MOD 2-B MINI-RTU
MOD 2-B MINI-RTU
    VISIONARYELECTRONICS
    INPUT MODULE 32 DIGITAL 12-130V
MOD 2-B MINI-RTU 数据手册
Mod 2-B Mini-RTU • • • • • • • • Full Electric Power Industry Compliance Designed for Medium or Large Substations Protocol Conversions for local IEDs Multiple Protocols for SCADA Master and Local IEDs Historical Data for all I/O Points Units can be Daisy-Chained for Large Point Counts Available as Bare Boards or in a NEMA Enclosure Custom Applications are our Specialty Specifications: • • • • • • • • • • • • Control Sequence: Direct or SBO 32 Relay Contacts: Form C, 10 Amps at 240Vac or 150Vdc 48 Analog Inputs with twelve-bit resolution, pre-scaled to ± 1 VDC with 0.1% accuracy 32 Status Inputs Status Input Voltage: 12Vdc to 130Vdc, positive or negative polarity Input Current: 0.1ma (typical) Isolation: Optical Phase-to-Ground 2000V Input Voltage: 12Vdc to 35Vdc Communication Links: 2 RS-232 Ports Available with DNP 3.0, Modbus, PG&E (Data 2179), or Telegyr 8979 Dimensions: 19.00" x 16.75" The Mini-RTUs come with a free copy of the VisiCal software suite that allows it to be configured, calibrated, scanned, monitored or programmed with drag-and-drop and pushbutton simplicity.
MOD 2-B MINI-RTU 价格&库存
很抱歉,暂时无法提供与“MOD 2-B MINI-RTU”相匹配的价格&库存,您可以联系我们找货
