VRFDUC38192AIRZ1
VRFDUC38192AIRZ1
    VIKINGTECHNOLOGY
    模块
    FLASH DUC TYPE3, 8GB 5V INDUSTRI
VRFDUC38192AIRZ1 数据手册
Viking eUSB Embedded USB Manual ~ Industrial Products Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 1 of 16 Revision History Date Revision Description X1 9/16/2014 Initial release on a modified PSFDUC3XXXXYXX_A1 (version 2 only). Revised Standby Current and Operating Current based on 3.3V NAND devices. Revised for single channel only and 2 flash device. Revise Voltage and Current Ratings table. X2 1/15/15 Revise PN table per PSG_PartSelectionGuide_SSD_2015 A 1/30/15 A1 3/3/2015 B 3/13/2015 Reviewed by DVT: Add VRFDUC3x016GACxxx to PN table Revise Performance values per Engineering. Remove Power table 2-5. Updated to final for review and signoff Revise per DVT review C 6/03/2015 D 7/27/2015 E 7/30/2015 F 9/1/2015 G 9/30/2015 H 11/10/2015 I 5/12/16 Add “max” to height measurement J 10/31/16 K 3/6/17 L 3/9/17 M 4/5/17 N 3/21/18 Add VRFDUC38192AIRZ1 DVT Iometer 2006 performance run showing sustained read and write speeds for VRFDUC3032GACSE2 with Toshiba 128Gbit SLC H die BGA Revise PN table Add VRFDUC38192ACQTH VRFDUC3016GAIRB1 VRFDUC38192AIRZ1 VRFDUC3L8192AIR3V1 Add VRFDUC3016GAIRB1, VRFDUC38192AIRZ1, VRFDUC3L8192AIR3V1 Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com Add 4GB and 8GB PSLC Add VRFDUC3L016GACRTH (7-22-15) and VRFDUC34096ACW01 (7/27/2015) change VRFDUC3L016GACRTH to low Profile change SLC 24nm based product to enterprise (7/29/2015) add notes on 3.3v vs. 5v (7/30/2015) Add VRFDUC3L016GACR3TH per PSG update. (8/15/15) Change pSLC in MLC PN’s to client application per IDC review. (9/1/2015) VRFDUC3L032GACSTH (9/30) SLC performance based on IOMeter 2006 using a 32GB eUSB with Toshiba SLC NAND toggle. Add VRFDUC3L032GACSTH and update SLC performance based on IOMeter 2006 using a 32GB eUSB with Toshiba SLC NAND toggle. Update SLC performance based new controller FW for HyMap. 3/21/2018 Viking Technology Page 2 of 16 Legal Information Legal Information Copyright© 2018 Sanmina Corporation. All rights reserved. The information in this document is proprietary and confidential to Sanmina Corporation. No part of this document may be reproduced in any form or by any means or used to make any derivative work (such as translation, transformation, or adaptation) without written permission from Sanmina. Sanmina reserves the right to revise this documentation and to make changes in content from time to time without obligation on the part of Sanmina to provide notification of such revision or change. Sanmina provides this documentation without warranty, term or condition of any kind, either expressed or implied, including, but not limited to, expressed and implied warranties of merchantability, fitness for a particular purpose, and noninfringement. While the information contained herein is believed to be accurate, such information is preliminary, and should not be relied upon for accuracy or completeness, and no representations or warranties of accuracy or completeness are made. In no event will Sanmina be liable for damages arising directly or indirectly from any use of or reliance upon the information contained in this document. Sanmina may make improvements or changes in the product(s) and/or the program(s) described in this documentation at any time. Sanmina, Viking Technology, Viking Modular Solutions, and the Viking logo are trademarks of Sanmina Corporation. Other company, product or service names mentioned herein may be trademarks or service marks of their respective owners. Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 3 of 16 Ordering Information: eUSB Family Viking High Performance USB embedded Drive Ordering Information for USB 2.0 using Hyperstone U8 controller eUSB Standard (0 to +70'c) SLC User GB 8 Enterprise Hyperstone U8 USB 2.0 TSB 24nm SLC VRFDUC3L8192ACQ3TH eUSB Low Profile (0 to +70'c) SLC 8 Enterprise Hyperstone U8 USB 2.0 TSB 24nm SLC VRFDUC3L016GACR3TH eUSB Low Profile (0 to +70'c) SLC 16 Enterprise Hyperstone U8 USB 2.0 TSB 24nm SLC eUSB Standard (0 to +70'c) SLC 16 Enterprise Hyperstone U8 USB 2.0 TSB 24nm SLC VRFDUC38192AIRZ1 eUSB Low Profile (0 to +70'c) SLC 8 Enterprise Hyperstone U8 USB 2.0 TSB 24nm SLC VRFDUC3L8192AIR3V1 eUSB Low Profile (0 to +70'c) SLC 8 Enterprise Hyperstone U8 USB 2.0 TSB 24nm SLC Part Number VRFDUC38192ACQTH VRFDUC3016GAIRB1 Form Factor Temp NAND Part Number Decoder VRFDUC3(L)xxxxACy(3)(M)zz Client/Ent Controller Interface NAND Form Factor xxxx =Capacity (GB) Controller Temp Blank=eUSB Std Profile L=eUSB Low Profile 4G=4096 8G=8192 16G=016G 32G=032G A= Hyperstone U8 I=(-40 to +85 ºC) C=(0 to +70'c) y= Device code Voltage NAND M=MLC 3 = 3.3V Blank=5V Blank= SLC Customer unique Alpha Numeric zz=wildcard characters Blank= Generic Note: 1. The pSLC (pseudo-SLC firmware) part numbers use double the user MLC NAND and Hyperstone U8 controller with pSLC firmware 2. Modules are 5V standard and 3.3V selectable by BOM resistor options. Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 4 of 16 Table of Contents 1 INTRODUCTION 7 1.1 Product Overview 7 1.2 Features 7 1.3 Block Diagram 8 1.4 USB Interface 9 2 PRODUCT SPECIFICATIONS 9 2.1 Performance 9 2.2 Timing 9 2.3 Power-up AC timing Requirements 9 2.4 Electrical Characteristics 2.4.1 Absolute Maximum Ratings 2.4.2 DC Operating Conditions and Characteristics 2.4.3 Power Consumption 2.4.4 Capacitance 10 10 10 10 11 2.5 Environmental Conditions 2.5.1 Temperature and Altitude 11 11 2.6 Reliability 11 3 MECHANICAL INFORMATION 13 4 PIN AND SIGNAL DESCRIPTIONS 15 4.1 Signal and Power Description Tables 15 5 CERTIFICATIONS AND COMPLIANCE 16 6 REFERENCES 16 Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 5 of 16 Table of Tables Table 2-2: Maximum Sustained Read and Write Bandwidth _____________________________ 9 Table 2-3: Timing Specifications __________________________________________________ 9 Table 2-4: Absolute Maximum Ratings ____________________________________________ 10 Table 2-5: Voltage and Current Ratings ____________________________________________ 10 Table 2-6: Bus Line Capacitance _________________________________________________ 11 Table 2-7: Temperature and Altitude Related Specifications ____________________________ 11 Table 2-8: Reliability Specifications _______________________________________________ 11 Table 4-1: eUSB Connector Pin Signal Definitions ___________________________________ 15 Table 5-1: Device Certifications __________________________________________________ 16 Table of Figures Figure 1-1: High-Level Block Diagram ______________________________________________ 8 Figure 3-1: Dimensions ( low profile) ______________________________________________ 13 Figure 3-2: Dimensions (standard profile) __________________________________________ 14 Figure 4-1: Connector Pin Assignments ____________________________________________ 15 Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 6 of 16 1 Introduction 1.1 Product Overview Viking Technology’s Embedded USB (eUSB) module provides a rugged, reliable and cost effective non-volatile memory, solutions to OEM customers in the Communication, Networking, Embedded and Industrial markets. The eUSB module is a secure pluggable device and a drop-in replacement for Intel® ZU130 Value Solid State Drive with a USB 2.0 interface, ECC and global wearleveling. Additional options such as MLC (Multi Level Cell) technology and ESD protection are also available. Viking’s rugged industrial designed USB’s offer the highest flash storage reliability and performance in harsh environments such as shock, vibration, humidity, altitude, ESD, and extreme temperatures. Viking USB’s meet JEDEC JESD22 standards and pass numerous qualifications including MIL-STDs and NEBS. Viking can also provide specialized services to OEMs designing customized hardware and systems by offering:  Locked BOM control with customer product change notification (PCN)  Pre-installed software, custom software imaging and ID strings  Custom packaging and labeling  Comprehensive supply-chain management  Customer specified testing  30k volt ESD protection  Conformal coating  Localized Field Application Engineering for complete pre and post sale technical support 1.2 Features The embedded USB drive delivers the