VNFUSB3016GCCDWT3
VNFUSB3016GCCDWT3
    VIKINGTECHNOLOGY
    16GB USB3.0 USB STICK
VNFUSB3016GCCDWT3 数据手册
Ordering Information: USB 3.0 Thumbdrives Viking High Performance USB Drive Ordering Information VNFUSB3064GCC5WT3 (0 to +70'c) Raw Capacity (GB) 64 VNFUSB3032GCC1WT3 (0 to +70'c) 32 SMI USB 3.0 TSB 3D TLC NAND VNFUSB3016GCCDWT3 Note: (0 to +70'c) 16 SMI USB 3.0 TSB 3D TLC NAND Part Number Temp Controller Interface NAND SMI USB 3.0 TSB 3D TLC NAND 1. Storage capacity listed will vary due to formatting and additional functions, and therefore is not available for storage. 2. USB’s ship unformatted from the factory unless otherwise stated or requested. 3. All USBs are based on TLC flash unless otherwise requested. 4. The lower case “xx” characters denotes a wild card to specify locked BOM attributes (i.e MLC NAND or customer specific information 5. Modules are 5V standard. Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com 7/25/2018 Viking Technology Page 1 of 10 Product Picture(s) Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com 7/25/2018 Viking Technology Page 2 of 10 Table of Contents 1 INTRODUCTION 5 1.1 Product Overview 5 1.2 Features 5 1.3 USB Interface 6 2 PRODUCT SPECIFICATIONS 6 2.1 Performance 6 2.2 Electrical Characteristics 2.2.1 Absolute Maximum Ratings 2.2.2 DC Operating Conditions and Characteristics 2.2.3 Power Consumption 2.2.4 Capacitance 6 6 6 7 7 2.3 Environmental Conditions 2.3.1 Temperature and Altitude 7 7 2.4 Reliability 8 3 MECHANICAL INFORMATION 8 3.1 Physical Dimensions 8 3.2 Weight 8 4 PIN AND SIGNAL DESCRIPTIONS 9 5 CERTIFICATIONS AND COMPLIANCE 9 6 REFERENCES 10 7 REVISION HISTORY 10 8 INDEX 10 Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com 7/25/2018 Viking Technology Page 3 of 10 Table of Tables Table 2-1: Absolute Maximum Ratings _____________________________________________ 6 Table 2-2: Voltage and Current Ratings _____________________________________________ 6 Table 2-3: Bus Line Capacitance __________________________________________________ 7 Table 2-4: Temperature and Altitude Related Specifications _____________________________ 7 Table 2-5: Reliability Specifications ________________________________________________ 8 Table 3-1: Physical Dimensions ___________________________________________________ 8 Table 4-1: Pin Assignments ______________________________________________________ 9 Table 5-1: Device Certifications ___________________________________________________ 9 Table of Figures No table of figures entries found. Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com 7/25/2018 Viking Technology Page 4 of 10 1 Introduction 1.1 Product Overview Viking Flash Drives are small, removable, high-speed USB 3.0 and USB 2.0 compatible data storage systems using flash technology. USB Drives allow easy data storage and transfer via the USB port on the host system with no driver installation required. The high speed Read/Write operation eliminates latency and seek-time associated with a hard disk drive. Flash storage incorporates an intelligent power management scheme that provides the lowest total power consumption. 1.2 Features The USB drive delivers the following features:  USB 3.0 high speed compatible (supports Bulk-Only transport protocol)*  Drive Activity indicator signal (Blue LED is on when USB is active)  Low power Dissipation  Solid state, Non-volatile NAND Memory  RoHS Compliant  Static Wear Leveling  Write Protect  Blue mating key inside the metal connector indicates USB 3.0 * With exception of 3.3V only operation, USB specification is 5V. Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com 7/25/2018 Viking Technology Page 5 of 10 1.3 USB Interface    The USB interface is compliant with the USB 3.0 specification. The USB interface connects the host computer to the USB. second). If the host computer is unable to negotiate USB 3.0 speeds, the USB interface automatically renegotiates to lower speeds. 2 Product Specifications 2.1 Performance USB 3.0 adds the new transfer rate referred to as SuperSpeed USB (SS) that can transfer data at up to 5 Gbit/s (625 MB/s), which is about 10 times as fast as the older USB 2.0 standard. The actual read/write bandwidth may be lower due to software overhead. 2.2 Electrical Characteristics 2.2.1 Absolute Maximum Ratings Table 2-1: Absolute Maximum Ratings Parameter Symbol Value Unit 5.0 Supply Voltage VBUS -0.3 ~ 5.5 V 3.3 Supply Voltage VBUS -0.3 ~ 3.6 V Input Voltage VIN GND - 0.5 ~ VCC + 0.3 V Storage Temperature TST -40 ~ 125 C Notes: 1. Permanent device damage may occur if ‘ABSOLUTE MAXIMUM RATINGS’ are exceeded. Functional operation should be restricted to recommended operating condition. Exposure to higher than recommended voltage for extended periods of time could affect device reliability. 