SD 3.0 VAFUSD016GCE1WT3 C TSB 3D TLC 16 0 to 70°C SD 3.0 VAFUSD032GCE5WT3 C TSB 3D TLC 32 0 to 70°C SD 3.0 VAFUSD032GCEBVH2 C SK Hynix MLC 32 0 to 70°C SD 3.0 VAFUSD064GCEAVH2 C SK Hynix MLC 64 0 to 70°C SD 3.0 VAFUSD128GCEZVH2 C SK Hynix MLC 128 0 to 70°C Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 4 Table of Contents 1 INTRODUCTION 8 1.1 Features 8 1.2 General Description 9 1.3 Flash Management 1.3.1 Error Correction Code (ECC) 1.3.2 Wear Leveling 1.3.3 Bad Block Management 9 9 9 10 2 11 PRODUCT SPECIFICATIONS 2.1 Summary 11 2.2 Block Diagram 12 2.3 MicroSD CARD COMPARISON 13 3 ENVIRONMENTAL SPECIFICATIONS 14 3.1 Environmental Conditions 3.1.1 Temperature and Humidity 3.1.2 Shock and Vibration 3.1.1 Electromagnetic Immunity and EMI Compliance 3.1.2 Drop 3.1.3 Bend 3.1.4 Toque 3.1.5 Switch 3.1.6 Card Socket Insertions 3.1.7 Electrostatic Discharge (ESD) 14 14 14 14 14 15 15 15 15 15 3.2 16 Power Consumption 3.3 DC Characteristic 3.3.1 Bus Operation Conditions for 3.3V Signaling 3.3.2 Bus Signal Line Load 3.3.3 Power Up Time of Host 3.3.4 Power Up Time of Card 16 16 18 19 21 3.4 AC Characteristic 3.4.1 MicroSD Interface Timing (Default) 3.4.2 MicroSD Interface Timing (High-Speed Mode) 3.4.3 MicroSD Interface Timing (SDR12, SDR25 and SDR50 Modes) 22 22 25 27 Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 5 3.4.4 4 MicroSD Interface Timing (DDR50 Mode) INTERFACE 31 34 4.1 Pad Assignment and Descriptions 4.1.1 MicroSD Bus Pin Assignment 34 34 5 36 MECHANICAL INFORMATION Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 6 Table of Tables Table 2-1: Comparing SD3.0 Standard, SD3.0 SDHC and SD3.0 SDXC ________________________ Table 2-2: Comparing UHS Speed Grade Symbols _________________________________________ Table 3-1: Temperature Specifications ___________________________________________________ Table 3-2: Shock and Vibration Specifications _____________________________________________ Table 3-3: Drop Specifications _________________________________________________________ Table 3-4: Bend Specifications _________________________________________________________ Table 3-5: Torque Specifications _______________________________________________________ Table 3-6: Switch Specifications ________________________________________________________ Table 3-7: Card Socket Insertions ______________________________________________________ Table 3-8: Electrostatic Discharge (ESD) _________________________________________________ Table 3-9: Power Consumption_________________________________________________________ Table 3-10: Threshold Level for High Voltage Range ________________________________________ Table 3-11: Peak Voltage and Leakage Current ___________________________________________ Table 3-12: Threshold Level for 1.8V Signaling ____________________________________________ Table 3-13: Input Leakage Current for 1.8V Signaling _______________________________________ Table 3-14: Bus Operation Conditions – Signal Line’s Load __________________________________ Table 3-15: Timing Specifications _______________________________________________________ Table 3-16: Card Output Timing (High Speed Card) ________________________________________ Table 3-17: Clock Signal Timing ________________________________________________________ Table 3-18: SDR50 and SDR104 Card Input Timing ________________________________________ Table 3-19: Output Timing of Fixed Data Window (SDR12, SDR25, SDR50) _____________________ Table 3-20: Output Timing of Variable Window (SDR104) ____________________________________ Table 3-21: Clock Signal Timing ________________________________________________________ Table 3-22: Bus Timings – Parameters Values (DDR50 