following features:  USB 2.0 high speed compatible (supports Bulk-Only transport protocol)* o Specification for Host Interface up to 60MB/s (480Mbit/s)  Drive Activity indicator signal  Firmware upgradeable via USB bus  Low power Dissipation  Solid state, Non-volatile NAND Memory Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 7 of 16   RoHS Compliant Static Wear Leveling * With exception of 3.3V only operation, USB specification is 5V. 1.3 Block Diagram Figure 1-1: High-Level Block Diagram USB/NAND CONTROLLER VOLTAGE REGULATOR 5V – 3.3V 3.3V 5V RAM BUFFER 5.0V LOCAL MICROPROCESSOR USB ENDPOINT CONTROLLER HOST CONNECTOR DM ` FLASH NAND DP DATA BUFFER #ACTIVE GND FLASH MEMORY INTERFACE (SINGLE CHANNEL) ECC OSCILLATOR Notes: Up to 4 CE on a channel. (8 CE may be configurable via GPIO firmware option) Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 8 of 16 1.4 USB Interface    The USB interface is compliant with the USB 2.0 specification. The USB interface connects the host computer to the embedded USB. The USB 2.0 interface runs at a maximum speed of 480Mbps (megabits per second). If the host computer is unable to negotiate highest speed, the USB interface automatically renegotiates to lower speeds. 2 Product Specifications 2.1 Performance The host interface speed is 480Mbit/s with a read/write bandwidth shown in the following table. Table 2-1: Maximum Sustained Read and Write Bandwidth MB/s Access Type (100% Sequential) SLC: Read, Single Channel Max Up to 33 SLC: Write, Single Channel Max Up to 28 Note: DVT Iometer 2006 performance run showing sustained read and write speeds for VRFDUC3032GACSE2 with Toshiba 128Gbit SLC H die BGA 2.2 Timing Table 2-2: Timing Specifications 2.3 Power-up AC timing Requirements Parameter Symbol Min. Typical Max. Unit Power on Time to Ready (from 2.7V VBUS) tRESET 100 150 250 ms Notes: 1. This power-up timing can be changed to 10ms upon request. The long power-up delay is designed to accommodate slow power-up times of rack systems. Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 9 of 16 2.4 Electrical Characteristics 2.4.1 Absolute Maximum Ratings Table 2-3: Absolute Maximum Ratings Parameter Symbol Value Unit 5.0 Supply Voltage VBUS -0.3 ~ 5.5 V 3.3 Supply Voltage VBUS -0.3 ~ 3.6 V Input Voltage VIN GND - 0.5 ~ VCC + 0.3 V Storage Temperature TST -40 ~ 125 C Notes: 1. Permanent device damage may occur if ‘ABSOLUTE MAXIMUM RATINGS’ are exceeded. Functional operation should be restricted to recommended operating condition. Exposure to higher than recommended voltage for extended periods of time could affect device reliability. 2.4.2 DC Operating Conditions and Characteristics Table 2-4: Voltage and Current Ratings Parameter Symbol Min. Typical Max. Unit 5.0 Supply voltage (± 5%) 3.3 Supply voltage (± 5%) Input high voltage VBUS VBUS VIH VIL VOH VOL 4.75 3.135 2.0 2.4 - 5.25 3.465 0.8 0.4 23.1 + 33 V V V V V V µA 2 Flash Devices ISTB - 5.0 3.3 16.5 + 6.6 16.5 + 13.2 23.1 + 66 µA 1 Flash Device 2 Flash Devices IOP - 165 + 19.8 165 + 39.6 mA mA Input low voltage Output high voltage Output low voltage 1 Flash Device Standby Current 2 Operating Current 2 132 + 9.9 132 + 19.8 Notes: 1. Recommended operating conditions (Voltages referenced to GND, TA = 0 to 70C) 2. Based on 3.3V NAND, BGA or TSOP 2.4.3 Power Consumption All onboard power requirements of the eUSB are derived from the 5V or 3.3V input rail. Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 10 of 16 2.4.4 Capacitance Table 2-5: Bus Line Capacitance Parameter Bus line capacitance Symbol Min Max Unit CL - 20 pF 2.5 Environmental Conditions 2.5.1 Temperature and Altitude Table 2-6: Temperature and Altitude Related Specifications Conditions Operating Shipping Storage Commercial 0 to 70°C -40 to 125°C -40 to 125°C 0 to 70°C or -40 to 85°C -40 to 125°C -40 to 125°C 5% to 95% 5% to 95% 5% to 95% 20°C/Hour n/a n/a -304.8 to 24,384 m -304.8 to 24,384 m -304.8 to 24,384 m n/a n/a 1 year Industrial 1 Humidity (non-condensing) Max Temperature Gradient Altitude Storage Time Notes: 1. SLC flash based products are available in the following operating temperature ranges: a) Commercial temperature