KTPS05-05015U
KTPS05-05015U
    KAGA
    5V 7.5 W AC/DC 外部 壁装(II 类) 适配器 固定插片 输入
KTPS05-05015U 数据手册
KTPS05 Series 5 Watt Universal Input, Wall Mount Adapter INPUT SPECIFICATIONS All specifications are typical at nominal input, full load. INPUT SPECIFICATIONS Input Voltage AC 100 – 240VAC Input Frequency 50 – 60Hz Input Current 0.19A Max Protection Internal Primary Current Fuse Inrush Limiting OUTPUT SPECIFICATIONS Output Voltage See Chart Efficiency CEC Level V, ErP Stage 2 Certified Protection Short Circuit Protection Over Current Protection Over Voltage Protection FEATURES      UNIVERSAL INPUT (AC100-240V) OVERVOLTAGE PROTECTION OVERCURRENT PROTECTION ROHS COMPLIANT CEC LEVEL V Ripple 1 – 2 % Vp-p (max) Hold-Up Time 10 mS (min) Transient Response 0.5mS for 50% Load Change(typ) Load Regulation ± 5% (typ) ENVIRONMENTAL SPECIFICATIONS Leakage Current 0.25mA @ 2 pin Operating Temperature 0°C~+40°C Storage Temperature -20°C ~ +80°C GENERAL SPECIFICATIONS Cooling. Convection MTBF(Calculated) 300,000 Hours Calculated hours at 25°C by Telcordia SR-332 Operating Humidity 20 – 80% Rh Storage Humidity 10 – 90% Rh Dielectric Withstanding Voltage 3,000 VAC Primary – Secondary EMI Conduction & Radiation Compliance to EN55022 Class B Harmonic Current Compliance to EN61000-3-2,3 EMS Immunity Safety Approvals MECHANICAL SPECIFICATIONS Case Dimension L52 x W29 x H63 (mm) Input Configuration IEC320-C14 Optional(C6, C8, C18) Compliance to EN61000-42,3,4,5,6,8,11 DC Cord 20AWG (Optional 22 AWG) UL/cUL Output Connector 5.5 x 2.1 x 9.5mm C+ Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com KTPS05 Series Model Number Output Voltage Output Current Max Output Power KTPS05-03015U 3.0V 1.5A 4.50W KTPS05-03315U 3.3V 1.5A 4.95W KTPS05-04215U 4.2V 1.5A 6.30W KTPS05-04515U 4.5V 1.5A 6.75W KTPS05-05010U 5.0V 1.0A 5.00W KTPS05-05015U 5.0V 1.5A 7.50W KTPS05-06012U 6.0V 1.2A 7.20W KTPS05-07510U 7.5V 1.0A 7.50W KTPS05-09006U 9.0V 0.6A 5.40W KTPS05-12006U 12.0V 0.6A 7.20W KTPS05-15005U 15.0V 0.5A 7.50W Note: Optional UK, EU, and US(Frontal) Input Configuration Available. Mechanical Drawing: Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com
KTPS05-05015U
物料型号:KTPS05系列,包含多个型号,如KTPS05-03015U、KTPS05-03315U等,输出电压和电流不同,最大输出功率为7.5瓦特。
器件简介:这是一款5瓦的通用输入壁挂式适配器,具有内部初级电流保险丝和软启动限制。
引脚分配:输出连接器为5.5x2.1x9.5mm C+。
参数特性:输入电压为AC100-240V,频率50-60Hz,最大输入电流为0.19A。具有短路保护、过流保护和过压保护。效率达到CEC Level V和ErP Stage 2认证。纹波为1-2%Vp-p(最大),保持时间为10毫秒(最小),瞬态响应为0.5毫秒(50%负载变化时)。
功能详解:适配器具有通用输入(AC100-240V)、过压保护、过流保护,符合RoHS标准和CEC Level V。
应用信息:适用于需要5瓦功率的电子设备。
封装信息:外壳尺寸为L52x W29 x H63毫米,输入配置为IEC320-C14(可选C6, C8, C18),直流线为20AWG(可选22 AWG)。
环境规格:工作温度0°C至+40°C,存储温度-20°C至+80°C,冷却方式为自然对流,工作湿度20-80%Rh,存储湿度10-90%Rh。
MTBF(预计):在25°C下按照Telcordia SR-332计算为300,000小时。
安全认证:符合UL/cUL标准。
EMI/EMC特性:符合EN55022 B级传导和辐射要求,符合EN61000-3-2和3谐波电流要求,符合EN61000-4-2,3,4,5,6,8,11 EMS抗扰度要求。
机械规格:包括外壳尺寸、输入配置、直流线规格和输出连接器尺寸。
制造商信息:Kaga Electronics (USA) Inc.,位于美国加利福尼亚州圣何塞。
KTPS05-05015U 价格&库存
很抱歉,暂时无法提供与“KTPS05-05015U”相匹配的价格&库存,您可以联系我们找货