Mode) ________________________________ Table 4-1: MicroSD Bus Pin Assignment _________________________________________________ Table 4-2: Registers _________________________________________________________________ 13 13 14 14 14 15 15 15 15 15 16 16 17 17 17 18 24 26 27 28 29 30 31 33 34 35 Table of Figures Figure 2-1: High-Level Block Diagram ___________________________________________________ Figure 3-1: Bus Circuitry Diagram _______________________________________________________ Figure 3-2: Power Up Time of Host _____________________________________________________ Figure 3-3: Power Up Time of Card _____________________________________________________ Figure 3-4: Voltage Levels ____________________________________________________________ Figure 3-5: Card Input Timing (Default Speed Card) ________________________________________ Figure 3-6: Card Output Timing (Default Speed Card) _______________________________________ Figure 3-7: Card Input Timing (High Speed Card) __________________________________________ Figure 3-8: Card Output Timing (High Speed Card) _________________________________________ Figure 3-9: Clock Signal Timing (Input) __________________________________________________ Figure 3-10: SDR50 and SDR104 Card Input Timing ________________________________________ Figure 3-11: Clock Signal Timing (Output Timing of Fixed Data) _______________________________ Figure 3-12: Output Timing of Variable Window (SDR104) ___________________________________ Figure 3-13: Clock Signal Timing _______________________________________________________ Figure 3-14: Timing Diagram DAT Inputs/Outputs Referenced to CLK in DDR50 Mode _____________ Figure 4-1: MicroSD Pin Assignment 9Back View of the Card) ________________________________ Figure 5-1: MicroSD Case Dimensions ___________________________________________________ Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 12 18 19 21 22 22 23 25 25 27 28 29 30 31 32 34 36 Page 7 1 Introduction Viking SSD’s offer the highest flash storage reliability and performance as well as support for many functional features. 1.1 Features  Bus Speed Mode o UHS-I o Non-UHS  Speed Class o Class 2/6/10  Power Consumption Note o Power Up Current < 250uA o Standby Current < 1000uA o Read Current < 400mA o Write Current < 400mA  CPRM (Content Protection for Recordable Media)  Advanced Flash Management o Static and Dynamic Wear Leveling o Bad Block Management  Write Protect with mechanical switch  Supply Voltage 2.7 ~ 3.6V  Temperature Range o Operation: 0°C ~ 70°C o Storage: -40°C ~ 85°C  RoHS compliant  EMI compliant NOTE: Please see Chapter on Power Consumption for details Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 8  Performance Overview Capacity Class Flash UHS-I TestMetrix Test Test 500MB Density Read (MB/s) Write (MB/s) 0.512GB CL6 Non-UHS .512Gb*1 23 17 1GB CL6 Non-UHS .512Gb*2 23 22 2GB CL6 Non-UHS .512Gb*4 23 22 4GB CL10 UHS-I (Grade 1) 4Gb*1 35 35 8GB CL10 UHS-I (Grade 1) 4Gb*2 35 35 16GB CL10 UHS-I (Grade 1) 8Gb*2 35 35 32GB CL10 UHS-I (Grade 1) 8Gb*4 35 35 64GB CL10 UHS-I (Grade 1) 16Gb*2 35 35 128GB CL10 UHS-I (Grade 1) 32Gb*2 35 35 1.2 General Description The Micro Secure Digital (MicroSD) card version 3.0 is fully compliant with the standards released by the SD Card Association. The Command List supports [Part 1 Physical Layer Specification Ver3.01 Final] definitions. Card capacities of non-secure area and secure area support [Part 3 Security Specification Ver3.0 Final] The MicroSD 3.0 card has a 9-pin interface, designed to operate at a maximum frequency of 208MHz. It can alternate communication protocol between the SD mode and SPI mode. It performs data error detection and correction with very low power consumption. The Card capacity could be more than 64GB and up to 2TB in the future with ex-FAT file system, which is called SDXC (Extended Capacity SD Memory Card). Secure Digital 3.0 cards are one of the most popular cards today due to its high performance, good reliability and wide compatibility. 