LABC14-12V
LABC14-12V
    KAGA
    BATT CHARGER DESKTOP 14.5V 800MA
LABC14-12V 数据手册
LABC14-12V Charger 12V Lead-Acid Battery Smart Charger INPUT SPECIFICATIONS All specifications are typical at nominal input, full load. INPUT SPECIFICATIONS Input Voltage AC 100 – 264VAC Input Frequency 50 – 60Hz Protection Reverse Polarity, short circuit Battery Size 12 volt SLA, VRLA, Gel, AGM or flooded OUTPUT SPECIFICATIONS 6V /12V Charge Voltage Limited 14.5V Float Charge Voltage 13.6V Charging Current 0.8 amp Battery Types All types 12V lead acid batteries Charging Algorithm Auto 3 Stages Constant Current Stage 1 Constant current 0.8 amp Battery voltage must be above 4V Constant Voltage Stage 2 Constant voltage 14.5V Floating Stage 3 Float charge 13.6V FEATURES      UNIVERSAL INPUT (AC100-240V) CONSTANT CURRENT/VOLTAGE, REVERSE POLARITY INDICATOR SHORT CIRCUIT PROTECTION 3 STAGE AUTO CHARGING ENVIRONMENTAL SPECIFICATIONS LED Indications Pwr on, no battery connected –Green Charging – Red Charged - Flashing Green Charge/Float charging – Green Dim Reverse polarity – Red and Green flashing GENERAL SPECIFICATIONS MTBF(Calculated) 30,000 Calculated hours at 25°C by MIL-HDBK-217F Hi pot, ESD 3,000V, 1 minute ESD 8000V Operating Temperature -10°C~+40°C Storage Temperature -40°C ~ +70°C Cooling. Convection Operating Humidity 20 – 80% Rh Storage Humidity 10 – 90% Rh MECHANICAL SPECIFICATIONS Case Dimension L81 x W51 x H28(mm) Input Configuration Fixed cord 2 pin USA Output Connector 5.5 x 2.1 x 11.0mm C+ Weight 150 grams Kaga Electronics (USA) Inc. 780 Montague Expressway, #403, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com LABC14-12V Charger Mechanical Drawing: Kaga Electronics (USA) Inc. 780 Montague Expressway, #403, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com
LABC14-12V 价格&库存
很抱歉,暂时无法提供与“LABC14-12V”相匹配的价格&库存,您可以联系我们找货
