KTPS24-1516DT 2P
KTPS24-1516DT 2P
    KAGA
    15V 24 W AC/DC 外部 台式(类 II) 适配器 缆线(单独出售) 输入
KTPS24-1516DT 2P 数据手册
KTPS24 Series 24 Watt Universal Input, Desktop Adapter INPUT SPECIFICATIONS All specifications are typical at nominal input, full load. INPUT SPECIFICATIONS Input Voltage AC 100 – 240VAC Input Frequency 50 – 60Hz Input Current 0.58A Max Protection Internal Primary Current Fuse Inrush Limiting OUTPUT SPECIFICATIONS Output Voltage See Chart Efficiency CEC Level V, ErP Stage 2, GEMS Protection Short Circuit Protection Over Current Protection Over Voltage Protection Ripple 1 - 2 % Vp-p (max) Hold-Up Time 10 mS (min) Transient Response 0.5mS for 50% Load Change(typ) Load Regulation ± 5% (typ) Leakage Current 0.25mA @ 2 pin GENERAL SPECIFICATIONS FEATURES        UNIVERSAL INPUT (AC100-240V) CEC LEVEL V OVER VOLTAGE PROTECTION OVER CURRENT PROTECTION SHORT CIRCUIT PROTECTION ROHS COMPLIANT NRCAN VERSION AVAILABLE ENVIRONMENTAL SPECIFICATIONS Operating Temperature 0°C~+40°C Storage Temperature -20°C ~ +80°C Cooling. Convection Operating Humidity 20 – 80% Rh 10 – 90% Rh MTBF(Calculated) 300,000 Calculated hours at 25°C by Telcordia SR-332 Dielectric Withstanding Voltage 3,000 VAC Primary – Secondary Storage Humidity EMI Conduction & Radiation Compliance to EN55022 Class B MECHANICAL SPECIFICATIONS Case Dimension L88 x W50 x H34(mm) Harmonic Current Compliance to EN61000-3-2,3 Input Configuration IEC320-C8 EMS Immunity Compliance to EN61000-42,3,4,5,6,8,11 DC Cord 18AWG (Optional 20 & 22 AWG) Safety Approvals UL/cUL/CE/CB/GS/PSE/FCC Output Connector 5.5 x 2.1 x 9.5 mm C+ Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com KTPS24 Series Model Number Output Voltage Output Current Max Output Power KTPS24-0540DT-2P 5.0V 4.0A 20.00W KTPS24-0635DT-2P 5.9V 3.5A 20.65W KTPS24-0730DT-2P 7.0V 3.0A 21.00W KTPS24-7530DT-2P 7.5V 3.0A 22.50W KTPS24-0925DT-2P 9.0V 2.5A 22.50W KTPS24-9525DT-2P 9.5V 2.5A 23.75W KTPS24-1220DT-2P 12.0V 2.0A 24.00W KTPS24-1516DT-2P 15.0V 1.6A 24.00W KTPS24-2410DT-2P 24.0V 1.0A 24.00W KTPS24-4805DT-2P 48.0V 0.5A 24.00W Mechanical Drawing: Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com
KTPS24-1516DT 2P 价格&库存
很抱歉,暂时无法提供与“KTPS24-1516DT 2P”相匹配的价格&库存,您可以联系我们找货