1.3 Flash Management 1.3.1 Error Correction Code (ECC) Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, Viking MicroSD cards apply the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. 1.3.2 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some area get updated more frequently than Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 9 others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Viking provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 1.3.3 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Viking implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 10 2 PRODUCT SPECIFICATIONS 2.1 Summary  Support MicroSD system specification version 3.0  Card capacity of non-secure area and secure area support [Part 3 Security Specification Ver3.0 Final] Specifications  Support MicroSD SPI mode  Designed for read-only and read/write cards  Bus Speed Mode (use 4 parallel data lines)  Non-UHS Mode  Default speed mode: 3.3V signaling, frequency up to 25MHz, up to 12.5 MB/sec  High speed mode: 3.3V signaling, frequency up to 50MHz, up to 25 MB/sec  UHS Mode  SDR12: SDR up to 25MHz, 1.8V signaling  SDR25: SDR up to 50MHz, 1.8V signaling  SDR50: 1.8V signaling, frequency up to 100MHz, up to 50 MB/sec  SDR104: 1.8V signaling, frequency up to 208MHz, up to 104MB/sec  DDR50: 1.8V signaling, frequency up to 50MHz, sampled on both clock edges, up to 50MB/sec NOTES: 1. Timing in 1.8V signaling is different from that of 3.3V signaling. 2. To properly run the UHS mode, please ensure the device supports UHS-I mode.  The command list supports [Part 1 Physical Layer Specification Ver3.1 Final] definitions  Copyrights Protection Mechanism  Compliant with the highest security of DPRM standard  Support CPRM (Content Protection for Recordable Media) of MicroSD Card  Card removal during read operation will never harm the content  Password Protection of cards (optional)  Write Protect feature using mechanical switch  Built-in write protection features (permanent and temporary)  Electrostatic Discharge (ESD)  ESD protection in contact pads (contact discharge)  ESD protection in non-contact pads (air discharge)  Operation voltage range: 2.7 ~ 3.6V  Support Dynamic and Static Wear Leveling Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 11 2.2 Block Diagram Figure 2-1: High-Level Block Diagram Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 12 2.3 MicroSD CARD COMPARISON Table 2-1: Comparing SD3.0 Standard, SD3.0 SDHC and SD3.0 SDXC SD3.0 SDSC (Backward compatible to 2.0 host) SD3.0 SDHC (Backward compatible to 2.0 host) FAT 12/16 FAT32 Addressing Mode Byte (1 byte unit) Block (512 byte unit) exFAT Block (512 byte unit) HCS/CCS bits of ACMD41 Support Support Support CMD8 (SEND_IF_COND) Support Support Support CMD16 (SET_BLOCKLEN) Support Support (Only CMD42) Support (Only CMD42) Partial Read Lock/Unlock Function Write Protect Groups Support Mandatory Optional Not Support Mandatory Not Support Not Support Mandatory Not Support Supply Voltage 2.7v – 3.6v (for operation) Support Support Support File System SD3.0 SDXC Total Bus Capacitance for each signal line CSD Version (CSD_STRUCTURE Value) 40pF 40pF 40pF 1.0 (0x0) Speed Class Optional 2.0 (0x1) Mandatory (Class 2 / 4 / 6 / 10) 2.0 (0x1) Mandatory (Class 2 / 4 / 6 / 10) Table 2-2: Comparing UHS Speed Grade Symbols U1 ( UHS Speed Grade 1) Operable Under MicroSD Memory Card Performance Applications U3 ( UHS Speed Grade 3) *UHS-I Bus I/F, UHS-II Bus I/F SDHC UHS-I and UHS-II, SDXC UHS-I and UHS-II 10 MB/s minimum write speed Full higher potential of recording real-time broadcasts and capturing large-size HD videos. 