FDC20-W
SINGLE AND DUAL OUTPUT, 4:1 WIDE INPUT RANGE
20 WATTS DC/DC CONVER TERS
OUTPUT SPECIFICATIONS
FEATURES
4:1 INPUT RANGE
Voltage Accuracy............................±2%
External Trim Adjustment Range...±10% typ.
Ripple and Noise, 20MHz BW
Single Output.................................75mV P-P, 20m V RMS
Dual Output....................................100mV P-P, 20m V RMS
Line Regulation, Full Line..............±0.5%
Load Regulation, FL-1/4FL............±0.25% (Single)
±2% (Dual)
FL-NL............±0.5% (Single)
±3% (Dual)
Temperature Coefficient.................±0.02%/˚C
Transient Response Recovery Time,
25% Load Step Change.................500µsec
Short Circuit Protection..................Continuous
Overvoltage Portection Threshold:
5V Output.......................................6.2V
12V Output.....................................15V
15V Output.....................................18V
PI INPUT FILTER
2 YEAR WARRANTY
HIGH EFFICIENCY
LOW PROFILE CASE
OVERVOLTAGE PROTECTION
OVERCURRENT PROTECTION
ON/OFF CONTROL
REMOTE ON/OFF CONTROL
Control Voltage Referenced to Negative (-) Input
Compatability......................................CMOS, TTL
On-Control..........................................4.8V min. or Open
Off-Control..........................................0.4V max. or Short
GENERAL SPECIFICATIONS
Switching Frequency...........................300kHz, typ.
Isolation Voltage.................................1600VDC, min
Isolation Resistance...........................10 9 Ohms , min
ENVIRONMENTAL SPECIFICATIONS
ELECTRICAL SPECIFICATIONS
All specifications are typical at nominal input, full load,
and 25˚C unless otherwise noted.
INPUT SPECIFICATIONS
Input Voltage Range 24V nominal......9 to 36V
48V nominal......18 to 72V
Input Filter...........................................PI Network
Operating Temperature Range............-25˚C to +60˚C (See Fig.1)
Alternative Operating Temperature Suffix “M2”
.............................................................-40˚C to +60˚C
Storage Temperature Range................-55˚C to +125˚C
Cooling.................................................Free-air Convection
EMI/RFI................................................Six-sided Continuous Shield
MTBF....................................................4.270x105Hours
(MIL-HDBK-217F TA=25˚C Full Load)
PHYSICAL SPECIFICATIONS
Case Material.....................................Nickel-Coated Copper with
Non-Conductive Base
Dimensions.........................................2.0x1.6x0.4 Inches
(50.8x40.6x10.2 mm)
18
Series
MODEL
INPUT VOLTAGE
OUTPUT VOLTAGE
OUTPUT CURRENT
% typ.
EFF
FDC20-24S05W
9-36VDC
5VDC
4000mA
79
FDC20-24S12W
9-36VDC
12VDC
1670mA
81
FDC20-24S15W
9-36VDC
15VDC
1330mA
81
FDC20-24D05W
9-36VDC
± 5VDC
±2000mA
79
FDC20-24D12W
9-36VDC
±12VDC
± 833mA
81
FDC20-24D15W
9-36VDC
±15VDC
± 666mA
82
FDC20-48S05W
18-72VDC
5VDC
4000mA
80
FDC20-48S12W
18-72VDC
12VDC
1670mA
81
FDC20-48S15W
18-72VDC
15VDC
1330mA
81
FDC20-48D05W
18-72VDC
± 5VDC
±2000mA
79
FDC20-48D12W
18-72VDC
±12VDC
± 833mA
83
FDC20-48D15W
18-72VDC
±15VDC
± 666mA
84
Pin Connections
Pin#
ALL DIMENSIONS IN INCHES (mm)
PIN PITCH TOLERANCE ±0.5 mm
19
Single
Dual
1
+Vin
+Vin
2
-Vin
-Vin
3
No Pin
No Pin
4
Ctrl
Ctrl
5
No Pin
+Vout
6
+Vout
Common
7
-Vout
-Vout
8
Trim
Trim
很抱歉,暂时无法提供与“FDC20-48D05W”相匹配的价格&库存,您可以联系我们找货
