MT10-2415W
MT10-2415W
    KAGA
    DIP5 模块
    隔离模块 直流转换器 2 输出 15V -15V 500mA,500mA 18V - 36V 输入
MT10-2415W 数据手册
MT10 10 WATT DC/DC CONVER TER, SINGLE & MULTIPLE OUTPUTS ELECTRICAL SPECIFICATIONS All specifications are typical at nominal input, full load INPUT SPECIFICATIONS Input Voltage Range ........................9-18 VDC MT10 - 12 18-36 VDC MT10 - 24 36-72 VDC MT10 - 48 OUTPUT SPECIFICATIONS FEATURES RATED 15W AT 24VDC & 48VDC INPUT Output Voltage Accuracy................. ±0.5% Over-Current Protection...................Built-in Ripple Noise ................................... 150 mVp-p (DC to 20MHZ) Line Regulation................................ ±0.5% max. ±10% max. (MT10 - **03S) Line Filter......................................... Built-in Load Regulation...............................±1.0% max. (min-max load) MT10 Single ±3.0% max. (min-max load) MT10 Dual ±5.0% max. (min-max load) MT10***03S SINGLE AND DUAL OUTPUTS HIGH EFFICIENCY AND RELIABILITY HIGH I/O ISOLATION 1500VDC INTERNAL EMI FILTER LOW OUTPUT RIPPLE AND NOISE SHORT CIRCUIT PROTECTION GENERAL SPECIFICATIONS Isolation Voltage Input-Output.............................. Input-Output.............................. MTBF.............................................. Isolation Resistance........................ DC 1500V/ 1min. MT10-48 DC 750V/ 1min. MT10-12, MT10-24 >1.2 million hours Input-Output-Case1000M-ohms max. (Measured at 500 VDC) Short-Circuit Protection....................20mS max. DIRECT PCB-SOLDERING INDUSTRY STANDARD PINOUT (IC-24P) LOW PROFILE, 10mm (0.39”) HEIGHT TWO YEAR WARRANTY EMI ENVIRONMENTAL SPECIFICATIONS Operating Temperature ................... -25˚C ~ +75˚C (Case not to exceed 100˚C) Temperature Coefficient...................0.05%/°C Humidity........................................... 30%-95% RH Storage Temperature....................... -30°C~+100°C PHYSICAL SPECIFICATIONS Complys with: CISPR CLASS A Case Material.....................................Nickel-Plated Steel Dual In-Line Pin Configuration 12 Series MODEL MT10-1203S MT10-1205S MT10-1212S MT10-1215S MT10-1212W MT10-1215W MT10-2403S MT10-2405S MT10-2412S MT10-2415S MT10-2412W MT10-2415W MT10-4805S MT10-4812S MT10-4815S MT10-4812W MT10-4815W INPUT VOLTAGE 12 VDC (9 ~ 18V) 24 VDC (18 ~ 36V) 48 VDC (36 ~ 72V) OUTPUT VOLTAGE 3.3 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC OUTPUT CURRENT MIN. MAX. 240mA 180mA 85mA 65mA ±82mA ±60mA 280mA 240mA 125mA 125mA ±120mA ±100mA 240mA 125mA 100mA ±120mA ±100mA EFFICIENCY AT 100% LOAD (TYP) 2400mA 1800mA 850mA 650mA ±410mA ±330mA 2800mA 2400mA 1250mA 1000mA ±600mA ±500mA 2400mA 1250mA 1000mA ±600mA ±500mA Also available in 9-36V & 18-72V Input 76% 77% 82% 80% 80% 80% 78% 78% 86% 84% 83% 84% 82% 85% 84% 84% 85% PIN-OUT PIN 1 2 3 4 5 NOTE: All specifications typical and nominal / full load and 25˚C unless otherwise noted. Avoid sustained operation in overload or dead short conditions. Specifications subject to changes without notice. • Dimensions in mm 13 SINGLE +VIN -VIN +VOUT NO PIN -VOUT DUAL +VIN -VIN +VOUT COMMON -VOUT
MT10-2415W 价格&库存
很抱歉,暂时无法提供与“MT10-2415W”相匹配的价格&库存,您可以联系我们找货