30 MB/s minimum write speed Capable of recording 4K2K video. *UHS (Ultra High Speed), , defines bus-interface speeds up to 312 Megabytes per second for greater device performance. It is available on SDXC and SDHC memory cards and devices. Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 13 3 ENVIRONMENTAL SPECIFICATIONS 3.1 Environmental Conditions 3.1.1 Temperature and Humidity Table 3-1: Temperature Specifications Conditions Temperature- Ambient Humidity (non-condensing) Operating Shipping Storage -40 to 85°C 95% under 25C -40 to 85°C 93% under 40C -40 to 85°C 93% under 40C 3.1.2 Shock and Vibration Table 3-2: Shock and Vibration Specifications Stimulus Description Shock 1500G, 0.5ms Vibration 20 – 80 Hz/1.52mm, 80 – 2000 Hz/20G, (X,Y,Z axis / 30 min for each) 3.1.1 Electromagnetic Immunity and EMI Compliance \    FCC: CISPR22 CE: EN55022 BSMI 13438 3.1.2 Drop Table 3-3: Drop Specifications MicroSD card Height of Drop Number of Drop 150cm free fall Direction: 6 face; 1 time/face Result: No any abnormality is detected when power on Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 14 3.1.3 Bend Table 3-4: Bend Specifications MicroSD card Force Action ≥ 10N Hold for 1min; total 5 times. Result: No any abnormality is detected when power on 3.1.4 Toque Table 3-5: Torque Specifications MicroSD card Force Action 0.15N-m or ±2.5 deg Hold 30 second/direction, Total 5 cycles Result: No any abnormality is detected when power on 3.1.5 Switch Table 3-6: Switch Specifications MicroSD card Force Number of Switch Cycle 0.4N-m~5N-m 1000 cycles Result: No any abnormality is detected when power on 3.1.6 Card Socket Insertions Table 3-7: Card Socket Insertions MicroSD card Number of Mating Cycles Result 10000 cycles Pass 3.1.7 Electrostatic Discharge (ESD) Table 3-8: Electrostatic Discharge (ESD) Condition Result Contact: ±4KV; 5 times/Pin Pass MicroSD card Air: ±15KV; 5 times/Position Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 Pass MicroSD Card 3.0 Page 15 3.2 Power Consumption The table below is the power consumption of MicroSD card with different bus speed modes. Table 3-9: Power Consumption Max. Power Up Current (uA) Max. Standby Current (uA) Default Speed Mode 250 1000 150 @ 3.6V 150 @ 3.6V High Speed Mode 250 1000 200 @ 3.6V 200 @ 3.6V Bus Speed Mode Max. Read Current Max. Write Current (mA) (mA) NOTES: 1) Power consumptions are measured at room temperature (25C). Standby current might rise to 1600 under 85C. 2) Power consumption of Max. Standby Current is for MicroSD cards under and including 64GB only. For 128GB and 256GB, the power consumption is to be determined. 3.3 DC Characteristic 3.3.1 Bus Operation Conditions for 3.3V Signaling Table 3-10: Threshold Level for High Voltage Range Parameter Symbol Min. Max Supply Voltage VDD 2.7 3.6 Output High Voltage VOH 0.75*VDD Output Low Voltage VOL Input High Voltage VIH Input Low Voltage VIL Revision A| November 13, 2018 V V IOH=-2mA VDD Min 0.125*VDD V IOL=2mA VDD Min 0.625*VDD VDD+0.3 V VSS-0.3 0.25*VDD V Power Up Time Datasheet: PSFUSDxxxxCxxxx Unit Condition 250 MicroSD Card 3.0 ms From 0V to VDD min Page 16 Table 3-11: Peak Voltage and Leakage Current Parameter Symbol Peak voltage on all lines Min Max. Unit Remarks -0.3 VDD+0.3 V -10 10 uA -10 10 uA All Inputs Input Leakage Current All Outputs Output Leakage Current Table 3-12: Threshold Level for 1.8V Signaling Parameter Symbol Min. Max Unit VDD 2.7 3.6 V VDDIO 1.7 1.95 V Generated by