2.2.2 DC Operating Conditions and Characteristics Table 2-2: Voltage and Current Ratings Parameter Symbol Min. Typical Max. Unit 5.0 Supply voltage (± 5%) VBUS 4.75 5.0 5.25 V Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com 7/25/2018 Viking Technology Page 6 of 10 Parameter Symbol Min. Typical Max. Unit 3.3 Supply voltage (± 5%) Input high voltage VBUS VIH VIL VOH VOL ISTB IOP 3.135 2.0 2.4 - 3.3 22 est 140 est 3.465 0.8 V V V V V µA mA Input low voltage Output high voltage Output low voltage 2 Standby Current 2 Operating Current Notes: 1. Recommended operating conditions (Voltages referenced to GND, TA = 0 to 70C) 2. Based on 3.3V NAND, BGA or TSOP 0.4 56 est 200 2.2.3 Power Consumption Maximum Power Consumption is 1 watt. 2.2.4 Capacitance Table 2-3: Bus Line Capacitance Parameter Bus line capacitance Symbol Min Max Unit CL - 20 est pF 2.3 Environmental Conditions 2.3.1 Temperature and Altitude Table 2-4: Temperature and Altitude Related Specifications Conditions Commercial Temperature Industrial 1 Temperature Humidity (noncondensing) Max Temperature Gradient Altitude Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com Operating 0 to 70°C (32 to 158° F) -40 to 85°C (-40 to 185° F) Shipping -40 to 85°C (-40 to 185° F) -40 to 85°C (-40 to 185° F) Storage -40 to 85°C (-40 to 185° F) -40 to 85°C (-40 to 185° F) 5% to 95% 5% to 95% 5% to 95% n/a n/a -304.8 to 24,384 m -304.8 to 24,384 m 20°C/Hour (36°F/Hour) -304.8 to 24,384 m 7/25/2018 Viking Technology Page 7 of 10 (-1,000 to 80,000 ft) (-1,000 to 80,000 ft) (-1,000 to 80,000 ft) n/a n/a 1 year Storage Time Duration Notes: 1. TLC flash based products are available in the following temperature ranges: a) Commercial temperature range of 0 to 70°C (32 to 158° F) b) Industrial temperature range -40 to 85°C (-40 to 185° F) 2.4 Reliability Table 2-5: Reliability Specifications Parameter Value Mean Time Between Failures (MTBF) 2,500,000 hours est Read Endurance Write or Erase Endurance Data retention Unlimited (specified by the flash component) >10 years 3 Mechanical Information 3.1 Physical Dimensions Table 3-1: Physical Dimensions Height (mm) Width (mm) Length (mm) 13 21.9 72 Notes: 1. All dimensions are in millimeters. 3.2 Weight The USB weight is 10grams Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com 7/25/2018 Viking Technology Page 8 of 10 4 Pin and Signal Descriptions Table 4-1: Pin Assignments Pin Number 1 Signal Name Description Mating Sequence VBUS Power Second USB 2.0 differential pair Third Ground for power return Second 2 D- 3 D+ 4 GND 5 StdA_SSRX- 6 StdA_SSRX+ 7 GND_DRAIN 8 StdA_SSTX- 9 StdA_SSTX+ Shell Shield SuperSpeed receiver differential pair Ground for signal return Last SuperSpeed transmitter differential pair Connector metal shell First Notes: 1. Tx and Rx are defined from the host perspective 2. Note that pins 1 to 4 are referred to as the USB 2.0 pins, while pins 5 to 9 are referred to as the SuperSpeed pins. 5 Certifications and Compliance Table 5-1: Device Certifications Certification/Compliance RoHS EU WEEE Compliant Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com Description Viking, Sanmina-SCI Corporation ("Viking") shall use commercially reasonable efforts to provide components, parts, materials, products and processes to customers that do not contain: (i) lead, mercury, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE) above 0.1% by weight in homogeneous material or (ii) cadmium above 0.01% by weight of homogeneous material, except as provided in any exemption(s) from RoHS requirements (including the most current version of the "Annex" to Directive\ 2002/95/EC of 27 January, 2003), as codified in the specific laws of the EU member countries. Viking strives to obtain appropriate contractual protections from its suppliers in connection with the RoHS Directives. The Waste Electrical and Electronic Equipment Directive (WEEE Directive) is the European Community directive 2002/96/EC on waste electrical and electronic equipment (WEEE) which, together with the RoHS Directive 2002/95/EC, became European Law in February 2003, setting collection, recycling and recovery targets for all types of electrical goods. 7/25/2018 Viking Technology Page 9 of 10 Certification/Compliance Safety Description All printed circuit boards (PCBs) have a flammability rating of UL94V-0. 6 References   USB Specification, version 3.0 https://en.wikipedia.org/wiki/USB_3.0 7 Revision History Revision Release Date A 7/25/18 Description of Change Checked By (Full Name) Initial release based on modified PSFUSB2XXXXCXX. Update performance and revise pin assignment 8 INDEX Endurance ...................................... 8 Environmental Conditions ............... 7 Erase Endurance ............................ 8 Humidity .......................................... 7 Manual PSFUSB2XXXXCXXXX Revision A www.vikingtechnology.com MTBF .............................................. 8 Power Consumption ........................ 7 Temperature.................................... 7 7/25/2018 Viking Technology Page 10 of 10
VNFUSB3016GCCDWT3 价格&库存
很抱歉,暂时无法提供与“VNFUSB3016GCCDWT3”相匹配的价格&库存,您可以联系我们找货
VNFUSB3016GCCDWT3
  • 500+135.18158500+17.51075