range of 0 to 70°C b) Industrial temperature range -40 to 85°C 2.6 Reliability Table 2-7: Reliability Specifications Parameter ECC Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com Value 96-Bit/1KB BCH 3/21/2018 Viking Technology Page 11 of 16 Parameter Value Mean Time Between Failures (MTBF) Power On/Off Cycles Read Endurance 2 Write or Erase Endurance Wear-leveling Data retention 1 2,500,000 hours 50,000 power cycles Unlimited SLC: 60-100K PE pSLC: 30K PE MLC: 3K PE Global >10 years Notes: 1. MTBF is calculated based on a Part Stress Analysis. It assumes nominal voltage, with all other o parameters within specified range. Telcordia method SR-332 component FIT rate at 55 c. 2. Power On/Off Cycles defined as power being removed from the drive, and then restored. Note that host systems and drive enclosures may remove power from the drive for reasons other than a system shutdown. Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 12 of 16 3 Mechanical Information Figure 3-1: Dimensions ( low profile) PCB thickness 6.277mm Max Primary Side (Top View) (Bottom View) Overall thickness Side View Low profile Module Connector: SAMTEC SMM-105-02-F-D-LC-09-P-TR Pitch: 2.00mm Secondary Side Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 13 of 16 Figure 3-2: Dimensions (standard profile) PCB thickness See Note 4 10.093mm Max Primary Side (Top View) (Bottom View) Overall thickness Side View Notes: 1. Standard Profile Module Connector: SAMTEC SSM-105-L-DV-LC-009-P-TR Pitch: 2.54mm 2. Dimensions shown in millimeters 3. Max screw penetration is 5mm at all 4 locations. 4. The module connector height is 7.4 ± 0.13 [0.290± 0.005] Secondary Side Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 14 of 16 4 Pin and Signal Descriptions Figure 4-1: Connector Pin Assignments 4.1 Signal and Power Description Tables Table 4-1: eUSB Connector Pin Signal Definitions Pin 1 2 3 4 5 6 7 8 9 Signal Name VBUS NC DM NC DP NC GND NC N/A Type Power NC I/O NC I/O NC Power NC Key 10 #Activity I/O Description 3.3 or 5V power supply Not connected USB 2.0 Data Negative Pin Not connected USB 2.0 Data Positive Pin Not connected Ground Not connected Polarization Status signal that indicates when the drive is busy. This signal may be used to drive a low current LED or other logic on the host to indicate drive status to the user or system. This signal is active low and has a 4mA drive strength. Notes: 1. * Available custom options: Pin 2 Chassis ground option; Pin 4 Hardware /WP; Pin 6 Hardware /Reset. Custom options available on locked BOMs only. 2. 3.3 or 5V is designated by the part number Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 15 of 16 5 Certifications and Compliance Table 5-1: Device Certifications Certification/Compliance RoHS EU WEEE Compliant Safety Description Viking Technology, Sanmina Corporation ("Viking") shall use commercially reasonable efforts to provide components, parts, materials, products and processes to customers that do not contain: (i) lead, mercury, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE) above 0.1% by weight in homogeneous material or (ii) cadmium above 0.01% by weight of homogeneous material, except as provided in any exemption(s) from RoHS requirements (including the most current version of the "Annex" to Directive\ 2002/95/EC of 27 January, 2003), as codified in the specific laws of the EU member countries. Viking strives to obtain appropriate contractual protections from its suppliers in connection with the RoHS Directives. The Waste Electrical and Electronic Equipment Directive (WEEE Directive) is the European Community directive 2002/96/EC on waste electrical and electronic equipment (WEEE) which, together with the RoHS Directive 2002/95/EC, became European Law in February 2003, setting collection, recycling and recovery targets for all types of electrical goods. All printed circuit boards (PCBs) have a flammability rating of UL94V-0. 6 References  USB Specification, version 2.00 Manual PSFDUC3XXXXAXX Revision N www.vikingtechnology.com 3/21/2018 Viking Technology Page 16 of 16
VRFDUC38192AIRZ1 价格&库存
很抱歉,暂时无法提供与“VRFDUC38192AIRZ1”相匹配的价格&库存,您可以联系我们找货