VDD Output High Voltage VOH 1.4 - V IOH=-2mA Output Low Voltage VOL - 0.45 V IOL=2mA Input High Voltage VIH 1.27 2 V Input Low Voltage VIL Vss-0.3 0.58 V Supply Voltage Regulator Voltage Condition Table 3-13: Input Leakage Current for 1.8V Signaling Parameter Input Leakage Current Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 Symbol Min Max. Unit Remarks -2 2 uA DAT3 pull-up is disconnected MicroSD Card 3.0 Page 17 3.3.2 Bus Signal Line Load Figure 3-1: Bus Circuitry Diagram MicroSD card Table 3-14: Bus Operation Conditions – Signal Line’s Load Parameter Symbol Min Max RCMD RDAT Pull-up resistance 10 Unit Remark 100 kΩ To prevent bus floating Total bus capacitance for each signal line CL 40 pF Card Capacitance for each signal pin CCARD 10 pF 16 nH 90 kΩ May be used for card detection 5 uF Maximum signal line inductance Pull-up resistance inside card (pin1) RDAT3 Capacity Connected to Power Line CC 10 1 card CHOST+CBUS shall not exceed 30 pF To prevent inrush current Notes: Total Bus Capacitance = CHOST + CBUS + N CCARD Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 18 3.3.3 Power Up Time of Host Host needs to keep power line level less than 0.5V and more than 1ms before power ramp up. Figure 3-2: Power Up Time of Host Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 19 Power On or Power Cycle Followings are requirements for Power on and Power cycle to assure a reliable MicroSD Card hard reset. 1. Voltage level shall be below 0.5V 2. Duration shall be at least 1ms. Power Supply Ramp Up The power ramp up time is defined from 0.5V threshold level up to the operating supply voltage which is stable between VDD (min.) and VDD (max.) and host can supply SDCLK. Followings are recommendations of Power ramp up: 1. 2. 3. 4. 5. Voltage of power ramp up should be monotonic as much as possible. The minimum ramp up time should be 0.1ms. The maximum ramp up time should be 35ms for 2.7-3.6V power supply. Host shall wait until VDD is stable. After 1ms VDD stable time, host provides at least 74 clocks before issuing the first command. Power Down and Power Cycle 1. When the host shuts down the power, the card VDD shall be lowered to less than 0.5Volt for a minimum period of 1ms. During power down, DAT, CMD, and CLK should be disconnected or driven to logical 0 by the host to avoid a situation that the operating current is drawn through the signal lines. 2. If the host needs to change the operating voltage, a power cycle is required. Power cycle means the power is turned off and supplied again. Power cycle is also needed for accessing cards that are already in Inactive State. To create a power cycle the host shall follow the power down description before power up the card (i.e. the card VDD shall be once lowered to less than 0.5Volt for a minimum period of 1ms). Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 20 3.3.4 Power Up Time of Card A device shall be ready to accept the first command within 1ms from detecting VDD min. Device may use up to 74 clocks for preparation before receiving the first command. Figure 3-3: Power Up Time of Card Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 21 3.4 AC Characteristic Figure 3-4: Voltage Levels 3.4.1 MicroSD Interface Timing (Default) Figure 3-5: Card Input Timing (Default Speed Card) Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 22 Figure 3-6: Card Output Timing (Default Speed Card) Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 23 Table 3-15: Timing Specifications Parameter Symbol Min Max Unit Remark Clock CLK (All values are referred to min(VIH) and max(VIL) 25 MHz Ccard≤10 pF (1 card) 0(1)/100 400 kHz Ccard≤10 pF (1 card) Clock frequency Data Transfer Mode fPP 0 Clock frequency Identification Mode fOD Clock low time tWL 10 ns Ccard≤10 pF (1 card) Clock high time tWH 10 ns Ccard≤10 pF (1 card) Clock rise time tTLH 10 ns Ccard≤10 pF (1 card) Clock fall time tTHL 10 ns Ccard≤10 pF (1 card) Inputs CMD, DAT (referenced to CLK) Input set-up time tISU 5 ns Ccard≤10 pF (1 card) Input hold time tIH 5 ns Ccard≤10 pF (1 card) Outputs CMD, DAT (referenced to CLK) Output Delay time during Data Transfer Mode tODLY 0 14 ns Ccard≤40 pF (1 card) Output Delay time during Identification Mode tODLY 0 50 ns Ccard≤40 pF (1 card) Notes: 1) 0Hz means to stop the clock. The given minimum frequency range is for cases where continuous clock is required. Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 24 3.4.2 MicroSD Interface Timing (High-Speed Mode) Figure 3-7: Card Input Timing (High Speed Card) Figure 3-8: Card Output Timing (High Speed Card) Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 25 Table 3-16: Card Output Timing (High Speed Card) Parameter Symbol Min Max Unit Remark Clock CLK (All values are referred to min(VIH) and max(VIL) 50 MHz Ccard≤10 pF (1 card) Clock frequency Data Transfer Mode fPP 0 Clock low time tWL 7 ns Ccard≤10 pF (1 card) Clock high time tWH 7 ns Ccard≤10 pF (1 card) Clock rise time tTLH 3 ns Ccard≤10 pF (1 card) Clock fall time tTHL 3 ns Ccard≤10 pF (1 card) Inputs CMD, DAT (referenced to CLK) Input set-up time tISU 6 ns Ccard≤10 pF (1 card) Input hold time tIH 2 ns Ccard≤10 pF (1 card) ns Ccard≤40 pF (1 card) ns Ccard≤15 pF (1 card) ns Ccard≤15 pF (1 card) Outputs CMD, DAT (referenced to CLK) Output Delay time during Data Transfer Mode tODLY 0 Output hold time tOH 2.5 Total System capacitance of each CL 0 14 40 Notes: 1) In order to satisfy severe timing, the host shall drive only one card. Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 26 3.4.3 MicroSD Interface Timing (SDR12, SDR25 and SDR50 Modes) Figure 3-9: Clock Signal Timing (Input) Table 3-17: Clock Signal Timing Symbol Min Max tCLK 4.8 - Unit Remark ns 208MHz (Max.), Between rising edge, VCT= 0.975V tCR, tCF < 0.96ns (max.) at 208MHz, CCARD=10pF tCR, tCF Clock Duty Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 - 0.2* tCLK ns 30 70 % tCR, tCF < 2.00ns (max.) at 100MHz, CCARD=10pF The absolute maximum value of tCR, tCF is 10ns regardless of clock frequency MicroSD Card 3.0 Page 27 Figure 3-10: SDR50 and SDR104 Card Input Timing Table 3-18: SDR50 and SDR104 Card Input Timing Symbol Min Max Unit tIS 1.4 - ns CCARD =10pF, VCT= 0.975V tIH 0.8 1 - ns CCARD = 5pF, VCT= 0.975V Symbol Min Max Unit tIS 3.00 - ns CCARD =10pF, VCT= 0.975V tIH 0.8 1 - ns CCARD = 5pF, VCT= 0.975V Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 SDR104 Mode SDR104 Mode Page 28 Figure 3-11: Clock Signal Timing (Output Timing of Fixed Data) Table 3-19: Output Timing of Fixed Data Window (SDR12, SDR25, SDR50) Symbol Min Max Unit tODLY - 7.5 ns tCLK>=10.0ns, CL=30pF, using driver Type B, for SDR50 tODLY - 14 ns tCLK>=20.0ns, CL=40pF, using driver Type B, for SDR25 and SDR12 TOH 1.5 - ns Hold time at the tODLY (min.), CL=15pF Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 Remark MicroSD Card 3.0 Page 29 Figure 3-12: Output Timing of Variable Window (SDR104) Table 3-20: Output Timing of Variable Window (SDR104) Symbol Min Max Unit 0 2 UI Card Output Phase △tOP -350 +1550 ps Delay variable due to temperature change after tuning tODW 0.6 - UI tODW = 2.88ns at 208MHz tOP Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 Remark MicroSD Card 3.0 Page 30 3.4.4 MicroSD Interface Timing (DDR50 Mode) Figure 3-13: Clock Signal Timing Table 3-21: Clock Signal Timing Symbol Min Max Unit tCLK 20 - ns 50MHz (Max.), Between rising edge - 0.2* tCLK ns tCR, tCF < 4.00ns (max.) at 50MHz, CCARD=10pF 45 55 % tCR, tCF Clock Duty Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 Remark MicroSD Card 3.0 Page 31 Figure 3-14: Timing Diagram DAT Inputs/Outputs Referenced to CLK in DDR50 Mode Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 32 Table 3-22: Bus Timings – Parameters Values (DDR50 Mode) Parameter Symbol Min Max Unit Remark Inputs CMD (referenced to CLK) Input set-up time tISU 3 - ns Ccard≤10 pF (1 card) Input hold time tIH 0.8 - ns Ccard≤10 pF (1 card) ns CL≤30 pF (1 card) ns CL≥15 pF (1 card) Outputs CMD (referenced to CLK) Output Delay time during Data Transfer Mode Output hold time tODLY 0 tOH 1.5 13.7 Inputs DAT(referenced to CLK) Input set-up time tISU2x 3 - ns Ccard≤10 pF (1 card) Input hold time tIH2x 0.8 - ns Ccard≤10 pF (1 card) 13.7 ns CL≤25 pF (1 card) ns CL≥15 pF (1 card) Outputs DAT (referenced to CLK) Output Delay time during Data Transfer Mode Output hold time Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 tODLY2x 0 tOH2x 1.5 MicroSD Card 3.0 Page 33 4 INTERFACE 4.1 Pad Assignment and Descriptions 4.1.1 MicroSD Bus Pin Assignment Table 4-1: MicroSD Bus Pin Assignment SD Mode Pin # Name 1 2 3 4 5 6 7 8 Type 1 SPI Mode Description Name Type1 Description DAT2 I/O /PP Data Line[Bit2] RSV CD/ DAT3 I/O/PP Card Detect Line[Bit3] CS I Chip Select (neg true) CMD PP Command/Response DI I Data In Vdd S Supply Voltage Vdd S Supply Voltage CLK I Clock SCLK I Clock VSS S Supply voltage ground VSS S Supply voltage ground DAT0 I/O /PP Data Line[Bit0] DO O/PP Data Out DAT1 I/O /PP Data Line[Bit1] RSV - Reserved (*) Notes: 1) S: power supply; I: input; O: output using push-pull drivers; PP: I/O using push-pull drivers; 2) The extended DAT lines (DAT1-DAT3) are input on power up. They start to operate as DAT lines after SET_BUS_WIDTH command. The Host shall keep its own DAT1-DAT3 lines in input mode, as well, while they are not used. 3) At power up this line has a 50KOhm pull up enabled in the card. This resistor serves two functions Card detection and Mode Selection. For Mode Selection, the host can drive the line high or let it be pulled high to select MicroSD mode. If the host wants to select SPI mode it should drive the line low. For Card detection, the host detects that the line is pulled high. This pull-up should be disconnected by the user, during regular data transfer, with SET_CLR_CARD_DETECT (ACMD42) command Figure 4-1: MicroSD Pin Assignment (Back View of the Card) Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 34 Table 4-2: Registers Name Width Description CID 128bit Card identification number; card individual number for identification. Mandatory RCA 16bit Relative card address; local system address of a card, dynamically suggested by the card and approved by the host during initialization. Mandatory DSR 16bit Driver Stage Register; to configure the card's output drivers. Optional CSD 128bit Card Specific Data; information about the card operation conditions. Mandatory SCR 64bit SD Configuration Register; information about the MicroSD Memory Card's Special Features capabilities. Mandatory OCR 32bit Operation conditions register. Mandatory SSR 512bit SD Status; information about the card proprietary features. Mandatory OCR 32bit Card Status; information about the card status. Mandatory 1 Notes: 1) RCA register is not used (available) in SPI mode Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 35 5 Mechanical Information Figure 5-1: MicroSD Case Dimensions Note: All dimension in mm. Drawing is not to scale Datasheet: PSFUSDxxxxCxxxx Revision A| November 13, 2018 MicroSD Card 3.0 Page 36
VAFUSD064GCEAVH2 价格&库存
很抱歉,暂时无法提供与“VAFUSD064GCEAVH2”相匹配的价格&库存,您可以联系我们找货
